Orienting the Approach.
Old May 31st 10, 11:09 PM posted to rec.aviation.piloting
Brian Whatcott
Default Orienting the Approach.
On transfer from a Class C approach controller to a Class D tower
facility under the umbrella, I got the following direction yesterday
when flying in from the west:
"Fly a right downwind to runway 17L , clear to land."
Got the picture?
What is the first turn direction?
On which runway do you turn final from base?
Brian W
Old June 1st 10, 01:16 AM posted to rec.aviation.piloting
* Got the picture?
Brian W
Wooops, maybe the handoff something got jagged up on where you were in
relation to the airport.
No question about it, I would have gotten a clarification from ATC
before initiating the approach as I can't imagine they wanting you to
cross mid field for 17L
On your last question, you are only cleared for 17L so it's not a
matter of which runway.
150flivver
* Got the picture?
Brian W
Sounds like you'd turn left onto the downwind, turn right base and fly
past 17R to turn final and land on 17L.
Old June 1st 10, 12:30 PM posted to rec.aviation.piloting
Brian Whatcott
Dave Doe wrote:
/snip/
Got the picture?
Brian W
Sounds good to me.
Well, that's what I did, and there was no problem.
In fact the FAA recommended join is 45 degrees to the downwind leg, so a
left turn onto downwind was no issue.
Flying a right pattern across a parallel runway would only happen when
both runways are not in use, obviously.
Regards
Brian W
p.s. As people remark to me all the time: there are only old pilots
left, any more. GenAv is suffering from an emigration of flight schools
to Brazil (!!) would you believe!
Old June 1st 10, 02:24 PM posted to rec.aviation.piloting
Dave Doe
In article , betwys1
@sbcglobal.net says...
Dave Doe wrote:
/snip/
Got the picture?
Brian W
Sounds good to me.
Not at all. It's up to the controllers surely (I assume we're talking
about a towered/controlled field!?!?)
Duncan.
Old June 2nd 10, 12:40 AM posted to rec.aviation.piloting
Brian Whatcott
Dave Doe wrote:
/snip/
Got the picture?
Brian W
Sounds good to me.
This was the situation on Sunday at Wiley Post,(PWA) at Oklahoma City.
I would expect Oke City Approach (at Will Rogers) to vector traffic
appropriately, if PWA 17L & R were both active. But it's the
controllers' call, no doubt!
Brian W
Old June 1st 10, 03:18 PM posted to rec.aviation.piloting
Steven P. McNicoll[_2_]
when both runways are not in use, obviously.
Obviously? Isn't the one you're making the approach to in use?
Old June 2nd 10, 12:43 AM posted to rec.aviation.piloting
Brian Whatcott
Yes indeed, the clearance was to 17L PWA from the west.
17R a shorter runway there, was not in use.
Brian W
Old June 1st 10, 01:37 AM posted to rec.aviation.piloting
Got the picture?
Brian W
I think my response would be along the lines of "WTF do you want me to do?",
although phrased a bit more gentle.
Jim Pennino
Remove .spam.sux to reply.
ILS approach and VOR Alpha Approach video DOCTOR Mary Ellen Hall McIntire Yasay, Ph.D, (Div.) Piloting 3 May 22nd 08 01:52 PM
ILS approach and VOR Alpha Approach video [email protected] Instrument Flight Rules 10 May 22nd 08 02:15 AM
ILS approach and VOR Alpha Approach video [email protected] Piloting 4 May 17th 08 01:19 PM
Garmin 430 rquestion- does the approach always have to be activated via "activate approach"? Terence Wilson Instrument Flight Rules 46 February 18th 08 05:46 PM
Completing the Non-precision approach as a Visual Approach John Clonts Instrument Flight Rules 45 November 20th 03 05:20 AM
