This doesn't look good for our sport. It seems that the Cirrus hit
the towline and the towplane and Cirrus went down despite the ballistic chute on the Cirrus. The glider released and landed safely. But guess where the blame will lay.... http://www.associatedcontent.com/art...all_plane.html This may be the last straw for gliders having mandatory transponders.... |
A transponder in the glider would not have averted this accident.. the news
media is taking the opportunity to again report inaccurate or half the information. The glider was on tow, within apx 200ft of his tow plane, The Cirrus TIS system if used would not have 200ft accuracy. Sad news for the tow pilot, and the Cirrus pilots. "Jody" wrote in message ... This doesn't look good for our sport. It seems that the Cirrus hit the towline and the towplane and Cirrus went down despite the ballistic chute on the Cirrus. The glider released and landed safely. But guess where the blame will lay.... http://www.associatedcontent.com/art...all_plane.html This may be the last straw for gliders having mandatory transponders.... |
On Feb 6, 5:59*pm, "BT" wrote:
A transponder in the glider would not have averted this accident.. the news media is taking the opportunity to again report inaccurate or half the information. The glider was on tow, within apx 200ft of his tow plane, The Cirrus TIS system if used would not have 200ft accuracy. Sad news for the tow pilot, and the Cirrus pilots. "Jody" wrote in message ... This doesn't look good for our sport. *It seems that the Cirrus hit the towline and the towplane and Cirrus went down despite the ballistic chute on the Cirrus. *The glider released and landed safely. *But guess where the blame will lay.... http://www.associatedcontent.com/art...dead_when_glid... This may be the last straw for gliders having mandatory transponders.... Would a transponder in the towplane have made any difference? What class airspace would this have occured in? |
Without knowing the altitude, it is difficult to determine the class of
airspace. The class of airspace would make no difference as both were allowed in the airspace. More than likely there was a transponder in the tow plane. I will surmise that the tow plane would not receive information from the Cirrus transponder. Depending on ATC radar coverage, the Cirrus being of modern avionics, might might might have had information from the tow planes transponder. But again, that depends on ATC radar coverage for TIS reporting. VFR (VMC) condition prevailed. The Cirrus pilot should have yielded the right of way to the tow operation, regardless of transponder information. "Jody" wrote in message ... On Feb 6, 5:59 pm, "BT" wrote: A transponder in the glider would not have averted this accident.. the news media is taking the opportunity to again report inaccurate or half the information. The glider was on tow, within apx 200ft of his tow plane, The Cirrus TIS system if used would not have 200ft accuracy. Sad news for the tow pilot, and the Cirrus pilots. "Jody" wrote in message ... This doesn't look good for our sport. It seems that the Cirrus hit the towline and the towplane and Cirrus went down despite the ballistic chute on the Cirrus. The glider released and landed safely. But guess where the blame will lay.... http://www.associatedcontent.com/art...dead_when_glid... This may be the last straw for gliders having mandatory transponders.... Would a transponder in the towplane have made any difference? What class airspace would this have occured in? |
On Feb 6, 4:11*pm, "BT" wrote:
Without knowing the altitude, it is difficult to determine the class of airspace. The class of airspace would make no difference as both were allowed in the airspace. More than likely there was a transponder in the tow plane. I will surmise that the tow plane would not receive information from the Cirrus transponder. Depending on ATC radar coverage, the Cirrus being of modern avionics, might might might have had information from the tow planes transponder. But again, that depends on ATC radar coverage for TIS reporting. VFR (VMC) condition prevailed. The Cirrus pilot should have yielded the right of way to the tow operation, regardless of transponder information. [snip] Can we hold off on speculation like this. Compounding what I suspect are guesses about what equipment the aircraft might have had you go on to state things about TIS-S, just one possible traffic awareness system. You don't know if the Cirrus had a Mode-S TIS capable transponder and whether that was connected to a TIS capable display? (And was all that turned on?) If and only then does TIS transmission from a Mode-S terminal radar become relevant for traffic display in the Cirrus. Any of the aircraft involved might have had Mode C or Mode S transponders, yes likely the Cirrus had one. Any of the aircraft could also have had PCAS, the Cirrus may have had one of the newer active traffic systems, none of those systems require Mode-S TIS data. I'm just trying to point out there are a large number of possibilities, I personally have no interest in guessing, or actually having the conversation at all right now. Darryl |
FLARM in all three aircraft could have helped prevent the accident.
