Fuel Drip Containment
Old October 25th 03, 07:33 PM
Sven
Default Fuel Drip Containment
Hi Jim,
I have seen people hang an empty plastic oil bottle on the fuel vent to
catch the dripping fuel on Cessnas. Have you tried this? It shouldn't be too
much of a fire hazard and will save your hangar floor. Just make sure that
you drain the bottle regularly because the angle it sits on the vent, it
won't hold a whole quart of fuel. Using a GATT jar or some other filter, you
can reuse the fuel.
"Jim Weir" wrote in message
Snarly Charlie, the 182, has the classic "Cessna drip" from the fuel vent
when
the tanks are filled and the hangar gets warm. I've tried everything I
know to
stop it, but all I can do with all the mechanical fixes is slow it down.
Old October 25th 03, 07:51 PM
Montblack
("Jim Weir" wrote)
Another thought is to put some sort of oven pan with a mat of some sort
that
would let the gasoline evaporate slowly from under the mat. The problem
is
finding a nonflammable mat that gasoline will not attack chemically.
Pet store (or a garage sale) buy a lizard heating rock. $10.
Put the flat rock UNDER, maybe a large brownie pan, and insulate around the
rock.
We used a 2" thick piece of rigid pink insulation and cut out the shape of
the rock. Rock fit flush in the hole. Then we also put another piece of
rigid pink UNDER the rock, So now the rock/insulation layer is sandwiched
between a solid piece of 2" insulation on the bottom and the container on
top.
The rock should be upside-down in the insulation hole to mate up with the
bottom of whatever you're using as a drip pan.
Run a couple of bands of duct tape around the pink edges for that "finished"
look and you're all set.
For us it was an aquarium for the lizard (anole) brought home from school at
the end of the year, by the 3rd grade niece. Kept that sucker alive for 2
years.
http://www.tpwd.state.tx.us/nature/w...iles/anole.htm
You know, any small heating pad would work in this setup. I had a waterbed
heater that I kept for years after the bed had been thrown away. Used the
pad all the time. Gave the pad to my sister a while back, haven't seen it
since.
Or ...a can of yellow foam insulation is $2.95 - $3.95 ...and it's fun to
play with. Wear latex gloves because that stuff turns your hands black,
before it hardens.
Whatever you choose, just separate the heating thing from the thermal mass
pan thing.
Good luck.
Montblack
"Styled by the laws of nature.............Concorde"
Old October 26th 03, 07:05 PM
Jim Weir
Sorry, no cigar. Putting a source of ignition (110 ac) in proximity to a fuel
source isn't where I wanted to be.
But thanks for trying.
"Montblack"
-("Jim Weir" wrote)
- Another thought is to put some sort of oven pan with a mat of some sort
-that
- would let the gasoline evaporate slowly from under the mat. The problem
-is
- finding a nonflammable mat that gasoline will not attack chemically.
-Pet store (or a garage sale) buy a lizard heating rock. $10.
-Put the flat rock UNDER, maybe a large brownie pan, and insulate around the
-rock.
-We used a 2" thick piece of rigid pink insulation and cut out the shape of
-the rock. Rock fit flush in the hole. Then we also put another piece of
-rigid pink UNDER the rock, So now the rock/insulation layer is sandwiched
-between a solid piece of 2" insulation on the bottom and the container on
-top.
-The rock should be upside-down in the insulation hole to mate up with the
-bottom of whatever you're using as a drip pan.
-Run a couple of bands of duct tape around the pink edges for that "finished"
-look and you're all set.
-For us it was an aquarium for the lizard (anole) brought home from school at
-the end of the year, by the 3rd grade niece. Kept that sucker alive for 2
-years.
-http://www.tpwd.state.tx.us/nature/w...iles/anole.htm
-You know, any small heating pad would work in this setup. I had a waterbed
-heater that I kept for years after the bed had been thrown away. Used the
-pad all the time. Gave the pad to my sister a while back, haven't seen it
-since.
-Or ...a can of yellow foam insulation is $2.95 - $3.95 ...and it's fun to
-play with. Wear latex gloves because that stuff turns your hands black,
-before it hardens.
-Whatever you choose, just separate the heating thing from the thermal mass
-pan thing.
-Good luck.
http://www.rst-engr.com
Old October 27th 03, 06:04 PM
Montblack
("Jim Weir" wrote)
fuel
One more try:
BTW, in the future, please leave out any references to cigars -
you, you, you ...politician :-)
Take the (fully sealed) lizard rock and make a 1x3 frame around it, with a
bottom board. Box should be about the size of a Cheerios box. Pour cement
around "lizard rock". (Doesn't matter what side of the lizard rock is up,
now that the whole thing is encased in cement)
In the side of the cement Cheerios box (with the "lizard rock cocooned
inside) insert a 6" piece of PVC pipe. The PVC pipe will have the power cord
running through it. Goop up the end of the PVC pipe to seal up the cord.
Might be easier to do this before the cement pour. g
Now you have a re-hearing thermal mass to set your brownie pan on top of.
Those lizard rocks get pretty warm, but not hot-hot. Do the normal (super)
insulation thing for the cement thermal mass. Don't forget the duct tape.
Whole thing should weigh as much as an old IBM Selectric typewriter. Heck,
use an old typewriter cart. High wing right?
This all assumes warming up the gasoline, by spreading it out in an old
turkey roasting pan with a thermal mass under it, will hasten evaporation.
Original brownie pan idea lacked capacity - just in case.
"Is it safe?" - Marathon Man.
Montblack
Old October 27th 03, 06:41 PM
Ron Natalie
"Montblack" wrote in message ...
pan thing.
It isn't clear to me that evaporating the fuel is what you want to do. A coffee can
of liquid fuel is a whole lot better than a enclosed space full of fuel vapor.
Old October 27th 03, 10:17 PM
Ross Richardson
Plus the EPA is gona get ya for air pollution.
pan thing.
Old October 27th 03, 10:28 PM
Montblack
("Ron Natalie" wrote)
coffee can
vapor.
You're probably right.
There just aren't many airplane projects that start by mixing up a small bag
of Quick-Crete.
Montblack
Old October 25th 03, 08:46 PM
clare @ snyder.on .ca
On Sat, 25 Oct 2003 18:33:46 GMT, "Sven"
Hi Jim,
can reuse the fuel.
when
know to
The RIGHT way to solve the problem is to go flying!!!!
Old October 26th 03, 07:06 PM
Jim Weir
And the WRONG thing is to be dicking around trying to fuel an aircraft at
0-dark-30 in the morning.
-The RIGHT way to solve the problem is to go flying!!!!
Old October 26th 03, 03:48 AM
C J Campbell
Don't fill your plane before putting it away?
We turn the fuel valve off or turn it to left or right tank -- this seems to
mitigate the problem considerably, though I am not sure why it does this.
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
Protecting fiberglass from fuel & oil Paul Lee Home Built 2 September 18th 03 06:14 AM
Fuel pressure Problems smf Home Built 3 September 7th 03 08:25 PM
Question ~ Does fuel injection add weight? Barnyard BOb -- Home Built 0 July 6th 03 09:47 PM
