Probably been asked before, but I'm too lazy to google it.
Is wind caused by being "pushed" (blown) or "pulled" (sucked)? |
"john smith" wrote in message ... Probably been asked before, but I'm too lazy to google it. Is wind caused by being "pushed" (blown) or "pulled" (sucked)? Yes. |
"Gig 601XL Builder" wr.giacona@coxDOTnet wrote in message news:fRb7f.49178$b65.5026@okepread01... "john smith" wrote in message ... Probably been asked before, but I'm too lazy to google it. Is wind caused by being "pushed" (blown) or "pulled" (sucked)? Yes. Chuckle No fair! You beat me to it! -- Jim in NC |
Both. Air is drawn inward to a low pressure area and then rises, so you
could say that it is being sucked. OTOH, air descending at a high pressure center flows outward, so you could say it is being pushed. Bob Gardner "john smith" wrote in message ... Probably been asked before, but I'm too lazy to google it. Is wind caused by being "pushed" (blown) or "pulled" (sucked)? |
Is it drawn by low pressure or pushed by higher pressure?
I believe this typifies the glass half empty or half full issue. Bob Gardner wrote: Both. Air is drawn inward to a low pressure area and then rises, so you could say that it is being sucked. OTOH, air descending at a high pressure center flows outward, so you could say it is being pushed. Bob Gardner "john smith" wrote in message ... Probably been asked before, but I'm too lazy to google it. Is wind caused by being "pushed" (blown) or "pulled" (sucked)? |
Well, air rises at a low pressure center (that's why the pressure is low).
Nature abhors a vacuum, so air must move in to replace the air that has risen. It's sure not being pushed by an outside force. Conversely, air descends at a high pressure center. It can't continue to descend once it hits the surface, so it moves away, rotating clockwise in the northern hemisphere. In this case, there certainly is a push...by the weight of the descending air. Pretty basic stuff. Bob Gardner "Nick" wrote in message ... Is it drawn by low pressure or pushed by higher pressure? I believe this typifies the glass half empty or half full issue. Bob Gardner wrote: Both. Air is drawn inward to a low pressure area and then rises, so you could say that it is being sucked. OTOH, air descending at a high pressure center flows outward, so you could say it is being pushed. Bob Gardner "john smith" wrote in message ... Probably been asked before, but I'm too lazy to google it. Is wind caused by being "pushed" (blown) or "pulled" (sucked)? |
It is kinetic energy of each molecule that moves the the air. The particles
are just bouncing off other particles in a radom fashion. The low pressure area has fewer molecules to run into (and bounce back towards the higher pressure) so the molecules generally move towards the low pressure. Thus it is the high pressure driving the air. Mike MU-2 "Bob Gardner" wrote in message ... Well, air rises at a low pressure center (that's why the pressure is low). Nature abhors a vacuum, so air must move in to replace the air that has risen. It's sure not being pushed by an outside force. Conversely, air descends at a high pressure center. It can't continue to descend once it hits the surface, so it moves away, rotating clockwise in the northern hemisphere. In this case, there certainly is a push...by the weight of the descending air. Pretty basic stuff. Bob Gardner "Nick" wrote in message ... Is it drawn by low pressure or pushed by higher pressure? I believe this typifies the glass half empty or half full issue. Bob Gardner wrote: Both. Air is drawn inward to a low pressure area and then rises, so you could say that it is being sucked. OTOH, air descending at a high pressure center flows outward, so you could say it is being pushed. Bob Gardner "john smith" wrote in message ... Probably been asked before, but I'm too lazy to google it. Is wind caused by being "pushed" (blown) or "pulled" (sucked)? |
Mike Rapoport wrote:
It is kinetic energy of each molecule that moves the the air. The particles are just bouncing off other particles in a radom fashion. The low pressure area has fewer molecules to run into (and bounce back towards the higher pressure) so the molecules generally move towards the low pressure. Thus it is the high pressure driving the air. But how did you get all those molecules out of the area in order to form the low? Conversely, how did you get all of the molecules together to form the high? Matt |
john smith wrote:
Probably been asked before, but I'm too lazy to google it. Is wind caused by being "pushed" (blown) or "pulled" (sucked)? Yes. Matt |
Beans - I think.
I'm also too lazy to Google it. Tony -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE Probably been asked before, but I'm too lazy to google it. Is wind caused by being "pushed" (blown) or "pulled" (sucked)? |
| Thread Tools | |
| Display Modes | |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
| Outfly the wind | Doug | Piloting | 7 | July 6th 05 04:18 PM |
| "Interesting" wind yesterday | Jay Honeck | Piloting | 36 | March 10th 05 05:36 PM |
| LX4000 wind calculation | AttentionLEcureuil | Soaring | 2 | June 23rd 04 05:33 AM |
