flying into snow showers without deice
Old February 4th 05, 02:25 AM
Doug Carter
Default flying into snow showers without deice
I'm presuming flying IFR in light snow in a Skylane RG with no deice
equipment other that the pitot heat is OK if the temp is low enough to
preclude sticking, perhaps -10c or less.
This comes up as I contemplate flying to Minneapolis early next week.
Just is case there could be other opinions though...
Old February 4th 05, 02:35 AM
Peter R.
I trained for my instrument rating downwind of Lake Ontario, New York
State, during the winter of '02-'03. Most of my 17 or so hours of actual
instrument conditions logged during the training were in moderate to heavy
lake effect snow in temperatures from -2 to -15 degrees C.
Other than a very light, white film on the leading edges, the snow never
stuck to the C172 in any mass to cause concern during these, or any
subsequent flights.
Peter
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
Mike Rapoport
If you can see then you are ok. Even heavy wet snow isn't really a problem.
Sometimes clouds can be "embeded" in the snow and they may contain ice.
MU-2
"Doug Carter" wrote in message
om...
Old February 4th 05, 11:50 AM
Bernd Seitter
From my real life experience: your wings are not the main problem - but the
prop. I had 2 flights in where I had to go through light snow for landing
and always the prop. was "iced" (from the spinner to half of the blades
appr. - thats why the prop heating sits exactly there, if you have it ;-) -
when you get out of the airplane and see it you are scared.
If you have to go missed - I have my doubts that you will be able to get all
the power. Now add some little ice on the wings/frame, more time in light
snow, maybe even divert - I am not going to do that again.
Bernd
Old February 4th 05, 01:16 PM
Peter R.
Were you sure that wasn't from the clouds?
Peter
Old February 4th 05, 03:00 PM
Doug Carter
do you happen to remember what the temperature was?
Old February 4th 05, 04:13 PM
Mike Rapoport
Any ice on your prop came from flying through cloud, not snow. Snow is
already frozen and doesn't stick.
MU-2
"Bernd Seitter" wrote in message
the prop. I had 2 flights in where I had to go through light snow for
landing and always the prop. was "iced" (from the spinner to half of the
blades appr. - thats why the prop heating sits exactly there, if you have
it ;-) - when you get out of the airplane and see it you are scared.
all the power. Now add some little ice on the wings/frame, more time in
light snow, maybe even divert - I am not going to do that again.
Bernd
Old February 4th 05, 07:00 PM
Bernd Seitter
I do not remember the temperatures (but it was not too cold, maybe -5C
Celcius on the ground - the ice did not melt from the prop). The cloud
layers were thin (maybe 2000ft) - both flights happened in southern Germany
during winter time, both alreay after sunset (quite early here in winter
time ;-)
No - I am not sure if the ice came from the clouds. But then I would have
seen more ice pickup in the clouds on the wings, and this was really just
small amount, compared to the "ice block" on the prop.
I have been to similar and more heavy icing conditions, but with an
appropriate equip. aircraft. There you could see the ice pick up very
clearly on the radar-dome under the wing (C210) while flying - on the
leading edge of the wing it is difficult to see (IMHO). On the ground I
could see parts of the wings iced while the prop. was clean as it could be.
Bernd
MU-2
Old February 4th 05, 11:07 PM
Matt Whiting
Wet snow can stick. A snowflake that falls into warm air (above
freezing air) doesn't instantly turn to water. Parts of it may be water
while other parts are frozen. This can stick to the airframe, or,
particularly on certain Cessnas, quickly clog the air intake.
I never had trouble in the 182 below about 25F, but I quickly clogged
the air intake in heavy snow at about 32-34F once.
Matt
Old February 5th 05, 07:03 AM
Mike Rapoport
If it is melting then the temp is above 0Cand the water content isn't
supercooled and it won't stick. It can certainly clog the intake though.
MU-2
"Matt Whiting" wrote in message
Wet snow can stick. A snowflake that falls into warm air (above freezing
air) doesn't instantly turn to water. Parts of it may be water while
other parts are frozen. This can stick to the airframe, or, particularly
I never had trouble in the 182 below about 25F, but I quickly clogged the
Matt
Marske Flying Wing discussion Group mat Redsell Home Built 0 September 19th 04 02:58 PM
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 06:07 PM
Flying Wing Design workshop in july 04 mat Redsell Home Built 1 May 5th 04 02:53 PM
restarting instrument flying Matthew S. Whiting Instrument Flight Rules 13 November 21st 03 02:04 PM
seeking info from NW Ontario/ Upper Midwest Pilots flying intoAtikokan David Megginson Instrument Flight Rules 0 July 9th 03 04:04 PM
