I had a failed jack that I took apart to see why it was not
maintaining the extended position. In my case the ramp would slowly lower back to collapsed postition, which besides annoying, can be a danger to the fuselage. Turns out that it was the synthetic plunger on the main piston leaking. So even under pressure the oil would seep past the plunger and the piston slowly looses position till it eventually collapses. The culprit does not seem to be any of the various ball-bearings in the base of the jack. Anybody know if a replacement plunger could be obtained. I am sure its much cheaper than a new jack. |
On Oct 28, 1:53*pm, db_sonic wrote:
I had a failed jack that I took apart to see why it was not maintaining the extended position. In my case the ramp would slowly lower back to collapsed postition, which besides annoying, can be a danger to the fuselage. *Turns out that it was the synthetic plunger on the main piston leaking. *So even under pressure the oil would seep past the plunger and the piston slowly looses position till it eventually collapses. *The culprit does not seem to be any of the various ball-bearings in the base of the jack. Anybody know if a replacement plunger could be obtained. *I am sure its much cheaper than a new jack. Darren Most people just replace the jack ~$80/$90 or so and not waste time messing around. Unfortuantely Cobra uses junk jacks and will likely fail in a few years again. Williams Soaring should have them. Darryl |
Yep, actually I already did. But before doing that I had attempted
to fix it and was disappointed when I couldn't figure it out. Till last night when a cracked it open. Incidentally took a monkey wrench and a propane torch to get the top off and I really had to lean into it. You might be right though that any replacement part would just fail again... Just seems wrong though to toss a 5 lb chunk of metal into the garbage can. Darren Most people just replace the jack ~$80/$90 or so and not waste time messing around. Unfortuantely Cobra uses junk jacks and will likely fail in a few years again. Williams Soaring should have them. Darryl |
On Oct 28, 5:52*pm, db_sonic wrote:
Yep, actually I already did. * But before doing that I had attempted to fix it and was disappointed when I couldn't figure it out. *Till last night when a cracked it open. *Incidentally took a monkey wrench and a propane torch to get the top off and I really had to lean into it. You might be right though that any replacement part would just fail again... *Just seems wrong though to toss a 5 lb chunk of metal into the garbage can. Darren Most people just replace the jack ~$80/$90 or so and not waste time messing around. Unfortuantely Cobra uses junk jacks and will likely fail in a few years again. Williams Soaring should have them. Darryl If you figure it out, you could have a nice overhaul biz... |
On Oct 28, 4:18*pm, Dave Nadler wrote:
On Oct 28, 5:52*pm, db_sonic wrote: Yep, actually I already did. * But before doing that I had attempted to fix it and was disappointed when I couldn't figure it out. *Till last night when a cracked it open. *Incidentally took a monkey wrench and a propane torch to get the top off and I really had to lean into it. You might be right though that any replacement part would just fail again... *Just seems wrong though to toss a 5 lb chunk of metal into the garbage can. Darren Most people just replace the jack ~$80/$90 or so and not waste time messing around. Unfortuantely Cobra uses junk jacks and will likely fail in a few years again. Williams Soaring should have them. Darryl If you figure it out, you could have a nice overhaul biz...- Hide quoted text - - Show quoted text - Changed the subject to something more apropos ; ). |
On Oct 28, 4:54*pm, db_sonic wrote:
On Oct 28, 4:18*pm, Dave Nadler wrote: On Oct 28, 5:52*pm, db_sonic wrote: Yep, actually I already did. * But before doing that I had attempted to fix it and was disappointed when I couldn't figure it out. *Till last night when a cracked it open. *Incidentally took a monkey wrench and a propane torch to get the top off and I really had to lean into it. You might be right though that any replacement part would just fail again... *Just seems wrong though to toss a 5 lb chunk of metal into the garbage can. Darren Most people just replace the jack ~$80/$90 or so and not waste time messing around. Unfortuantely Cobra uses junk jacks and will likely fail in a few years again. Williams Soaring should have them. Darryl If you figure it out, you could have a nice overhaul biz...- Hide quoted text - - Show quoted text - Changed the subject to something more apropos ; ).- Hide quoted text - - Show quoted text - Good move. I think there's a club member here with the standard cobra bleed-down problem. If he replaces his, I'll try to talk him out of the old one. It's just a hydraulic jack, and I have more than one that are over 30 years old and never leaked a bit, so I'm pretty sure it's possible. I have access to a machine shop. Who knows? I might make a fortune selling 1 or 2 rebuilt jacks a year!! |
