towplane collides with glider, prop hits wingtip
Old August 29th 09, 09:34 PM posted to rec.aviation.soaring
Default towplane collides with glider, prop hits wingtip
Educational video...
Murphy's law at work... one thing leads to another...
towplane: Wilga
glider: LAK
place and time: competition at Pila in Poland, late August 2009
towplane's engine misses than cuts off during takeoff
prop collides with the wingtip
http://picasaweb.google.pl/Wojtekpar...27461393125826
Andre V, CFIG
Old August 30th 09, 01:05 AM posted to rec.aviation.soaring
tstock
towplane: Wilga
glider: LAK
prop collides with the wingtiphttp://picasaweb.google.pl/Wojtekpara/Wypadek#5238527461393125826
Andre V, CFIG
Any clues as to what caused the tow pilot to lose control at the end
of the runway and/or make the hard right turn into the glider's path?
Old August 30th 09, 01:34 AM posted to rec.aviation.soaring
vaughn[_2_]
"tstock" wrote in message
Plain old taildragger-type ground loop?
Another question is what kind of brakes did that glider have? It didn't
seem to have been doing very much stopping.
Vaughn
Old August 30th 09, 02:27 AM posted to rec.aviation.soaring
BT
"vaughn" wrote in message
Vaughn
It appeared to me that the glider had not chance to stop, he's still being
pulled by the rope when the tow plane looses control.
We can see no where that either the tow or glider pilot released the rope.
Gliders in this situation do not have good brakes.
The error is in the tow pilot trying to keep the tow plane on a runway, he
faked left, glider pilot decides to go right and the tow pilot changes
direction.
Old August 30th 09, 10:58 AM posted to rec.aviation.soaring
John Smith
direction.
Wow. You should apply for a job as an accident investigator, your quick
conclutions would save them a lot of money! Not sure the reports would
be very accurate, though.
Old August 30th 09, 02:30 AM posted to rec.aviation.soaring
Frank[_12_]
On Aug 29, 8:34*pm, "vaughn"
Another question is what kind of brakes did that glider have? *It didn't
Vaughn
Lets all be thankful that the wingtip was the only thing chomped up by
the prop - could just as easily have been pilot hamburger!
TA
Old August 30th 09, 04:33 AM posted to rec.aviation.soaring
tstock
Agreed.. and also thankful that this happened on the ground and not at
75 feet.
Old August 30th 09, 03:06 PM posted to rec.aviation.soaring
bildan
towplane: Wilga
glider: LAK
Andre V, CFIG
After watching this a couple of times, it appears to me the tug pilot
intended to turn around and didn't lose control until he saw the
glider about to collide with him - a failure to maintain situational
awareness.
I've had a tug abruptly stop on the runway centerline just after I was
airborne forcing me to fly around him - it's an experience I won't
forget. Just as in flight, the tug pilot should bear left if aborting
takeoff on the runway so the glider has somewhere to go.
The PZL 104 Wilga's Russian Ivchenko/Vedeneyev radial can be a cranky
beast - 'ready to go' and 'ready to quit' sound about the same. The
tug pilot may have been confused by that.
Old August 30th 09, 06:31 PM posted to rec.aviation.soaring
Andy[_10_]
towplane: Wilga
glider: LAK
Andre V, CFIG
awareness.
forget. *Just as in flight, the tug pilot should bear left if aborting
beast - 'ready to go' and 'ready to quit' sound about the same. *The
I had an L-19 run out of gas on me on a downhiill asphalt runway. I
had just broken ground and my LS-3 was full of water. Full spoilers
and flying it onto the runway to engage the LS's powerful Tost drum
brake (not!) was the only thing that kept me out of the swampy
overrun. The tow pilot was smart enough to coast to a stop off the
left edge of the runway, leaving me room to scoot past on the right
edge of the pavement. I ended up with the tow rope wrapped around my
axle but no harm done.
Old August 30th 09, 08:01 PM posted to rec.aviation.soaring
bildan
towplane: Wilga
glider: LAK
Andre V, CFIG
awareness.
edge of the pavement. *I ended up with the tow rope wrapped around my
The "tug out of gas" incidents/accidents are getting old. I can
recall no less than a dozen - which means 10x that number are likely
to have happened. You'd think a pilot who is back on the ground every
10 minutes would have time to check his fuel.
We had an as yet unexplained fuel exhaustion incident this summer -
the pilot glided safely back to the runway. One possibility is that a
fuel drain continued to dribble fuel overboard after the pre-flight.
Please take a second or two to check the drains shut off after taking
a fuel sample.
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
Airplane collides with ambulance Don Pyeatt Aviation Photos 3 May 26th 07 07:58 AM
Glider - Towplane Signals Mike the Strike Soaring 24 March 26th 05 09:33 PM
VIDEO: Frecce Tricolore collides over Ramstein - a new head on video Montblack Piloting 1 February 12th 05 04:03 AM
Auto-rotating helicopter hits towplane during take-off Dave Nadler \YO\ Soaring 8 August 20th 03 04:14 AM
