I have a 1966 Cherokee 180 with fixed pitch prop. I have noticed some
oil streaks on the back plate of the prop spinner, apparently seeping out between the prop and flywheel. Anyone have an expereince with this? Is there a plug in the front the hollow (I assume) crankshaft that could be leaking? Is this a common problem? Thanks for any info. -- Gene Seibel Gene & Sue's Aeroplanes - http://pad39a.com/gene/planes.html Because I fly, I envy no one. |
Gene,
This is usually an indication that the front main seal of the engine is leaking. This is the seal at the point where the crankshaft comes out of the crankcase. It is not as bad as it sounds, as long as you get it fixed promptly. If you leave it, it will often get worse quickly. Then you will think it is raining (droplets on the windscreen). Shortly after that... well... how are your off-field landing skills? Gene Hudson CFII, ASC |
I had a couple of seals go bad over 11 years in my Cherokee 140. Both
times the seal itself was blown completely out of its land (there was NO sealing action). Both times we noticed a residue on the inside of the flywheel pulley and a few fine drops on the windshield. I once flew it for 2+ hours in that condition and did not lose a measurable amount of oil. However, I once saw a Warrior that had blown a seal and it was down 3 quarts after a 1 hour instruction flight. Upon shutdown, there was a stream of oil running out of the flywheel and a puddle on the ground. The fix involves removing the prop and stretching a new seal over the crankshaft flange, then glueing it into place. Good Luck, Mike __________________________________________________ _____________________________ Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com The Worlds Uncensored News Source |
On 2 Jan 2005 16:29:32 -0800, "Gene Seibel" wrote:
I have a 1966 Cherokee 180 with fixed pitch prop. I have noticed some oil streaks on the back plate of the prop spinner, apparently seeping out between the prop and flywheel. Anyone have an expereince with this? Is there a plug in the front the hollow (I assume) crankshaft that could be leaking? Is this a common problem? Thanks for any info. As another poster indicated, it may be the forward crankcase seal leaking. If you have a hollow crank, there is indeed a plug smacked into the forward end of it. Depending on your spinner installation, removing the spinner may or may not make this plug (and the oil leak) visible. If you have a solid crank, the inside of the crankshaft will be visible as a machined recess that should have some turning marks visible on the face. If you have a "plug" it is a slighty cupped steel disc, placed into the crank with the cupped side outward, and smacked with a drift to flatten it out and drive the edges outward into the sides of the recess in the crank. Not sure anymore what Lycoming says to seal them with, we useta use hard-setting Permatex. If they leak, you smack them in the center with a bluntly pointed punch, turning the disc inside-out, and lever it out with the punch. Clean up the recessed area, and poke in a new one. TC |
I had a main leak once before on another plane, and the oil remained
behind the flywheel. I believe this is different and probably a plug as you describe. There is a plate under the prop bolts, so removing the spinner will not make it visible. Time for professional help. Thanks for the info. -- Gene Seibel Gene & Sue's Aeroplanes - http://pad39a.com/gene/planes.html Because I fly, I envy no one. |
![]() G.R. Patterson III wrote: Urethabond can also be applied during the inspection. If this is done, the crank never has to be inspected for this AD again. Last that I had heard (admittedly it has been years since I checked in detail) the urethabond could only be applied if the crank was removed from the engine. CPA was lobbying to allow the procedure to be perofrmed with the crank still installed. What is the current status of this? Bruce Cunningham N30464 C177A |
If you have an O-360-A3A, it does have a hollow crank with the RPM restriction
on the tach and a plug in the front. The -A4A is a solid crank. -- Dr. Nuketopia Sorry, no e-Mail. Spam forgeries have resulted in thousands of faked bounces to my address. |
oil leak question | Dick | Home Built | 18 | November 19th 04 03:14 PM |
~ DICK GRILLED FOR CIA LEAK - CAN YOU SAY PRISON?! ~ | ~ THE CHOKING CHIMP ~ | Military Aviation | 0 | June 6th 04 05:34 AM |
Pazmany PL2 strut leak | moni nut | Home Built | 1 | April 27th 04 02:24 AM |
oil leak fixed - breaking in new cylinders | Michael 182 | Owning | 24 | September 23rd 03 12:36 PM |
Oil Leak in TR182 | Michael 182 | Owning | 2 | August 17th 03 07:13 PM |
