Not really an aviation topic, but at least naval.
Was looking at a book on the Iowa class battleships. Went through the engineering section and saw the design of the engines. A thought came to mind - where does the cooling water come from or are they single pass engines with the steam exhausted overboard. That sounds grossly inefficient and makes more sense to have a closed loop design with cooling water. Is there a set of scoops below the waterline or some type of flush opening below the waterline to draw in seawater for cooling? Or is it all "fresh" water that has been drawn through the evaporators. Is the system similar on any ship? (There, finally a tie into aviation if a carrier uses a similar powerplant) Thanks in advance MAH |
![]() "mah" wrote in message ... Not really an aviation topic, but at least naval. Was looking at a book on the Iowa class battleships. Went through the engineering section and saw the design of the engines. A thought came to mind - where does the cooling water come from or are they single pass engines with the steam exhausted overboard. That sounds grossly inefficient and makes more sense to have a closed loop design with cooling water. Is there a set of scoops below the waterline or some type of flush opening below the waterline to draw in seawater for cooling? Or is it all "fresh" water that has been drawn through the evaporators. Is the system similar on any ship? (There, finally a tie into aviation if a carrier uses a similar powerplant) Thanks in advance MAH My experience was Aviation and it's been a while since I studied the boiler cycle for my Surface Warfare Specialist designation. I did locate this document which gives some details: http://www.chemistry.usna.edu/navapp...0Treatment.pdf and answers some of your questions. Larry AECS (AW/SW/MTS) USN 'in a previous life' |
It has been a long time since I studied a steam plant -like at OCS in 1962,
but there are indeed "condensers" on the bottom of the ship that convart the steam back to water and feed it back to the boiler for re-use. Probably one of our "black shoe" brethren can give us a better details/explanation. tc "mah" wrote in message ... Not really an aviation topic, but at least naval. Was looking at a book on the Iowa class battleships. Went through the engineering section and saw the design of the engines. A thought came to mind - where does the cooling water come from or are they single pass engines with the steam exhausted overboard. That sounds grossly inefficient and makes more sense to have a closed loop design with cooling water. Is there a set of scoops below the waterline or some type of flush opening below the waterline to draw in seawater for cooling? Or is it all "fresh" water that has been drawn through the evaporators. Is the system similar on any ship? (There, finally a tie into aviation if a carrier uses a similar powerplant) Thanks in advance MAH |
"mah" wrote...
Is there a set of scoops below the waterline or some type of flush opening below the waterline to draw in seawater for cooling? Or is it all "fresh" water that has been drawn through the evaporators. Is the system similar on any ship? (There, finally a tie into aviation if a carrier uses a similar powerplant) The "sea chests" or water intakes are on the bottom of the hull. Same for virtually any modern steam-powered ship (including aircraft carriers). How that water is distributed and used differs among ships. |
![]() "mah" wrote in message ... Not really an aviation topic, but at least naval. Was looking at a book on the Iowa class battleships. Went through the engineering section and saw the design of the engines. A thought came to mind - where does the cooling water come from or are they single pass engines with the steam exhausted overboard. That sounds grossly inefficient and makes more sense to have a closed loop design with cooling water. Is there a set of scoops below the waterline or some type of flush opening below the waterline to draw in seawater for cooling? Yes seawater for the condensers is drawn in below the waterline and discharged the same way Or is it all "fresh" water that has been drawn through the evaporators. That would require more throughput than is available Is the system similar on any ship? (There, finally a tie into aviation if a carrier uses a similar powerplant) Pretty much. Even gas turbine and diesel ships need cooling water and nuclear power is just a diiferent way of boiling water. Keith |
keith- Pretty much. Even gas turbine and diesel ships need cooling water
