ILEC SN10 and SN10B version 2.34 release
Old September 22nd 09, 12:43 AM posted to rec.aviation.soaring
Dave Nadler
Default ILEC SN10 and SN10B version 2.34 release
Hi All - We've released the latest updates for the
ILEC SN10B and SN10. Installation programs
(for DOS and Windows) can be downloaded he
http://www.nadler.com/sn10/ILEC_SN10B_234_setupB.EXE
http://www.nadler.com/sn10/ILEC_SN10_234_setup.EXE
Note these installers do *not* run under 64-bit windows.
For 64-bit windows users, you can manually install the files
in this ZIP in C:\SN10 and set up shortcuts as required:
http://www.nadler.com/sn10/ilec_sn10_latest.zip
The manual for the new ILEC SN10B/SN10 USB adapter
can be found he
http://www.nadler.com/sn10/SN10_USB_...h_20090911.pdf
Have a great fall soaring season,
Best Regards, Dave & Juergen
Notable features of version 2.34 (21-September-2009):
- Dark LCD bug fixed (temperature-contrast adjust bug of Jan 2009)
- USB adapter bug fixes and improvements (progress messages etc)
- Suppress diagnostics which could interfere with PDA/FLARM (USB, NSP)
Notable features of version 2.33 (29-June-2009):
- USB-adapter support for log file save, NDB file load, and
softwareload
- BugFix: serial port now properly initialized on cold-start
- Prevent accidental creation of database points with blank names
- Maximum number of AAT areas increased to 6
- NMEA baud rate selectable (4800 or 19200) for FLARM/PDA support
- 19.2kb NMEA support in SL (software load) and PClink
- "Software Load..." on screen during software update
- Memory map changes for diagnostics (OS stack pool at fixed location)
- Many optimizations for speed and code-size (room for next feature)
ILEC SN10 release 2.33 available Dave Nadler Soaring 2 July 24th 09 03:22 PM
Ilec SN10 question John Ferguson Soaring 3 May 29th 07 06:11 AM
Ilec SN10b screen reflections John Ferguson Soaring 1 June 22nd 05 11:32 PM
FS - ILEC SN10 and Volkslogger Dave Springford Soaring 0 March 7th 05 01:43 AM
ILEC SN10 upgrade to "B" model Dave Nadler YO Soaring 0 November 23rd 04 01:57 PM
