Updated IGC-approval for the EW Avionics microRecorder
Old February 27th 07, 12:06 AM posted to rec.aviation.soaring
Ian Strachan
Default Updated IGC-approval for the EW Avionics microRecorder
I am pleased to announce that an update to the IGC-approval document
for
the EW Avionics microRecorder is now on the IGC GNSS web site. This
update adds an SD card facility for the downloading of flight data.
To find the IGC-approval document, go to:
http://www.fai.org/gliding/gnss
and click the link under "List of IGC-approved FRs"
This will give you a PDF document that lists all IGC-approved
recorders
and their manufacturers as well as other information about GPS
recording.
The links to all current IGC-approval documents are in the
last column of the table that lists the 33 types of IGC-approved
recorders.
Find the line in the table for the EW microRecorder and click the link
in the
last column which shows the issue date as 26 February 2007.
Ian Strachan
Chairman IGC GNSS Flight Recorder Approval Committee
Update to IGC-approval of EW microRecorder Ian Strachan Soaring 0 November 21st 06 07:24 AM
IGC-approval issued for EW Avionics microRecorder Ian Strachan Soaring 0 June 11th 06 06:52 PM
Updated IGC-approval documents for some types of GPS Recorders Ian Strachan Soaring 1 April 13th 04 04:23 AM
New and updated IGC-approval documents for GNSS Flight Recorders Ian Strachan Soaring 0 November 25th 03 06:55 PM
Updated IGC approval documents for Cambridge GNSS flight recorders Ian Strachan Soaring 0 August 27th 03 06:28 PM
