Roadable Aircraft ... What about this?
Old March 5th 06, 05:49 PM posted to rec.aviation.homebuilt
Default Roadable Aircraft ... What about this?
I saw earlier posts about North Texan's Butterfly and was impressed
with the depth and quality of discussion regarding patents and the
limitations and requirements for roadable aricraft.
I would welcome your feedback regarding my product:
http://www.wolffaerocycle.com/
And an article in the recent issue of Full Throttle (biker rag):
http://www.fullthrottlenyne.com/feature2.htm
Thanks
-Adam
Old March 5th 06, 06:09 PM posted to rec.aviation.homebuilt
"To invent an airplane is nothing. To build an airplane is something. But to
fly is everything."
- Otto Lilienthal
Old March 5th 06, 07:39 PM posted to rec.aviation.homebuilt
fly is everything."
- Otto Lilienthal
picky. picky. picky...
http://home.earthlink.net/~tp-1/sm-j-01.jpg
http://home.earthlink.net/~tp-1/sm-j-02.jpg
http://home.earthlink.net/~tp-1/sm-j-04.jpg
Sonny Mosel's Fisher Jungster
(with extruded aluminum angle fuselage construction )
Old March 5th 06, 07:52 PM posted to rec.aviation.homebuilt
The exposed bike and rider are going to create considerable drag. To
get to reasonable cruise speeds - I'm guessing 100-120 mph or so, to be
enough faster than a bike to make it worthwhile - it's going to take a
bigger engine than you think.
It's going to be difficult to adequately belt the pilot down (in?) if
he's sitting on a bike.
No IFR, of course, no space for a panel
Dealing with 100+ mph wind blast for an extended period is going to be
taxing.
No reason you can't have a conventional side stick for aileron and
elevator. Yes, you have enough degrees of freedom in handlebars, 2
twist grips and 2 grip levers. But it would mean a lot of training to
unlearn regular aircraft controls.
It comes down to defining your mission. If your goal is to ride your
motorcycle through the air, you may have a reasonable answer. If it's
to fly somewhere with your motorcycle, I'd lean toward a more
conventional airplane that can hoist or ramp a motorcycle inside, and
unload at the other end.
Old March 5th 06, 08:18 PM posted to rec.aviation.homebuilt
wrote)
Why not revisit the Wright Brothers design - a fitted belt, around the rear
tire, up to a big slow turning pusher prop?
Just a thought...
Montblack
I wonder if gyroscopic(?) forces (with the rear spinning tire) would make
banking difficult? :-)
Old March 5th 06, 08:37 PM posted to rec.aviation.homebuilt
("Montblack" wrote)
rear tire, up to a big slow turning pusher prop?
Or:
....a second sprocket or hub - don't use the rear tire.
....a belt/pulley setup, off the engine - like an old tractor.
Just a thought...
Montblack
Old March 5th 06, 08:39 PM posted to rec.aviation.homebuilt
Thanks
-Adam
Usually, the flying car concept is offered as a new, improved way to
commute. Wouldn't it be easier to have an airplane that isn't compromised
with the unnecessary weight of a motorcycle and position a motorcycle at
each end of the commute?
The compromises of a flying car (or motorcycle) tend to more or less ruin
the craft's utility in one or both roles.
Old March 5th 06, 08:40 PM posted to rec.aviation.homebuilt
"Richard Riley" wrote in message
Snip-------
If it's
A single engine airplane specifically designed to haul a medium weight
motorcycle at good cruise speeds seems a very worthwhile thing. I wonder
why someone hasn't done it.
Bill Daniels
Old March 6th 06, 06:21 AM posted to rec.aviation.homebuilt
In article .com,
Montblack wrote:
wrote)
Just a thought...
BMW had (has?) a shaft driven motorcycle. You could
have a PTO and clutch that would select between the
drive shaft and a belt or chain drive for the prop.
Ever seen a shaft-driven bicycle? There were some about 100 years ago.
Old March 6th 06, 08:20 AM posted to rec.aviation.homebuilt
("Kyle Boatright" wrote)
[snip]
Wouldn't it be easier to have an airplane that isn't compromised with the
unnecessary weight of a motorcycle and position a motorcycle at each end
of the commute?
That's great for Point (A) to Point (B) travel ...forgetting, for a moment,
about the other (24) letters in the alphabet.
Montblack
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
terminology questions: turtledeck? cantilever wing? Ric Home Built 2 September 13th 05 10:39 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 08:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 04:04 PM
