ILEC SN10 release 2.35
Old March 23rd 10, 11:02 PM posted to rec.aviation.soaring
Dave Nadler
Default ILEC SN10 release 2.35
Hi All - As I got 1005 points Tuesday at the Seniors,
it looks like 2.35 is good to go. The production 2.35
build has now passed flight testing and is generally
available. Details at URL below. Pass the word !
http://www.ilec-gmbh.com/software.htm
Enjoy !
Best Regards, Dave & Juergen
Old March 24th 10, 02:08 PM posted to rec.aviation.soaring
kirk.stant
Enjoy !
Ok, if I understand the AAT "Snap" feature correctly:
I'm on the first leg, and I want to go deep into the area (undercalled
task). I'm off the "black line" task (as drawn from start to first
AAT turnpoint in center of area), just outside the area. I select the
moving map, cursor at lower left, hit ENTER: the AAT turnpoint (small
square drawn on map, line, task data) moves to a point on an extended
line from the start through my current position, half way to the back
of the area. I hit HELP, and get new stats.
This new AAT turnpoint is offset L/R based on my displacement from the
original course line, and the drawn task line on the map to the next
AAT turnpoint center originates from this new turnpoint.
I then continue deeper into the area, past the turnpoint, decide to
turn. Do I go to the Task page and ENTER on the AAT turnpoint to
establish the actual turnpoint (and adjust the map accordingly)?
Sounds interesting; will there be an update to the demo ("simulator")
to let us play with it on the ground?
Love the USB adaptor - makes it soooo easy to load S/W & files and
download igc files - great gizmo!
Cheers,
Kirk
66
Old March 24th 10, 06:10 PM posted to rec.aviation.soaring
Dave Nadler
Enjoy !
task). *I'm off the "black line" task (as drawn from start to first
AAT turnpoint in center of area), just outside the area. *I select the
moving map, cursor at lower left, hit ENTER: *the AAT turnpoint (small
You'll get the stats automagically after the TP is moved.
No need for a second button-push.
Right.
turn. *Do I go to the Task page and ENTER on the AAT turnpoint to
Right, same as always to acknowledge the actual turn.
The code is available in the simulator (demo), but I haven't
published a script that shows the new area task features in action...
Thanks !
Cheers,
Kirk
66
Hope that helps,
Best Regards, Dave
Old March 27th 10, 05:38 PM posted to rec.aviation.soaring
Mike the Strike
I'm having trouble accessing the download - is the web site on line or
is everyone trying to download the new version at the same time?
Mike
Old March 27th 10, 05:53 PM posted to rec.aviation.soaring
Dave Nadler
Mike
Apologies, web.com is having "networking issues they are working
diligently to resolve". ILEC's web site is up, but some downloads
(which are actually coming from my site) are currently offline.
You could join me on hold to India...
Aaarrrgggggg....
Anybody able to recommend a good inexpensive hosting provider ?
Preferably with tech support I never need to call, but answers
the phone in the event I do call ?
Aarrrrgggg.....
Old March 27th 10, 05:55 PM posted to rec.aviation.soaring
Mike the Strike
Mike
Aaarrrgggggg....
Aarrrrgggg.....
I've been using a Hong Kong based supplier - never had an outage.
Mike
ILEC SN10 and SN10B version 2.34 release Dave Nadler Soaring 0 September 21st 09 11:43 PM
ILEC SN10 release 2.33 available Dave Nadler Soaring 2 July 24th 09 02:22 PM
Ilec SN10 question John Ferguson Soaring 3 May 29th 07 05:11 AM
FS - ILEC SN10 and Volkslogger Dave Springford Soaring 0 March 7th 05 12:43 AM
ILEC SN10 upgrade to "B" model Dave Nadler YO Soaring 0 November 23rd 04 12:57 PM
