Hi all,
Id like to ask for help here. My Ventus a SN143 right wing ballast is leaking around the ballast valve actuator rod. I've contacted S&H but no response so far. I do not know if a O-ring seal would fit in the small recess. Have anyone in this group experienced this problem? Thanks to everyone |
On Oct 9, 7:21*am, wladkummer76 wrote:
Hi all, Id like to ask for help here. My Ventus a SN143 right wing ballast is leaking around the ballast valve actuator rod. I've contacted S&H but no response so far. I do not know if a O-ring seal would fit in the small recess. Have anyone in this group experienced this problem? Thanks to everyone This is consistent with failure of the bellows that seals this area. M&H will have part and installation information. UH |
On Oct 9, 5:44*am, wrote:
On Oct 9, 7:21*am, wladkummer76 wrote: This is consistent with failure of the bellows that seals this area. M&H will have part and installation information. UH We had a customer ask us to look into his Ventus leak in the springtime. The only access for replacing a bellows is to cut a hole in the wing, which we did. Turns out the bellows was fine. The silly part is the 'never-anticipated-for maintenance' design. The bellows is installed on a brass actuator rod, which has to be disassembled from the inner mount (tip end) with a roll-pin style keeper outboard of the suspension post. The bellows is slipped over some looks-like-typical wing tape lapped around the brass pushrod to size it out and provide a compression seat for the hose clamp which tightens and fixes the bellows rootend in position. Water can leak under/through the tape on the rod. Water could leak through a perforated bellows. Water can also leak through the twenty year old, now rusted, iron sleeve that is set in the root rib, which had become transparent when the brass rod was removed. Can you imagine tapping out the remaining rusty material and machining an inner sleeve of brass material to seat/adhere in the root rib? We feel our leakage was through that iron sleeve, not from the bellows which we pressure checked as sound. Then after dump reassembly, you have a nice 12 inch or so hole to patch in your (carbon) skin, and refinish to match. So a leaky "bellows" is not a small item of consideration in either cost or time. Best wishes, Cindy B www.caracole-soaring.com |
On Oct 9, 4:21*am, wladkummer76 wrote:
Hi all, Id like to ask for help here. My Ventus a SN143 right wing ballast is leaking around the ballast valve actuator rod. I've contacted S&H but no response so far. I do not know if a O-ring seal would fit in the small recess. Have anyone in this group experienced this problem? Thanks to everyone A VERY affordable fix is to simply get some Chapstick and slather / smear it with your finger around where the ballast actuator rod comes out of the wing. A 1/16" layer does nicely. This can be easily done at the same time you are greasing the wing assembly rods. Re-apply a layer of Chapstick each time you assemble on days you plan to fly with water. A little Chapstick also works very nicely to stop any drips emminating from the drain valve in the undersurface of the wing. 19 |
On Oct 9, 4:52*pm, Bob wrote:
On Oct 9, 4:21*am, wladkummer76 wrote: Hi all, Id like to ask for help here. My Ventus a SN143 right wing ballast is leaking around the ballast valve actuator rod. I've contacted S&H but no response so far. I do not know if a O-ring seal would fit in the small recess. Have anyone in this group experienced this problem? Thanks to everyone A VERY affordable fix is to simply get some Chapstick and slather / smear it with your finger around where the ballast actuator rod comes out of the wing. *A 1/16" layer does nicely. *This can be easily done at the same time you are greasing the wing assembly rods. *Re-apply a layer of Chapstick each time you assemble on days you plan to fly with water. *A little Chapstick also works very nicely to stop any drips emminating from the drain valve in the undersurface of the wing. 19 Bee 's wax from the seals used to install toilets also works and is a little more substanial than chapstick. Get a Ace hardware or HomeDepot. Richard www.craggyaero.com |
Same problem on my V2C SN30