Not sure if everyone knows about flarm, but it's in use in many European countries and I have been saved by it many times. However, any collision-avoidance instruments are no excuse for the rule of "See and Avoid"!!! My condolences to all involved. Roderick |
On 2/6/2010 9:33 PM, XXL wrote:
FLARM in all three aircraft could have helped prevent the accident. Not sure if everyone knows about flarm, but it's in use in many European countries and I have been saved by it many times. However, any collision-avoidance instruments are no excuse for the rule of "See and Avoid"!!! My condolences to all involved. Roderick FLARM is of no use in the US. What we desperately need are low cost ADS-B transceivers in the same price range as the European FLARM units. The units that MITRE has flying fit this bill. The only obstacle is the lack of FAA certification standards for this kind of low cost device which prevents its commercialization. -- Mike Schumann |
the information. "In order to generate speed and lift, the pilot must be skillful enough to fly the glider at angles up and down and side to side so the glider gains enough speed to remain aloft." Unfortunately the accident is too sad to be able to laugh at this piece of journalism. |
On Feb 6, 4:53*pm, Jody wrote:
This doesn't look good for our sport. *It seems that the Cirrus hit the towline and the towplane and Cirrus went down despite the ballistic chute on the Cirrus. *The glider released and landed safely. *But guess where the blame will lay....http://www.associatedcontent.com/art...dead_when_glid... This may be the last straw for gliders having mandatory transponders.... A tweet from another tow pilot who saw the accident said the SR-22 hit the Pawnee, not the tow rope. One would expect the tug's weak link to fail protecting the tug if the SR-22 had just hit the rope. It appears the collision was in the standard north mountain departure corridor for aero tows. Boulder has a lot of noise sensitive areas where tugs can't go so tow routes are very standardized. Local pilots should be aware of these corridors. There is a lot of transient VFR traffic along the foothills of the Rockies. Pilots want to see the mountains without acutally flying over them - or flying high enough to need oxygen. There's also a class C airport (BJC) that tends to push north-south VFR traffic into a narrow corridor that passes over Boulder. About 15 years ago a member of a transiting RV-4 formation flight hit a Grob 103 on final approach. The G103 landed safely with 10 feet of wing missing. The RV-4 pilot died. |
This "article" is typical web garbage. It's too bad this web site does not
have their disclaimer more predominately shown - "Associated Content ("AC") does not evaluate or guarantee the accuracy of any articles, videos or other posted information on the AC Website (collectively, "AC Content"). All AC Content is provided by AC Contributors in the AC community, like you. None of the content on AC is written, or edited by AC employees. You agree that any use you make of such AC Content is at your own risk and that AC is not responsible for any losses resulting from your reliance on any AC Content on the AC Website. " "Jody" wrote in message ... This doesn't look good for our sport. It seems that the Cirrus hit the towline and the towplane and Cirrus went down despite the ballistic chute on the Cirrus. The glider released and landed safely. But guess where the blame will lay.... http://www.associatedcontent.com/art...all_plane.html This may be the last straw for gliders having mandatory transponders.... |
towplane collides with glider, prop hits wingtip | [email protected] | Soaring | 21 | September 1st 09 07:24 PM |
Airplane collides with ambulance | Don Pyeatt | Aviation Photos | 3 | May 26th 07 07:58 AM |
Glider - Towplane Signals | Mike the Strike | Soaring | 24 | March 26th 05 09:33 PM |
VIDEO: Frecce Tricolore collides over Ramstein - a new head on video | Montblack | Piloting | 1 | February 12th 05 04:03 AM |
Aerodynamic Simulation of Standard Cirrus Glider | Jim Hendrix | Soaring | 13 | November 9th 04 11:38 PM |
