FAA Operating Limitations
Old January 26th 10, 01:35 PM posted to rec.aviation.soaring
rlovinggood
Default FAA Operating Limitations
My glider has an old Experimental Operating Limitations letter from
the FAA, dated 16 APR 1980. Among other things, it states:
"No person may exceed the designer's or builder's recommended limits
as follows: Maximum gross weight 1,100 lbs..."
Eleven Hundred Pounds? Where did that come from??? My aircraft
manual states the maximum weight of 752 lbs for my LS1-d. NOT ELEVEN
HUNDRED POUNDS!
The Operating Limitations continue,
"...And maximum airspeed in smooth air 121 knots..."
Back to the aircraft manual, the limit is 130 knots.
Why would the FAA, back in 1980, have different limits than the
manufacturer? How could they come up with a weight that is almost 1.5
times greater than what LS said? At 752 lbs, my wing loading (using
9.75 sq meters = 104.95 sq. ft) is 7.2 lbs/sq.ft. and at 1,100 lbs,
the loading is 10.5 lbs/sq. ft.
Don't worry, I don't fly with water and I'm not going over 752 lbs.
Just wondering if anyone might know where the FAA found their numbers.
Thanks,
Ray Lovinggood
Carrboro, North Carolina, USA
Old January 26th 10, 02:47 PM posted to rec.aviation.soaring
jcarlyle
Just guessing, but I'd bet that the FAA got its numbers from the
manufacturer. When I was looking for moment arms for my ASW-19, the
best source turned out to be the TCDS and not the flight manual. An
email to Schleicher confirmed that the FAA numbers were correct for
the 19.
Is there any chance that your Operating Limitations letter was
"adopted" from a ketter fir an earlier model of the LS1? Would the max
gross and the Vne you quoted be correct for the first version?
-John
HUNDRED POUNDS!
Thanks,
Ray Lovinggood
Old January 26th 10, 03:33 PM posted to rec.aviation.soaring
the FAA, dated 16 APR 1980. *Among other things, it states:
as follows: *Maximum gross weight 1,100 lbs..."
Eleven Hundred Pounds? *Where did that come from??? *My aircraft
manual states the maximum weight of 752 lbs for my LS1-d. *NOT ELEVEN
HUNDRED POUNDS!
manufacturer? *How could they come up with a weight that is almost 1.5
times greater than what LS said? *At 752 lbs, my wing loading (using
Thanks,
Ray Lovinggood
Sometimes- back in the "olden days", the FAA would issue limitations
on Ex gliders that were not the same as the manufacturer's info.That's
why they were called experimental. Gross weight was one that could be
"flexible". A lower max speed would be consistent with higher gross
weight. It is quite possible that whoever got the original
airworthiness and associated limitations asked for different limits
and it was granted.
I had an ASW-20C with limitations of 1157 lb gross(like 20B) just by
asking for it.
Ah the good old days!
UH
Old January 26th 10, 04:10 PM posted to rec.aviation.soaring
rlovinggood
why they were called experimental. *Gross weight was one that could be
and it was granted.
asking for it.
UH- Hide quoted text -
- Show quoted text -
Thanks UH. That, unfortunately, makes sense. Some years back, pre-
DG intervention, I did ask LS what the max weight and CG limits were
for my specific glider and they responded with the same information as
already printed in the aircraft's manual. Not the 1,100 lbs, but the
752 lbs.
So it's possible that a previous owner could have done this? I'll
have to check the logbook and see who owned it at that time.
It's sort of odd that I'm limited to 752 lbs, per LS and 121 knots per
the FAA. A "mix and match" duo of limitations.
Oh, as far as I'm concerned, flying this glider is "the good old
days." :-)
Ray Lovinggood
Old January 26th 10, 04:52 PM posted to rec.aviation.soaring
Tony[_5_]
and it was granted.
asking for it.
Thanks UH. *That, unfortunately, makes sense. *Some years back, pre-
already printed in the aircraft's manual. *Not the 1,100 lbs, but the
752 lbs.
So it's possible that a previous owner could have done this? *I'll
the FAA. *A "mix and match" duo of limitations.
days." *:-)
Ray Lovinggood
you could always contact the FSDO and ask to get your operating
limitations changed to reflect the manufacturers recommendations. of
course that would lead to a complete re-issue of the op lims which
could change your situation with regard to a program letter and stuff
like that.
Old January 26th 10, 05:23 PM posted to rec.aviation.soaring
mattm[_2_]
and it was granted.
asking for it.
752 lbs.
days." *:-)
Ray Lovinggood
like that.
Ray, considering the origin of that glider I'm not surprised that
there's a high
weight limit on it. An historical question for everyone: was there a
wing loading
limit in standard class in world championships in the early 1970's? I
know there
was one for US contests until recently, but this wing loading is
higher than that.
-- Matt
Old January 26th 10, 05:36 PM posted to rec.aviation.soaring
rlovinggood
and it was granted.
asking for it.
752 lbs.
days." *:-)
Ray Lovinggood
like that.- Hide quoted text -
Tony,
No. Don't want to go there! I'll keep the letter as is. With this
particular Operating Limitations, there is NO program letter
required. That's the one beauty of this old letter, of which I have
multiple copies, both soft and hard, scattered around, in case I loose
one...
Ray
Old January 26th 10, 06:44 PM posted to rec.aviation.soaring
JS
ABSOLUTELY NOT!
NEVER replace any "good old days" Operating Limitations. The new
ones (or more likely tens) will create vast sucking sounds. They are
designed to keep you well grounded.
like that.
Old January 26th 10, 06:49 PM posted to rec.aviation.soaring
Tony[_5_]
On Jan 26, 12:44*pm, JS wrote:
ABSOLUTELY NOT!
* NEVER replace any "good old days" Operating Limitations. The new
true in most cases, especially with non amatuer built gliders that
require a program letter and stuff. however on my experimental-amatuer
built Cherokee II I was actually able to gain more flexibilty in terms
of required instrumentation by getting new operating limitations
issued last spring. everything else was the same except the very
friendly folks at the Wichita FSDO issued them using the standard
wording that all experimental amatuer built aircraft should get, that
is there are no instrument requirements as long as you are flying Day
VFR. The last guy had given it operating limitations which restrained
it to the 91.209 (I think) AIRPLANE instrument requirements.
But based on what I've seen on RAS and what I've heard I bet I'm about
the only glider guy in the country who has called the FSDO asking them
to give me new operating limitations.
Old January 27th 10, 07:01 PM posted to rec.aviation.soaring
Westbender
Ray,
My Operating Limitations were also published in 1980. It has no
reference at all to weight or speed limits. Although it does say "this
aircraft shall not be operated for glider towing or parachute jumping
operations". I don't mind giving up the parachute jumping part. )
Dave
HUNDRED POUNDS!
Thanks,
Ray Lovinggood
Gyrocopter requirements and limitations Andy L Piloting 1 October 28th 08 04:25 PM
Registering a Warbird with the FAA (Experimental Operating Limitations) [email protected] Owning 21 October 11th 05 01:52 AM
changing operating limitations pittss1c Home Built 46 August 22nd 05 04:28 AM
Limitations of Lemon Pledge Jay Honeck Owning 36 May 6th 04 08:44 PM
regs re flying outside the limitations of a plane...? Ron Natalie Piloting 0 July 9th 03 04:12 PM
