Is anyone running XC soar and have it hooked up to an intelligent
vario, such as the Tasman with the Flight Pack module? I am thinking about upgrading at some point and getting the Tasman/FP module package and sending the data to my PDA for the various functions XC soar would use, and was wondering if anyone has done that, and how it works. I've got the latest versions of XC soar on the iPAQ 3850 PDA, which I fly with, and also on an iPAQ 310 that I use while sitting in the Barkaflier. I thought I would actually use the iPAQ 310 in the air, but am not sure yet, especially when considering adding outside vario info.......there is talk of bluetooth interface to achieve this, but am not sure I want to go there. Pretty happy with the old PDA for now. Thanks, Brad |
Hi Brad,
I offer cables that will allow an RS-232 serial connection between a Tasman FP10 and V1000 variometer and the iPAQ 310. The 310 only accepts data at 9600 baud or higher, so you'd need a GPS that can output data at 9600 baud or higher. A BlueTooth connection is also possible, but I recommend the cable solution. Best Regards, Paul Remde Cumulus Soaring, Inc. "Brad" wrote in message ... Is anyone running XC soar and have it hooked up to an intelligent vario, such as the Tasman with the Flight Pack module? I am thinking about upgrading at some point and getting the Tasman/FP module package and sending the data to my PDA for the various functions XC soar would use, and was wondering if anyone has done that, and how it works. I've got the latest versions of XC soar on the iPAQ 3850 PDA, which I fly with, and also on an iPAQ 310 that I use while sitting in the Barkaflier. I thought I would actually use the iPAQ 310 in the air, but am not sure yet, especially when considering adding outside vario info.......there is talk of bluetooth interface to achieve this, but am not sure I want to go there. Pretty happy with the old PDA for now. Thanks, Brad |
![]() "Paul Remde" wrote in message ... Hi Brad, I offer cables that will allow an RS-232 serial connection between a Tasman FP10 and V1000 variometer and the iPAQ 310. The 310 only accepts data at 9600 baud or higher, so you'd need a GPS that can output data at 9600 baud or higher. A BlueTooth connection is also possible, but I recommend the cable solution. Best Regards, Paul Remde Cumulus Soaring, Inc. "Brad" wrote in message ... Is anyone running XC soar and have it hooked up to an intelligent vario, such as the Tasman with the Flight Pack module? I am thinking about upgrading at some point and getting the Tasman/FP module package and sending the data to my PDA for the various functions XC soar would use, and was wondering if anyone has done that, and how it works. I've got the latest versions of XC soar on the iPAQ 3850 PDA, which I fly with, and also on an iPAQ 310 that I use while sitting in the Barkaflier. I thought I would actually use the iPAQ 310 in the air, but am not sure yet, especially when considering adding outside vario info.......there is talk of bluetooth interface to achieve this, but am not sure I want to go there. Pretty happy with the old PDA for now. Thanks, Brad Hi Paul, Since the iPAQ 310 has a built in GPS, I wouldn't need to add an external GPS, right? I did see the 310 has the 9600 baud rate, does the Tasman need to have a certain baud rate too? Thanks, Brad Hi Brad, If XC Soar can receive data on 2 comm ports (which is unlikely, but maybe possible) then you could receive the Tasman data on one com port and the internal GPS on a different comm. port. However, I have never seen any soaring software that was able to receive data on 2 comm ports at the same time. So I'm pretty certain that an external GPS is required. Any GPS that can send data at 9600 baud would be fine. An EW microRecorder is a good option if you want an IGC approved logger. The FP10 defaults to 4800 baud, but a software utility can be used to change the baud rate to 9600 baud or 19200 baud. Best Regards, Paul Remde Cumulus Soaring, Inc. Serving the soaring community http://www.cumulus-soaring.com 1-952-445-9033 |
![]() "Paul Remde" ha scritto nel messaggio ... If XC Soar can receive data on 2 comm ports (which is unlikely, but maybe possible) then you could receive the Tasman data on one com port and the internal GPS on a different comm. port. However, I have never seen any soaring software that was able to receive data on 2 comm ports at the same time. So I'm pretty certain that an external GPS is required. Any GPS that can send data at 9600 baud would be fine. An EW microRecorder is a good option if you want an IGC approved logger. XCS does indeed support TWO different serial ports as input for gps and external varios or other instruments. Actually many people with the HP 310 series (310, 312, 314, 316 ) are using it. Paolo |
FAA ADS-B Out NPRM needs your input | Ron Lee[_2_] | Piloting | 24 | November 27th 07 04:06 AM |
Input jack on a Baron | Greg Farris | Piloting | 12 | November 25th 06 05:09 AM |
Bose X with audio input.. | Dan | Piloting | 3 | November 9th 06 06:30 PM |
GTX 327 serial input? | weebee | Owning | 1 | December 19th 05 01:04 AM |
Aux. Audio Input | Eugene Wendland | Home Built | 1 | April 5th 04 04:16 AM |
