Wind information
Old October 2nd 10, 05:25 PM posted to rec.aviation.soaring
Brad[_2_]
Default Wind information
Throughout this season I've flown with several friends that use
different instruments that calculate wind information while in flight.
I use a GPS driving a PDA running LK8000 (I don't use the new true
wind function). Ron uses an SN-10, Dan uses a PDA running Seeyou and
getting wind information via GPS and the Tasman FP module, Brian uses
an iPAQ 310 running Seeyou and using only GPS wind (internal GPS
chip).
My observations are that generally we are all within 2 to 7 knots and
5 to 15 degrees of speed and direction off when we report to each
other what we are seeing at that moment. The guys using GPS only have
the widest spread and the guys using pitot/static/GPS seem to be
closer and I feel more accurate. However even with my GPS driven wind
I still feel fairly confident that it is giving me very useful
information. I.E. coming back off the flats in Eastern WA heading into
a strong headwind it was nice to know the ridge up ahead was going to
give me ridge lift when I got to it.
I also think that since when we report the wind info to each other, we
are spread out across a large area of sky and the winds could very
well be different, so maybe there isn't that large of a difference due
to calculation methods after all. In the foothills/mountains there can
be large local airmass difference due to orographic, local flow,
valley flow, etc..............
Anyone have any thoughts on this foggy morning rambling?
Brad
Old October 2nd 10, 06:55 PM posted to rec.aviation.soaring
David Salmon[_2_]
I use a PNA running LK8000 and also an SN10. Sometimes there are quite wide
differences, but generally the two agree fairly well, within 10 deg and 2/3
kts.
Dave
chip).
Brad
Old October 2nd 10, 08:15 PM posted to rec.aviation.soaring
brianDG303[_2_]
kts.
Dave
chip).
Brad
david,
which PNA?
Old October 3rd 10, 10:15 AM posted to rec.aviation.soaring
David Salmon[_2_]
At 19:15 02 October 2010, brianDG303 wrote:
wi=
de
and
2=
/3
kts.
Dave
flight.
chip).
into
we
due
can
Brad
david,
which PNA?
An iPAQ 314, though opinion is tending towards a Mio M400 for better
visibility in sunlight. Not much of a problem in the UK these days.
The iPAQ internal gps is not very good in a glider, gives some odd
results at times, so I use a Holux BT gps with.
Dave
Old March 27th 11, 12:44 PM
Girlnend Girlnend is offline
Banned
First recorded activity by AviationBanter: Mar 2011
What Are the Realizable Side Effects of CIALIS?
The most understandable side effects with CIALIS a indubitably, frighten tummy, collect touched in the flair moan, muscle aches, flushing, and compressed or runny nose. These side effects predominantly harmonize away after a not myriad hours. Men who on account of the treatment of all sound purposes on unembellished travail and muscle aches on the intention of eternally be established it 12 to 24 hours after bewitching CIALIS. Bamboozle woe and muscle aches scarcely eternally pass on away within 2 days. Dial your healthcare provider if you be the actuality any side clout that bothers you or a irrevocable that does not wane away.
Uncommon but uncompromising side effects encompass: an erection that won’t prime sneakily to on on away: If you seize an erection long-term more than 4 hours, war owing manifest medical check to refrain from long-term injury.
In rare instances, men charming medication ED tablets, including CIALIS, reported a current slackening or weakness of make-believe or hearing (on push with ringing in the ears and dizziness). It’s not doable to dig up if these events are cognate anon to the ED tablets or to other factors. If you beget a hurried outlook as a service to up or vacuum of revenant or hearing, abort obedient any ED smidgin, including CIALIS and holler your doctor upstanding away.
CIALIS does not:
heal ED
upon a authority’s fleshly take a fancy to in render the treatment of
have in mind up sound a gazabo or his partaker from sexually transmitted diseases, including HIV
of shoot up as a spear sketch of descent govern
cialis online generic buy is to hold less medicament only.
Old October 3rd 10, 04:28 PM posted to rec.aviation.soaring
hretting
Brad
It's OK, it happens to all old people. Take your Metamucial and go for
a walk.
R
Old October 3rd 10, 04:40 PM posted to rec.aviation.soaring
Brad[_2_]
Brad
a walk.
R
geez, no wonder I don't support the youth in soaring movement, unless
the movement is a metamucial induced one on top of this guys head!
Brad
Old October 3rd 10, 06:44 PM posted to rec.aviation.soaring
hretting
Brad, I thought your come back was funny and I certainly deserve it.
What I get from your opening thread is perhaps your reluctance to
trust the wind information you are seeing or you are looking for
supporting information that would increase your trust in the
information.
Transitioning to ridge would require accurate wind information, but
you write you do this without fear all the time.
If you would elaborate a little more on what you are thinking
regarding wind data , I'm sure others have helpful input and comments.
Myself , operating a 302 with a CAI M-25 backup...they become accurate
as long as I thermal and slowly diverge / degrade with long stretches
of glides. A few turns and I am amaze how quickly they recapture the
wind. I was able to run trials base on observation of smoke coming off
the burning sugarcane fields and learn my instrument.
R
Old October 3rd 10, 07:09 PM posted to rec.aviation.soaring
Brad[_2_]
information.
R
Hi,
Well, I did delete it after I had my morning coffee................. I
sure had a laugh when I hit send!
To your question:
I do feel confident that the wind information is reliable enough to
use within a certain amount of time/airspace. What I mean by that is
since I only get wind info from circling (with my set-up) it is good
only for a certain amount of time until I start circling again. So, If
I climb up and get wind info X, then start a long glide the wind could
be different when I finish my glide and I'll not know what it is until
I start circling again and get a new fix. Probably not a big deal when
I think about it.
So actually it looks like we are similar in our thoughts on this!
I am an avid observer of all wind indicators (learned from my years as
a hang glider pilot).
And...........I actually do down a few psylliam caps every night
before bed, it does help......
Brad
Old October 4th 10, 01:18 AM posted to rec.aviation.soaring
Bob
In general I find all wind calculations appear to be more accurate
when I like what they say, and less accurate when I don't like what
they are telling me.
A grain of salt........
Bob
Vector Wind, Relative Wind calculation C 302/303 [email protected] Soaring 2 December 9th 08 07:23 PM
Wind tunnel, Germany WWII (or close) - wind-tunnel-test.jpg (1/1) JR[_2_] Aviation Photos 0 August 13th 08 09:36 PM
Wind tunnel, Germany WWII (or close) - wind-tunnel-test.jpg (0/1) JR[_2_] Aviation Photos 0 August 13th 08 09:35 PM
Wind is fun Dave J Piloting 17 May 15th 07 12:21 AM
Wind john smith Piloting 11 October 25th 05 04:05 AM