and nuclear power is just a diiferent way of boiling water. BRBR But cooling water for the nukes is a closed system, yes? I know they still take on water to make for drinking and the cats, but for cooling of the nuke power plant, that doesn't go over the side-or does it?? P. C. Chisholm CDR, USN(ret.) Old Phart Phormer Phantom, Turkey, Viper, Scooter and Combat Buckeye Phlyer |
If I recall my Naval science 101 taught by Lt. Tom "Truxton" Calhoon. The steam
plants that we studied were the 600 and 1200 PSI power plants which is what most of the Naval ships use. The steam that is boiled for the boilers is a closed loop system. Nothing is lost other than leaks and a steam leak at 600 or 1200 PSI is a big deal. Like your cars cooling system it is a closed loop system, if stuff leaks out you see the car on the side of the road. Now there are scoops on the bottom of the ships hull, sea chests that are used to help return the steam back to water. In a nuc it is the same, you still need sea water too cool the hot water back to water. Keeping the radioactive stuff on one side and the cool stuff on the other. I think that is how we cased the soviets subs is that they were not clean and had a leak in the system. After Enterprise hit Bishops Rock in 87 the divers brought up pieces of the rock from the sea chests. It isn't uncommon for there to be fish and other things stuck in them and they do sometimes require a diver to clean them out. Sparky |
![]() Elmshoot wrote: If I recall my Naval science 101 taught by Lt. Tom "Truxton" Calhoon. The steam plants that we studied were the 600 and 1200 PSI power plants which is what most of the Naval ships use. The steam that is boiled for the boilers is a closed loop system. Nothing is lost other than leaks and a steam leak at 600 or 1200 PSI is a big deal. Like your cars cooling system it is a closed loop system, if stuff leaks out you see the car on the side of the road. Now there are scoops on the bottom of the ships hull, sea chests that are used to help return the steam back to water. In a nuc it is the same, you still need sea water too cool the hot water back to water. Keeping the radioactive stuff on one side and the cool stuff on the other. I think that is how we cased the soviets subs is that they were not clean and had a leak in the system. After Enterprise hit Bishops Rock in 87 the divers brought up pieces of the rock from the sea chests. It isn't uncommon for there to be fish and other things stuck in them and they do sometimes require a diver to clean them out. Sparky Dead fish, seaweed, mud, trash bags, and a pair of live sharks are just a few things that I've cleaned out of main engine condenser inlets in my time. We were able to keep one of the sharks alive in the engine room for about a week between Alameda and Hawaii using a washtub and fresh sea water from a condenser drain. The one thing that did surprise me was surprised that passing volcanic ash from Mt. Penatubo through the condensers on the Lincoln left them as clean and shiny as they were at Newport News when we christened the ship. Although the ash did erode away the zinc's. ALV |
they do sometimes require a diver to clean them out. ....Or those nice little venomous sea snakes that inhabit the South China Sea. Watching out for these was always a big deal whenever a ship had to put a diver over the side in that part of the world. -- Mike Kanze "The hot dog is the reductio ad absurdum of American eating. The Sicilian in the ditch, though he may never be President, knows better: he puts a slice of onion between his slabs of bread, not a cartridge filled with the sweepings of abattoirs." - H. L. Mencken (1926) Hooray for the start of ballpark franks and Major League Baseball this week! "Elmshoot" wrote in message ... [rest snipped] |
![]() "Mike Kanze" wrote in message ... Hooray for the start of ballpark franks and Major League Baseball this week! We don't have professional baseball here. We have the Colorado Rockies. Tex |
flying into snow showers without deice | Doug Carter | Instrument Flight Rules | 35 | February 7th 05 11:19 AM |
THOMAS MOORER, EX-JOINT CHIEFS CHAIR DIES | Ewe n0 who | Naval Aviation | 4 | February 21st 04 09:01 PM |
THOMAS MOORER, EX-JOINT CHIEFS CHAIR DIES | Ewe n0 who | Military Aviation | 2 | February 12th 04 12:52 AM |
Water Cooled Jet Engines: a possibillity then and now? | The Enlightenment | Military Aviation | 3 | December 18th 03 09:41 AM |
USS Liberty. MTB crewman has credibility. | Steve Richter | Naval Aviation | 2 | July 19th 03 06:38 PM |
