Cambridge 302 Problem - Help
Old August 7th 10, 04:42 AM posted to rec.aviation.soaring
Leroy Tire
Default Cambridge 302 Problem - Help
Need ideas on Cambridge 302 problem that has cropped up.
Latest F/W with gear warning and PEV.
When applying power, 302 boots and displays F/W screen, shortly after
the display counts down (3,2,1) and the display goes blank and the
needle sits on zero. However the audio of the vario still works. My
PDA still functions and communicates with the 302 with gps information,
I just can't use the 302 display interface to set values or use the
302's vario needle.
The process repeats itself every time it is powered up.
Is this operator error some way or possibly a broken 302?
If someone knows how to resolve this, Thanks in advance!
Wells
--- news://freenews.netfront.net/ - complaints: ---
Old August 7th 10, 04:54 AM posted to rec.aviation.soaring
Darryl Ramm
needle sits on zero. *However the audio of the vario still works. *My
302's vario needle.
Wells
Is the main function/volume knob/press button jammed down?. Take the
knob off the button and/or remove the whole C302 and check you can
feel the button press down cleanly and not jam. If that does not fix
it you have a faulty C302 -- which may just be the main switch
failed. I've seen similar to this just being something fouling the
switch like misaligned holes in the panel, screws coming in from the
edge of the panel and pressing near the C302 switch/knob etc.
Darryl
Old August 8th 10, 05:05 PM posted to rec.aviation.soaring
Leroy Tire
Default Resolved - Cambridge 302 Problem - Help
Resolved...
The PEV button on the panel had gone bad, apparently making contact even
when not pressed. Disconnected the PEV switch and all is good.
Thanks!
needle sits on zero. However the audio of the vario still works. My PDA
still functions and communicates with the 302 with gps information, I
just can't use the 302 display interface to set values or use the 302's
vario needle.
Wells
Cambridge 302 problem..HELP Please Colin Milner Soaring 0 July 20th 09 07:15 PM
Cambridge 302 problem..HELP Please Robert Holliday Soaring 11 June 25th 09 02:15 PM
Cambridge 302 problem..HELP Please Andy[_10_] Soaring 2 June 24th 09 09:21 PM
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 Nathan Whelchel Soaring 4 July 5th 04 11:22 PM
Cambridge 302 problem: "Could not get FAT.(A)" while trying to download flight logs Jason Armistead Soaring 5 July 13th 03 02:36 PM
