DIY Gascolator
Old November 16th 08, 09:09 PM posted to rec.aviation.homebuilt
Default DIY Gascolator
To All:
The Gascolator dates from the days of the Model T Ford. Back in those
days the fuel tank was located in the cowl, just forward of the
windscreen -- which was plate glass. The filler was located on the
cowl. The float-type quantity gauge was located in the instrument
cluster. The system did not have a pump; it relied on gravity to feed
fuel to the carburetor. There was a strainer inside of the tank which
prevented LARGE particles of debris from reaching the carb, whilst the
Gascolator served to trap any WATER that happened to get into the
tank. The Gascolator's bowl was made of glass, allowing you to SEE
any water that may have been trapped. Your job was to loosen the
clamp securing the glass bowl and empty it, thus ridding the system of
water.
When I was a kid every junk yard worthy of the name had a windrow of
early Fords -- T's as well as A's -- which managed to survive the lust
for scrap iron generated by World War II. These junked Fords provided
a host of parts for anyone crazy enough to build their own airplane.
One of those parts was the Gascolator.
Alas, Gascolators have become rather rare birds in today's world.
Fortunately, they are relatively easy to make.
The first thing you'll need is the receiver; the glass or metal
'sediment bowl' through which all of the engine's fuel must pass.
Back then, it was always glass. Nowadays it's usually metal but
either one will work. (If you want to stick with Ford parts for some
reason, give a call to Mike's "A" Ford-able Parts in Maysville,
Georgia. Good people. See their on-line catalog at www.mikes-afordable.com
The receiver needs a mouth 1-3/4" to 2" in diameter. This could be a
baby food jar or similar. It could also be a section of chromed drain
pipe from under the bathroom sink. Or kitchen sink. (But don't get
caught!) The tricky bit here is to close the open end of the pipe,
which you can do by spinning or by hammering or whatever. If you
chose to hammer the end closed you'll have to anneal the brass pipe
several times during the process so keep in mind that quenching non-
ferrous metals SOFTENS the metal, whereas quenching ferrous metals
hardens them. To anneal your brass pipe simply raise it to a red heat
then swirl it around in a bucket of water. That makes it good to go
for another round of hammering.
Once you've hammered or spun the brass pipe to a single point, you may
seal it with a dot of hard solder.
Whatever you settle upon as your receiver, the next step is to find an
O-ring that matches its diameter. This is pretty easy since most real
auto-parts stores (as opposed to un-real, chain-store type FLAPS) will
have TRAYS of O-rings in every size imaginable. Simply find one that
fits.
The body of your Gascolator needs to be about 3/4" thick (ie, 19mm).
You need that much depth because the body will receive several
fittings that use NPT -- pipe threads. (I'm assuming you have
suitable pipe-thread reamers and taps.)
Although NPT is pretty strong you do NOT want to depend upon a pipe-
threaded fitting to SUPPORT the Gascolator, which will be mounted on
your firewall -- and which must be the LOWEST point in your fuel
system. (Why lowest? So that the water will go there.)
A circular groove is cut into the Gascolator body to accept the O-
ring. The receiver then presses against the O-ring with sufficient
pressure to form a gasoline-tight seal. The pressure comes from a
simple screw affair and a pair of straps that connect to the body of
the Gascolator then pass under the receiver. At the point where the
straps pass under the receiver you must fabricate a plate or other
fixture that is threaded 1/4-20, the bolt provided with some means of
safety-wiring. The head of the bolt is usually fitted with a cross-
bar or wheel to make it easy to unscrew by hand.
On the body of the Gascolator you must provide for one inlet (ie, from
the fuel tank) and two outlets. One of the outlets is to the carb and
is fitted with a sintered bronze muffler from a pneumatic-tool. The
other outlet goes to the primer. All of the drillings in the body of
the Gascolator are 3/16" or larger in diameter and are tapped 1/8"
NPT.
You must also provide some means of attaching and supporting the
Gascolator to the firewall.
The body of the Gascolator may be made from a billet of aluminum or
frm a casting..
I will post an illustrated version of this message to my blog as soon
as I am able to do so.
Old November 16th 08, 09:29 PM posted to rec.aviation.homebuilt
jan olieslagers[_2_]
schreef:
To All:
water.
fits.
NPT.
frm a casting..
Bob, thanks for explaining!
So a gascolator is simply a water separator, OK?
I thought it a lot more complicated -
an easy way to get lost in explanations.
Questions:
-) why does one want a water separator apart from the fuel filter?
In my house's heating, there's a filter cartridge in a glass bowl,
and when I ran the tank dry it sure filled up with water (and smudge).
Isn't it sufficient to mount the fuel filter at the lowest point,
and have a water drain valve on its bottom?
-) is there a finer fuel filter in the Ford A & T, or only the
strainer in the tank? Do you recommend a finer filter, either
between tank and gascolator or between gascolator and carb?
-) why the "sintered bronze muffler" on the exit?
actually, what is a "sintered bronze muffler"?
Does it serve as a filter, perhaps?
-) for the receiver body, I should like clear plastic:
less delicate than glass, but unlike metal, it shows what's happening.
