FAA ADS-B Out NPRM needs your input
Old October 21st 07, 07:48 PM posted to rec.aviation.piloting
Ron Lee[_2_]
Default FAA ADS-B Out NPRM needs your input
Many pilots, if they have heard about ADS-B, think that it means free
weather.
IT DOES NOT
This proposal will mandate potentially costly avionics that in my
analysis provide little or nothing to the GA pilot. You will still
have to keep your Mode C transponder.
You won't get free weather.
You won't get traffic alerts in your cockpit.
You only get to pay thousands (TBD but possibly over $7000 per plane)
for something that only helps the airlines.
The official link to read the NPRM and submit comments is he
http://tinyurl.com/2raefd
My analysis (which is still in work and may not be done until November
or later) is he
http://tinyurl.com/2wem8j
My suggestion is that you read what I have written then read the NPRM.
If you agree with my analysis, please reply to the FAA and AOPA. You
may use any or all of my reply but I strongly suggest changing it to
reflect your views (possibly shorter).
Ron Lee
Old October 21st 07, 09:17 PM posted to rec.aviation.piloting
S Green
"Ron Lee" wrote in message
weather.
IT DOES NOT
or later) is he
Ron Lee
Shall we still write to the FAA if we don't agree with your analysis?
Old October 22nd 07, 01:26 AM posted to rec.aviation.piloting
Ron Lee[_2_]
Ron Lee
You are free to disagree with anything I wrote. I would be surprised
if you did not concur with my views if you read everything provided.
Ron Lee
Old October 24th 07, 07:45 PM posted to rec.aviation.piloting
Angelo Campanella[_2_]
Around 1985, I attended an RTCA meeting where this transponder mode was
discussed. (S-mode?). What has happened since, other than 20 years ago
positional (GPS) information was not available, but barometeric,
velocity and heading were, along with acft identification. My
recollection was that the degree of acft identification was a sticky
point then, and that transponder signal clutter could be intense in
termial areas.
My attitude then and now was and is that, I would not stand in the way
of pormulgating it gradually (is 20+ years gradual enough?). Clearly,
the data processing and sensors are now all in place.
So, other than the possibly that the FAA can make terribly inefficient
actions while wasting huge amounts of taxpayer money in the process if
we don't maintain a close rein on the matter, what are the negative
aspects of this specific NPRM?
Angelo Campanella (Flying IFR since 1965).
Old November 2nd 07, 02:58 PM posted to rec.aviation.piloting
Ron Lee[_2_]
Read the NPRM. Read my response. Does the mandate of a multi thousand
dollar piece of equipment that provides little or no benefit to you
matter?
The FAA needs more PRIMARY radars...not reliance on ADS-B or
transponders.
Ron Lee
Old November 24th 07, 01:15 AM posted to rec.aviation.piloting
Ron Lee[_2_]
Read my writeup. One biggie is having to pay lots of money for no
benefit (I don't consider the SAR related possible benefit as worth
anything to me).
Ron Lee
Old November 24th 07, 04:38 AM posted to rec.aviation.piloting
Morgans[_2_]
anything to me).
What was the link for your write-up, again, please?
One comment off the top of my head, (before I have read more of your info
about the issue) is that if the feds want us to all change to a GPS
reporting type of traffic surveillance and control, is that they should pay
to put the technology in each plane.
A box could be contracted (to be designed and built) that would have a GPS
in it linked to the reporting transmitter, in a all in one unit. To save
cost and complexity, it would not need to have any display of the GPS data
available to the pilot.
The government is going to be doing a similar type of purchase of technology
for the public to make the change from standard definition TV to high
definition TV, by allowing all households to get two coupons free of charge
to be exchanged for a set top box that changed high definition signals to
standard definition signal for the old TV's.
FAA ADS-B Out NPRM needs to be drastically changed Ron Lee[_2_] Piloting 14 October 9th 07 08:23 PM
nprm for private aviation [email protected] Piloting 4 September 11th 07 07:14 PM
DC ADIZ NPRM Blueskies Piloting 3 August 17th 05 04:22 PM
DC ADIZ NPRM Blueskies Home Built 0 August 15th 05 11:41 PM
NPRM proposing to update the AC 43.13 2A - [email protected] Home Built 0 January 3rd 05 03:56 PM
