Garmin 430 rquestion- does the approach always have to be activated via "activate approach"?
Old February 16th 08, 05:41 AM posted to rec.aviation.ifr
Terence Wilson
Default Garmin 430 rquestion- does the approach always have to be activated via "activate approach"?
One annoyance of the 430 is that activating an approach will
immediately set a course for the selected IAF (assuming RV not
selected). What I would like to do is append the approach to my
current flightplan so that I can transition en route to the approach
without further programming. But I'm concerned that a loaded,
unactivated approach will cause the 430 not to switch to approach
senstivity. I tried this in the simulator and found that it seems to
work fine, the sensitivity changes 2nm from the FAF and all is well;
but I'm hesistant to start using the method in the A/C.
Can someone else verify that it is ok? What method do you use?
Video clip of an "interesting" final approach & landing Elmo von Thud Aviation Photos 3 October 7th 07 01:54 AM
Friday 072707 in Oshkosh Pt 1 - the Raptor [06/30] - "F22 Flyby approach close 2.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 29th 07 07:36 AM
Friday 072707 in Oshkosh Pt 1 - the Raptor [05/30] - "F22 Flyby approach close 1.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 29th 07 07:36 AM
Has Anyone Used The "Approach Sport Hub Avionics Wiring Systems"? three-eight-hotel Owning 7 June 1st 06 04:28 PM
"End of an era: USN's Tomcats make their final approach before decommissioning" Mike Naval Aviation 15 April 5th 06 04:45 AM