There must surely be clear plastics that resist gasoline?
Sincere apologies if these questions are stupid, or were answered
before. And my gratitude for sharing your knowledge!
Old November 16th 08, 10:27 PM posted to rec.aviation.homebuilt
Ed
On Sun, 16 Nov 2008 12:09:06 -0800 (PST), "
To All:
water.
fits.
NPT.
frm a casting..
Actually, the tank was located behind the dash on the model A, The
model T tank was under the front seat. That is why you had to back up
a hill since the drop wasn't sufficient to gravity feed the carb. on a
hill.
Old November 16th 08, 11:12 PM posted to rec.aviation.homebuilt
Anthony W
Old rototillers and garden tractors used to have these too. I'm not
sure where you'd find one of them these days...
Tony
Old November 16th 08, 11:45 PM posted to rec.aviation.homebuilt
More or less, yes.
It IS a lot more complicated. The body of the Gascolator provides a
place to attach various fuel lines. On a simple airplane -- one
lacking even a fuel pump -- the Gascolator offers more convenience
than other methods..
I give up. Why?
In fact, most Gascolators DO provide for fuel filtering as well as
water separation.
Yes, a water drain at the lowest point should prevent water from
reaching the burner. But I am not familiar with the oil burners used
by many Americans. Based on your description I suspect there is an
auxiliary circuit open to the atmosphere that is only allowed to drain
when the main tank is completely empty, but that is only a guess.
No; not as a stock item. As I recall, the strainer fits down inside
the filler neck and there were a number of after-market filters that
offered a finer mesh than the stock filter.
That's two questions :-)
The Gascolator has a finer filter than the one in the filler neck.
You should not need any additional filtering.
Because the 'exit' of the Gascolator is the inlet to the carburetor.
A muffler -- the types vary -- is standard equipment for pneumatically-
powered tools, which have an extremely high noise signature. Sintered
bronze mufflers do not corrode nor 'pack-up' like some other types of
mufflers.
See the above.
I'm sure there is but the goal here is to describe a Gascolator that
can be fabricated by the typical homebuilder. As for showing what's
happening, it would ALWAYS show full; there would be nothing to see.
As for plastic vs glass or metal, my personal preference -- and that
of many other homebuilders -- is to keep keep the amount of flammable
materials forward of the firewall to an absolute minimum.
-R.S.Hoover
Old November 17th 08, 02:07 AM posted to rec.aviation.homebuilt
Tim Ward[_1_]
To All:
water.
fits.
NPT.
frm a casting..
There is a thingummy available from Briggs and Stratton called a "glass bowl
cutoff".
It sits directly under the fuel tank, and has a glass sediment bowl of
approximately the size you describe. It has one input, one output, and a
shutoff valve on... I think it's the input.
The glass bowl cutoff, the replacement glass bowls, and a picture of both of
them can be seen at:
http://www.briggs.learnsmallenginere...BScarbkits.htm
The assembly is $10.75, the glass bowl replacement is $5.75.
On the one on my rototiller, the glass bowl is about 1 1/2" in diameter, and
the gasket, instead of an O-ring, is flat, and molded onto fine brass
screen.
The lip on the glass bowl is flat enough that using an O-ring instead
shouldn't be a problem, though.
Tim Ward
Old November 17th 08, 02:25 AM posted to rec.aviation.homebuilt
On Nov 16, 5:07*pm, "Tim Ward" wrote:
To All:
Dear Tim,
This sounds like the sediment/strainer I got from Northern Hydraulic
and tested for maximum flow rate. It was a little bit shy.
-Bob Hoover
cu toff".
approximately the size you describe. *It has one input, one output, and a
them can be seen at:http://www.briggs.learnsmallenginere...BScarbkits.htm
screen.
Tim Ward
Old November 17th 08, 03:04 AM posted to rec.aviation.homebuilt
Morgans[_2_]
wrote
Dear Tim,
I would think so. g
I have a 1942 Gibson tractor that has a (book rated) 9 HP Wisconsin engine,
and it has one like that. Not enough for a VW engine, I would not think.
The reason I said it was book rated at 9 HP, was because it has a 3 inch
piston, with a 3 1/4" stroke.
What a striker. I love that engine. A modern one with that displacement in
the typical over square configuration is rated at around 20 HP, I think. I
would be very surprised if a modern would come close to working as hard, for
pushing dirt and pulling stuff, as that tractor.
I gotta get that thing back in good running condition. I have a sneaking
feeling that we might get some snow, this year.
Old November 17th 08, 03:36 AM posted to rec.aviation.homebuilt
Anthony W
cutoff".
Wouldn't it be easier to drill out one of these for better flow rather
than making one from scratch?
Tony
Old November 17th 08, 04:41 AM posted to rec.aviation.homebuilt
Ernest Christley
Tony
It'll cost ya' $11 to find out.
Is this a safe location for a Gascolator? flybynightkarmarepair Home Built 0 May 29th 07 02:38 AM
Gascolator Jonathan Goodish Owning 10 September 29th 05 02:02 PM
