Temporary waypoints in Garmin 430/530
On Oct 15, 9:29*pm, Mxsmanic wrote:
Is there a way to set up temporary waypoints in a Garmin 430/530 that are used only during a single flight, without having to create user waypoints? *I can't find anything in the manual that describes such a thing. Install: http://www8.garmin.com/products/communicator/ and upload from Garmin's "Mapsource". -- Mark |
In rec.aviation.piloting Mark wrote:
On Oct 15, 9:29?pm, Mxsmanic wrote: Is there a way to set up temporary waypoints in a Garmin 430/530 that are used only during a single flight, without having to create user waypoints? ?I can't find anything in the manual that describes such a thing. Install: http://www8.garmin.com/products/communicator/ and upload from Garmin's "Mapsource". That might work for the majority of Garmin handheld devices, but it won't work for their panel mounted equipment like the 430/530. The only way that these units will accept waypoint information as input is when they they are talking to another simular unit and are in 'cross-fill' mode. I'm not sure, but this may be a legal requreiment of their use in an IFR environment (TSO 129?) -- Frank Stutzman Bonanza N494B "Hula Girl" Boise, ID |
On Oct 16, 10:45*am, Frank Stutzman wrote:
In rec.aviation.piloting Mark wrote: On Oct 15, 9:29?pm, Mxsmanic wrote: Is there a way to set up temporary waypoints in a Garmin 430/530 that are used only during a single flight, without having to create user waypoints? ?I can't find anything in the manual that describes such a thing. Install: http://www8.garmin.com/products/communicator/ and upload from Garmin's "Mapsource". That might work for the majority of Garmin handheld devices, but it won't work for their panel mounted equipment like the 430/530. The only way that these units will accept waypoint information as input is when they they are talking to another simular unit and are in 'cross-fill' mode. *I'm not sure, but this may be a legal requreiment of their use in an IFR environment (TSO 129?) -- Frank Stutzman Bonanza N494B * * "Hula Girl" Boise, ID While that may be, it was my understanding that he is simply doing all this from a desktop computer and his Garmin is a "virtual" one. If so, then my directions may solve his need. --- Mark |
Mark writes:
While that may be, it was my understanding that he is simply doing all this from a desktop computer and his Garmin is a "virtual" one. If so, then my directions may solve his need. I am indeed using a simulator, but it works exactly like the real unit and I want to do it in whatever way it is done with the real unit--if it's possible, that is. For the moment, I'm creating user waypoints as I enter a route, then deleting them when I no longer need that route, but it's tedious. |
In rec.aviation.piloting Mxsmanic wrote:
Mark writes: While that may be, it was my understanding that he is simply doing all this from a desktop computer and his Garmin is a "virtual" one. If so, then my directions may solve his need. I am indeed using a simulator, but it works exactly like the real unit and I want to do it in whatever way it is done with the real unit--if it's possible, that is. For the moment, I'm creating user waypoints as I enter a route, then deleting them when I no longer need that route, but it's tedious. When I do it in a real GPS I don't bother to delete the user waypoints unless I get close to the memory limit. -- Jim Pennino Remove .spam.sux to reply. |
On Oct 16, 3:01*pm, Mxsmanic wrote:
I am indeed using a simulator, but it works exactly like the real unit No it doesn't. Close, but a real Garmin 430 is easier to set up. I'm not sure about FSX. For reference, I'm using FS2004 and I teach on a Frasca Tru-Flite with a Garmin 430, a Garmin 430 training system and a C-172 with a G430. The flightsim Garmin is the most cumbersome to program and some of the features don't work quite as well. If everybody plays nice, I might post the lesson plan I'm working on for teaching/learning the Garmin on the PC versus in the cockpit. For the moment, I'm creating user waypoints as I enter a route, then deleting them when I no longer need that route, but it's tedious. I think it's less tedious on the actual device. Legally, to use a GPS overlay for an existing VOR or NDB approach, the waypoints must be in the database and not manually entered. Some fascinating trivia that the FAA and the AOPA have shared is that since so many people are flying GPS on autopilot now, instead of being spread out across the airways, airplanes are automatically flying themselves right down the center of the airway which means it's only a matter of time before somebody flying a route by GPS at 120kts gets overtaken and chewed up by somebody flying the same at 220kts. Kinda scary if you think about it. In fact, I did a flight review for a pilot recently who had a GPS and he spent so much head-down time in the cockpit with it that he'd lose his situational awareness. Everytime he looked down, he'd lose 200 feet but he didn't look at his altimeter enough to realize how much altitude he was losing. He might be banking 20 degrees, approaching the yellow arc and losing 300 fpm or climbing up to 1000' AGL pattern altitude after a cross country, but, dammit, he stayed RIGHT ON that pink line. A great Flight Sim exercise is to launch your cross country into IFR by GPS and, at some point when you're enroute, turn the GPS off to simulate a failure. If you lose situational awareness in actual IMC, you'll be wanting diapers. -C CFI |
