Cobra Hydraulic Jack - oil replentishment
Old March 23rd 05, 10:01 PM
Gary Emerson
Default Cobra Hydraulic Jack - oil replentishment
What am I looking for as far as where to fill the hydraulic ramp jack w/
more oil?
Old March 24th 05, 02:38 AM
bumper
You would be looking for a little rubber plug, probably painted red, on the
body of the jack about 2/3rds the way up from the base. Some jacks use a
screw to plug this fill/level hole, but the one on my Cobra uses the
aforementioned plug.
If you have never changed the hydraulic fluid in your jack, you might want
to do this. When I did mine after just one season, I found the oil
contaminated with metallic particles. This appears to be from rough
machining, as a very old US made Craftsman jack I checked had clean oil
after some 35 years of use!
To flush your jack, remove it from the trailer, remove plug, hold jack with
fill hole down, open release screw and manually extend and retract ram to
expel the old oil. Put a small amount of new oil in and cycle jack, drain
and then refill with new oil.
I didn't feel that the above, though easy enough, would remove all the
contamination from mine, so disassembled it for a thorough cleaning.
BTW, I think the contamination I found may be responsible for so many of
these jacks leaking etc.
all the best,
bumper
"Gary Emerson" wrote in message
more oil?
Old March 25th 05, 04:04 PM
HL Falbaum
My Cobra hyd ramp jack was leaking , so I did thte following
Now I *really* need help.
Disassembled the mechanism and extracted the jack, cleaned all.
Removed the pipe thread fitting holding the "pump" and removed the plunger
(actually it just came out before I expected it.
Removed the nearby screw-"o-ring" and spring, and the rubber plug on the
fill body.
Removed the dirty oil
Reasembled with clean hydraulic jack oil.
tested--ram goes up & down as expected while actuating the "pump" by hand
with a 3/8" bolt through the "saddle".
Installed the foot operating lever--operated lever by hand--does not work!
Same stroke on plunger as hand operation that does work! Removed lever--it
works by hand! It did work once while I was describing the problem to my
wife, to demonstrate what was taking so long! Then, after installation in
the ramp,-no luck!
Reassembled the entire mechanism, ramp, scissors etc--doesn't work at all.
Drained & refilled via body hole with jack upright and ram closed.
Same problem--works by direct hand actuation-but with lever installed-no
luck.
Side loads by direct actuation, no problem. Stroke length varied, no
problem. The lever does not change the stroke length or produce side loads
much, as the saddle is a fairly loose fit.,
I'm stumped--anyone out there with experience?
Thanks in advance.
Hartley Falbaum
ASW27B "KF" USA
"bumper" wrote in message
the body of the jack about 2/3rds the way up from the base. Some jacks use
a screw to plug this fill/level hole, but the one on my Cobra uses the
with fill hole down, open release screw and manually extend and retract
ram to expel the old oil. Put a small amount of new oil in and cycle jack,
drain and then refill with new oil.
all the best,
bumper
more oil?
Old March 25th 05, 05:00 PM
Gary Evans
I assume that you are testing it in the same operating
position for if not it could be a trapped air problem.
If it works by hand but not with the lever that suggests
that you are no getting the exact same plunger stroke.
If that's not the problem perhaps someone put a hex
on the pump when you were not around. You may want
to check with your wife.
following
cleaned all.
Removed the pipe thread fitting holding the 'pump'
Removed the nearby screw-'o-ring' and spring, and the
rubber plug on the
fill body.
the 'pump' by hand
with a 3/8' bolt through the 'saddle'.
the problem to my
the ramp,-no luck!
work at all.
and ram closed.
lever installed-no
luck.
length varied, no
Thanks in advance.
Hartley Falbaum
ASW27B 'KF' USA
'bumper' wrote in message
painted red, on
I found the oil
to be from rough
plug, hold jack
extend and retract
thorough cleaning.
for so many of
all the best,
bumper
'Gary Emerson' wrote in message
more oil?
Old March 25th 05, 06:47 PM
HL Falbaum
Same position. Stroke is close to 1" by lever, so duplicated that and the
portion of the range.
She wouldn't do that !
Thanks for trying.
Hartley Falbaum
"Gary Evans" wrote in message
following
cleaned all.
rubber plug on the
fill body.
the 'pump' by hand
the problem to my
the ramp,-no luck!
work at all.
and ram closed.
lever installed-no
luck.
length varied, no
Thanks in advance.
Hartley Falbaum
ASW27B 'KF' USA
COBRA Skin Trailer Protector - Commercial John Seaborn Soaring 0 July 20th 04 04:38 PM
Cobra jack warning Andy Durbin Soaring 8 June 30th 04 02:32 AM
FS: 1990 Cracker Jack "War Time Airplanes" Minis 6-Card (CJR-3) Set J.R. Sinclair Aviation Marketplace 0 April 12th 04 05:57 AM
Servicing Cobra Hydraulic foot pumps mike pitoniak Soaring 13 March 9th 04 04:04 PM
COBRA TALON, COBRA SPOT Allen Thomson Military Aviation 0 December 9th 03 06:44 PM
