An Old Carrier Aircraft Mystery Solved?
Old May 30th 07, 09:54 PM posted to rec.aviation.military.naval
W. D. Allen
Default An Old Carrier Aircraft Mystery Solved?
On 23 December, 1956, an FJ-3 Fury fighter plane was launched from the U. S.
S. Shangri La while operating south of Japan. The FJ-3 did not follow
normal departure procedures - instead it continued flight with it's landing
gear and flaps still down while slowly banking left as the plane turned
almost opposite to the ships course abeam to it's port-side. The plane
continued rolling left until it dropped into the ocean and sunk. Both plane
and pilot were lost. No pilot communications were reported. No firm
conclusion was ever arrived at as to the cause of the loss. Some years later
a former squadron mate was cycling the wing fold mechanism on an FJ-3 when
he noticed something that might explain the loss of his friend years
earlier.
The FJ-3 had two wing folding/spreading controls: the first, mounted on the
right forward instrument panel, was a handle hinged at the bottom for
locking (handle up vertically and locked in place) and unlocking (handle
unlocked and down to horizontal) the ailerons before folding or spreading
the wings to prevented aileron control linkage damage. Most importantly,
this handle had a thumb operated detent button on the left side to lock the
handle itself in the closed position when the wings are fully spread and
locked and the ailerons were free to be used. Also connected to this same
handle were metal flags, painted red, located in each wing indicating wings
locked when the flag is down with no red showing and unlocked when up with
red showing. Behind that handle was a small left/right lever used to
actually fold or spread the wings.
Years later in ground exercising the wing spread and lock procedure of an
FJ-3 the former squadron mate found a peculiarity. Because of linkage
tolerances it was possible for the flags to disappear, indicting wings
locked, when the outer pilot's control handle detent button was NOT yet
seated in the lock position. The significance of that detent being not
seated, together with aileron linkage slack, was that while the wings
locking pins might be fully seated with the flags not showing red, the
ailerons linkage could still be locked - meaning no aileron controls for the
pilot. A pilot "stirring the cockpit" with the joystick prior to launch
would know he had no aileron authority and "down" his aircraft before being
catapulted. On the other hand, a nervous pilot overloaded with pre-launch
check-off procedures and checking only hi swing flags could end up on the
catapult not realizing he had no aileron control. Whereas post-catapult
flight with no aileron controls might just be possible using the rudder to
counter roll tendency the likelihood of even recognizing the lack of aileron
control until too far committed in roll is more likely. Being at relatively
low speed and low altitude in an uncontrollable FJ-3 a pilot could not
expect to survive a cockpit ejection. Low, slow, in a roll, and off the
catapult with no ailerons means he has just run out of options!
Unfortunately, this peculiarity of the FJ-3 was not known at the time that
unfortunate squadron mate flew his last flight. Also unfortunate was that
the accident occurred just days before Christmas, 1956. Hopefully the Navy
waited to notify the pilot's wife and two children until after they had
enjoyed their Christmas, such as it was with daddy not being with them.
For want of a nail, a shoe was lost
For want of a shoe, a horse was lost
For want of a horse, a rider was lost
For want of a rider, a message was lost
For want of a message, a battle was lost
For want of a battle, a kingdom was lost
All for want of a nail
- George Herbert (1593-1632)
Old May 31st 07, 07:57 AM posted to rec.aviation.military.naval
Mike Kanze
Sounds like as good an explanation as any.
The A-6 had a similar external visual indicator (red flags near the wingfolds), and the wingfold lever was located between the pilot and B/N. AFAIK, there were never any linkage engagement issues with the A-6 wingfold like those you describe for the FJ.
Part of good A-6 crew coordination was deciding who would control the lever under what circumstances - some pilots and B/Ns preferred the B/N handle this, allowing the pilot more attention to the yellowshirt's directions.
Mike Kanze
"Political correctness is the doctrine holding that it is entirely possible to pick up a turd by the clean end."
- Anonymous
"W. D. Allen" wrote in message ...
earlier.
Old June 18th 07, 07:07 AM posted to rec.aviation.military.naval
RapidRonnie
"W. D. Allen" wrote in om...
earlier.
If I understand correctly at least one FJ Fury flies today. Has its
operator been notified of this? Maybe someone reading this knows the
guy.
GA on Aircraft Carrier??? Cockpit Colin Piloting 12 January 21st 05 04:17 PM
Mystery Solved Jeff Franks Piloting 4 August 31st 04 06:02 AM
Mystery of missing virgins, solved JJ Sinclair Soaring 18 March 30th 04 11:51 PM
Mystery aircraft: Help needed Andreas Parsch Military Aviation 7 February 4th 04 11:10 AM
Pan AM 747 mystery solved! Alan White Simulators 1 July 18th 03 07:29 PM