Alpha Propellerhead writes:
No it doesn't. Close, but a real Garmin 430 is easier to set up. Sounds like you're not using the real simulator, but just the built-in MSFS simulation. The real simulator was written by Garmin. As far as I can tell (since I have the real manual) the simulated 430 and 530 work exactly like the real-world manual describes, or at least I haven't found discrepancies between the manual and the simulated 430/530. I asked about temporary waypoints because it's not documented very well in the manual. I'm not sure about FSX. Nothing changes for FSX. It's the same simulator (if you are using Garmin's simulator). For reference, I'm using FS2004 and I teach on a Frasca Tru-Flite with a Garmin 430, a Garmin 430 training system and a C-172 with a G430. The flightsim Garmin is the most cumbersome to program and some of the features don't work quite as well. If you are still using the built-in GPS, I agree. I haven't looked at that in years. Head on over to Reality XP and get one that actually behaves like the genuine article. If everybody plays nice, I might post the lesson plan I'm working on for teaching/learning the Garmin on the PC versus in the cockpit. Don't waste your time on the built-in GPS. Use the real sim, and then there won't be any differences worth documenting. I think it's less tedious on the actual device. Legally, to use a GPS overlay for an existing VOR or NDB approach, the waypoints must be in the database and not manually entered. I use my own waypoints only for VFR (and to compensate for the lack of database updates with the simulated 430/530--occasionally a waypoint will move or a new one will appear). Some fascinating trivia that the FAA and the AOPA have shared is that since so many people are flying GPS on autopilot now, instead of being spread out across the airways, airplanes are automatically flying themselves right down the center of the airway which means it's only a matter of time before somebody flying a route by GPS at 120kts gets overtaken and chewed up by somebody flying the same at 220kts. Kinda scary if you think about it. Yes, I've been worrying about that for quite some time. Greater accuracy hugely increases the chance of collisions, especially if the increase in accuracy is not accompanied by collision-avoidance technologies like TCAS. In fact, I did a flight review for a pilot recently who had a GPS and he spent so much head-down time in the cockpit with it that he'd lose his situational awareness. Everytime he looked down, he'd lose 200 feet but he didn't look at his altimeter enough to realize how much altitude he was losing. He might be banking 20 degrees, approaching the yellow arc and losing 300 fpm or climbing up to 1000' AGL pattern altitude after a cross country, but, dammit, he stayed RIGHT ON that pink line. Yet another problem of GPS. Many real-life pilots seem to be way too dependent on GPS, and since they believe they know everything, they are unwilling to hear about the dangers of this. Sim pilots make the same mistakes, but they don't die from them. A great Flight Sim exercise is to launch your cross country into IFR by GPS and, at some point when you're enroute, turn the GPS off to simulate a failure. If you lose situational awareness in actual IMC, you'll be wanting diapers. Agreed. Since I am wary of GPS, I like to practice using various forms of navigation, from pilotage to flight management systems. The GPS never fails in the sim, of course (unless you want it to), but if it did, I'd be able to find my way home. I try to keep a few VORs tuned if I can. A somewhat riskier undertaking that I occasionally chance in the sim is using the TAWS/GPWS to help remain safe during nighttime VFR. I don't know if I'd trust the database in real life, but in the sim the database comes directly from the sim's own terrain database, so it's always 100% accurate. Even then, mistakes can be made. |
In article
, Alpha Propellerhead wrote: In fact, I did a flight review for a pilot recently who had a GPS and he spent so much head-down time in the cockpit with it that he'd lose his situational awareness. Everytime he looked down, he'd lose 200 feet but he didn't look at his altimeter enough to realize how much altitude he was losing. He might be banking 20 degrees, approaching the yellow arc and losing 300 fpm or climbing up to 1000' AGL pattern altitude after a cross country, but, dammit, he stayed RIGHT ON that pink line. Yikes. I hope you got him straightened out. Assuming you did, how did he react to the idea that this behavior might not be entirely desirable? -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
Similar Threads | ||||
LAT/LONG waypoints in Garmin 430 | [email protected] | Piloting | 4 | August 8th 06 07:04 PM |
Garmin GNS 430/530 User Waypoints | Resca | Products | 2 | April 20th 06 01:18 PM |
Garmin user waypoints | Jim Macklin | Piloting | 1 | January 5th 06 06:12 PM |
Garmin user waypoints | Jim Macklin | Instrument Flight Rules | 1 | January 5th 06 06:12 PM |
Garmin 430 user waypoints | Red Baron | Instrument Flight Rules | 9 | December 27th 05 06:20 PM |