I only started to fly with water this season. I noticed water dripping out of the fuselage draining hole just in front of the wheel, after landing. The repair as described by Cindy sounds horrible. Need to try the bee wax next season. Hans Van Weersch |
On Oct 10, 3:13*am, weersch wrote:
Same problem on my V2C SN30 I only started to fly with water this season. I noticed water dripping out of the fuselage draining hole just in front of the wheel, after landing. The repair as described by Cindy sounds horrible. Need to try the bee wax next season. Hans Van Weersch Thanks all for the responses. I use the chapstick hint for sealing the dump valve and I'll try to use it for sealing the actuator rod leak. To Cindy, since I'm in Brazil I unfortunately cannot bring the plane for fixing at Caracole. Do you have any pictures on the fix you have done? The hole was cut on the underside of the wing, right? Do you know the position of the center? |
![]() To Cindy, since I'm in Brazil I unfortunately cannot bring the plane for fixing at Caracole. Do you have any pictures on the fix you have done? The hole was cut on the underside of the wing, right? Do you know the position of the center? Okay - I admit to weak Google skills. Send an email address to me directly and we will see what we can send. I'm at info at caracole-soaring.com Yes, we took a few photos mid-process. No - they didn't tell us where to center the hole. And the hole for access was top side. Thanks for admitting you were geographically awkwardly located to use our professional services...... when a shop goes through a learning curve like that, they don't expect to hand off the info willy-nilly. Generic girly descriptions however, can be freely shared for general education on the aging fleet at large. smile, Cindy B www.caracole-soaring.com |
On Saturday, October 9, 2010 at 1:21:53 PM UTC+2, wladkummer76 wrote:
Hi all, Id like to ask for help here. My Ventus a SN143 right wing ballast is leaking around the ballast valve actuator rod. I've contacted S&H but no response so far. I do not know if a O-ring seal would fit in the small recess. Have anyone in this group experienced this problem? Thanks to everyone Hi, Sorry about causing a reawakening of this old thread. But it so happens, that our plane a Ventus B/16.6 has developed "sort of" the same problem. The bolt to the water ballast valve have simply broken inside the wing. Anyone with pictures or information on how to do the repair? - S.H. Just told me to cut a hole in the top side of the wing, but it sure would be nice with some experience. I can't go to Cindy's place, as I live in Europe. Thanks Mr.T |
I saw similar in a Mini Nimbus after the wings were cut open.Â* All of
the hardware was made of mild steel which, over the years simply rusted away!Â* Very shoddy design, if you ask me.Â* The repairs were accomplished with brass hardware and the wings closed up. There should be plenty of shops in Europe that can handle this kind of repair. Good Luck! On 9/5/2018 12:52 PM, Mr.T wrote: On Saturday, October 9, 2010 at 1:21:53 PM UTC+2, wladkummer76 wrote: Hi all, Id like to ask for help here. My Ventus a SN143 right wing ballast is leaking around the ballast valve actuator rod. I've contacted S&H but no response so far. I do not know if a O-ring seal would fit in the small recess. Have anyone in this group experienced this problem? Thanks to everyone Hi, Sorry about causing a reawakening of this old thread. But it so happens, that our plane a Ventus B/16.6 has developed "sort of" the same problem. The bolt to the water ballast valve have simply broken inside the wing. Anyone with pictures or information on how to do the repair? - S.H. Just told me to cut a hole in the top side of the wing, but it sure would be nice with some experience. I can't go to Cindy's place, as I live in Europe. Thanks Mr.T -- Dan, 5J |
C85 Oil Leak | Dick[_1_] | Owning | 2 | May 2nd 07 11:00 PM |
water ballast leak | Robert Harvey | Soaring | 2 | May 27th 05 03:49 PM |
water ballast leak | Robert Harvey | Soaring | 0 | May 26th 05 10:33 PM |
Oil leak | Gene Seibel | Owning | 10 | January 4th 05 02:57 PM |
Oil leak | mike regish | Piloting | 9 | June 22nd 04 03:46 AM |