On Oct 28, 2:53*pm, db_sonic wrote:
I had a failed jack that I took apart to see why it was not maintaining the extended position. In my case the ramp would slowly lower back to collapsed postition, which besides annoying, can be a danger to the fuselage. *Turns out that it was the synthetic plunger on the main piston leaking. *So even under pressure the oil would seep past the plunger and the piston slowly looses position till it eventually collapses. *The culprit does not seem to be any of the various ball-bearings in the base of the jack. Anybody know if a replacement plunger could be obtained. *I am sure its much cheaper than a new jack. I took a look at a Cobra jack for a friend. It's not actually a "bottle jack" but more likely a replacement part for a "floor jack" - those long handled things on caster wheels you see in auto shops. The giveaway is the trunnions on the hydraulic cylinder which are not seen on mere bottle jacks. In the car jack application, "leak down" isn't an issue since it just has to hold long enough to put jack stands under the car after which the jack is lowered and removed. That makes me think that you will never get it to stop leaking. Scissor jacks are terrible since they have the least mechanical advantage when you need it most. The best solution I've seen is scissor jacks with the crank handle replaced with a large nut which the owner turns with a humongous slow speed cordless electric wrench bought specifically for the purpose. Bill D |
"bildan" wrote in message ... On Oct 28, 2:53 pm, db_sonic wrote: I had a failed jack that I took apart to see why it was not maintaining the extended position. In my case the ramp would slowly lower back to collapsed postition, which besides annoying, can be a danger to the fuselage. Turns out that it was the synthetic plunger on the main piston leaking. So even under pressure the oil would seep past the plunger and the piston slowly looses position till it eventually collapses. The culprit does not seem to be any of the various ball-bearings in the base of the jack. Anybody know if a replacement plunger could be obtained. I am sure its much cheaper than a new jack. I took a look at a Cobra jack for a friend. It's not actually a "bottle jack" but more likely a replacement part for a "floor jack" - those long handled things on caster wheels you see in auto shops. The giveaway is the trunnions on the hydraulic cylinder which are not seen on mere bottle jacks. In the car jack application, "leak down" isn't an issue since it just has to hold long enough to put jack stands under the car after which the jack is lowered and removed. That makes me think that you will never get it to stop leaking. Scissor jacks are terrible since they have the least mechanical advantage when you need it most. The best solution I've seen is scissor jacks with the crank handle replaced with a large nut which the owner turns with a humongous slow speed cordless electric wrench bought specifically for the purpose. Bill D About a year ago, I started a similar thread. I got three responses to an offer to do rebuilds. I couldn't do it for a lot less than a "Cobra" replacement. The hydraulic in a cheap car jack is similar, but not exacly the same as a "Cobra". A custom bushing or two would do the conversion. To make it worse, Cobra has changed the dimensions at least once. So--if you can do your own machining, you can easily replace the hydraulic. You also could "clean up" the innards of the "Cobra" jack and it would work better. But compared to other stuff in gliding, the "Cobra" replacement is so cheap that it may not be worth the effort. Hartley Falbaum |
I had a failed jack that I took apart to see why it was not maintaining the extended position. In my case the ramp would slowly lower back to collapsed postition, which besides annoying, can be a danger to the fuselage. *Turns out that it was the synthetic plunger on the main piston leaking. *So even under pressure the oil would seep past the plunger and the piston slowly looses position till it eventually collapses. *The culprit does not seem to be any of the various ball-bearings in the base of the jack. Anybody know if a replacement plunger could be obtained. *I am sure its much cheaper than a new jack. Unscrew (remove) the bleed down screw dig out the old oring replace with a new one. Worked for me. |
| Thread Tools | |
| Display Modes | |
| Cobra hydraulic bottle jacks - where to buy? | [email protected] | Soaring | 20 | August 17th 17 07:15 AM |
| WTB: Cobra Trailer Ramp Jack - US | Gary Emerson | Soaring | 1 | June 21st 09 02:34 AM |
| Cobra Hydraulic Jack | HL Falbaum[_2_] | Soaring | 4 | December 12th 08 09:45 PM |
| Cobra Hydraulic Jack - oil replentishment | Gary Emerson | Soaring | 4 | March 25th 05 07:47 PM |
| Cobra jack warning | Andy Durbin | Soaring | 8 | June 30th 04 03:32 AM |
