Back up Flight Recorder for US contests
Old April 6th 06, 12:28 AM posted to rec.aviation.soaring
Default Back up Flight Recorder for US contests
I need help interpreting the 2006 rules regarding the above subject.
The rules do not discuss a back up flight recorder.
What options exist for a backup flight recorder that would be
excepted across the board in US contests for none team use.
Udo
PS. If you have a used GPS Nav 20 or 25 let me know.
Old April 6th 06, 01:59 AM posted to rec.aviation.soaring
Hi Udo
Is a backup needed? My GPS Nav has worked flawlessly for the last 10
years {:))
What options exist for a backup flight recorder that would be excepted
Udo
Old April 6th 06, 02:13 AM posted to rec.aviation.soaring
Hello Charles,
mine has worked flawlessly for many years as well.
I would like to have a second Nav / PDA system.
It should generates a flight log that is acceptable
as a back up for contests in the US.
If you like to know, I had a bit of a hick up in Florida with
my PDA I got it resolved in time but I wish, at that moment, I had
a second set-up. Having invested time and money for a contest
it could ruin an otherwise pleasant outing.
Udo
Hi Udo
years {:))
Udo
Old April 6th 06, 04:25 AM posted to rec.aviation.soaring
Udo,
I had the same issue as you and couldn't justify spending another
$800-$1000 for a "backup" (equal to one family vacation). So, I went
and bought a Garmin GPSMap76 for $130 on eBay. Best investment I ever
made! Advantages:
- Self-contained logger and display. So, no interface issues,
cables, software conflicts, etc.
- If you spend the time to get familiar with it, you can input a task,
set arrival radius, etc. It's easy to zoom in our out, and you can add
various maps to the background if you want to get fancy.
- Compact, so easy to mount. I molded a small cradle from plexiglas
and used the camera mounting holes provided in my LS8. RAM makes all
sorts of very slick mounts if you want something more elegant.
- It has been 100% reliable over the last year. In fact, it has been
so much easier to use when submitting OLC claims (given the recent VALI
issues) that it has been my primary logger for that purpose.
- As Marc cautions below, you need to be aware of the altitude
differences between barometric altitude and GPS altitude on anything
other than an ISA day. I have mine set up to show GPS Altitude on the
pointer screen itself; that way you have access to it in case you find
your Cambridge has gone down.
- You will need to have SeeYou, G72Win, or an equivalent program to
download and create an IGC format file.
- I use 2 rechargable 2500mAh rechargeable AA batteries which are good
for at least 6 hours each. I just swap 2 pairs each day during the
contest and I'm all set. I keep a spare pair of alkalines in the side
pouch just in case.
Hope this works for you.
Erik Mann (P3)
Old April 6th 06, 05:48 AM posted to rec.aviation.soaring
made!
That works very well for me, too. Get the GPSMAP 76-S, with the
barometric sensor and compass. A few bucks more but better altitude
readings.
Advantages:
pouch just in case.
Erik Mann (P3)
Old April 6th 06, 06:14 AM posted to rec.aviation.soaring
readings.
Careful, the pressure sensor equipped Garmins don't necessarily provide
"better" or "more accurate" altitude, at best, they provide "smoother"
altitude readings. Plus, if you get the calibration mode wrong, they
can give very poor results...
Marc
Old April 6th 06, 02:25 AM posted to rec.aviation.soaring
Udo
You can use an off-the-shelf GPS unit (handheld, or track log capable
Bluetooth device) that records GPS altitude as a primary or backup
recorder, at any SSA sanctioned contest. You'll need to avoid cutting
the start altitude too close, to allow for the fact that GPS altitude
may be as much as 500 feet higher than indicated pressure altitude, due
to normal pressure altimetry errors.
Marc
Old April 6th 06, 04:57 AM posted to rec.aviation.soaring
You might check with Tom Stowers...he had one at High
Country Soaring for several years.
Old April 6th 06, 04:27 PM posted to rec.aviation.soaring
Please look at my website "used" pages
http://www.wingsandwheels.com/page8.htm and
http://www.wingsandwheels.com/page20.htm
I typically have a used CAI loggers and sometimes other types taken on
trade.
tim
Wings & Wheels
"Udo Rumpf" wrote in message
Udo
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
Student Drop-Out Rates...why? Jay Honeck Piloting 254 September 1st 05 01:00 AM
ramifications of new TSA rules on all non-US and US citizen pilots paul k. sanchez Piloting 19 September 28th 04 12:49 AM
