Garmin 430 user waypoints
Old December 26th 05, 06:12 PM posted to rec.aviation.ifr
Default Garmin 430 user waypoints
Hello,
I am a VFR pilot and I currently have a 96C in which I loaded some 700
user waypoints, neede in Italy to find VFR reporting points and
airstrips. My new club's airplane will have a Garmin GNS430. I contacted
Garmin in order to know if it would be possible to load waypoints
through the serial ports, but they said NO.
Looking in depth in the Pilot's manual and in the Installation Manual,
it looks clear that many EFIS do that:
-Bendix King EFS 40/50
-Collins Pro Line 21
-Honeywell Primus 1000
-Radar Graphics
And it is clear too that they connect through Serial 2 RS232 port. On
the installation, I do find some of the OUTPUT packets but there is no
mention of the INPUT required to load waypoints.
Do anybody know something about this?
Old December 26th 05, 06:43 PM posted to rec.aviation.ifr
Red Baron wrote:
Hello,
700 user waypoints, neede in Italy to find VFR reporting points and
Manual, it looks clear that many EFIS do that:
-Radar Graphics
On the installation, I do find some of the OUTPUT packets but there is
no mention of the INPUT required to load waypoints.
Can you use a program such as EasyGPS (Google) to unload them from one
unit and load them into the other via a portable computer?
Old December 26th 05, 07:23 PM posted to rec.aviation.ifr
Unfortunately no! I already use a similar program as well as some
home-made programs, but all of them work with PORTABLE GPSs. GNS530 is a
panel mount GPS and doesn't have the standard Garmin interface, used
by ant commercial program like EasyGPS, GarTrip, etc.
GNS430 has 4 serial ports, but the software interface (protocol) seems
not documented.
Old December 26th 05, 07:56 PM posted to rec.aviation.ifr
Ask a local avionics technician, you need to download the
user way-points to a database and then convert it to a
format and medium that can be entered into the new Garmin.
The GNS530 database will be "protected" since it is a
certified unit, but you should be able to create a "virtual
GNS530" using a laptop computer and then use the cross-fill
menu to import the way-points. You have room for 1,000
waypoints.
On page 107 of the GNS530 manual, it says that the GNS530
can use "other equipment" in the panel, such as a joystick,
to create a waypoint. This would be documented and a
qualified avionics shop would be able to duplicate the
output and use your database as the input.
James H. Macklin
ATP,CFI,A&P
"Red Baron" wrote in message
them from one
computer?
as some
GPSs. GNS530 is a
interface, used
(protocol) seems
| not documented.
Old December 26th 05, 08:32 PM posted to rec.aviation.ifr
Already asked: the only information an important Garmin dealer here in
Italy has, is that a 430/530 can be cross-conneted and the waypoints can
be saved when the other unit has to be serviced.
Database conversion and/or a program on PC is my job: I alreday did it
for a couple of Garmin handhelds, with DOCUMENTED protocol.
See above: I need the SPECIFICATIONS for the protocol. On the
"Installation Manual" there are only few specifications, but for packets
FROM the 430 to other units. No reference at all for packets to be sent
to it :-(
Yes: that is the reason I am convinced it can be done.
As far as I can see, it isn't documented. May be Bendix, Honeywell and
Collins have other channels... of course!
Old December 27th 05, 01:35 AM posted to rec.aviation.ifr
I would seem that the data exchange would have to follow an
ARINC protocol for data exchange. If Garmin was looking to
helpful, you could copy your waypoint database to a CD in
several formats, such as Comma separated values, XLS and
whatever else you can think of. Then send it to Garmin with
a request that they convert it to a format you can install
on your 530 and save as a back-up.
You might also contact Jepesen and ask if they would create
an package for you, with appropriate sales and liability
waivers.
Merry Christmas
Have a Safe and Happy New Year
Live Long and Prosper
Jim Macklin
Garmin.
dealer here in
waypoints can
alreday did it
protocol.
"virtual
cross-fill
but for packets
packets to be sent
| to it :-(
GNS530
joystick,
Honeywell and
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Piloting 10 March 23rd 05 01:16 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
Garmin 76S question Carl Buehler Soaring 2 April 30th 04 11:06 AM
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Products 10 April 29th 04 06:57 AM
Garmin 90 Database Updates Discontinued Val Christian Piloting 14 August 20th 03 09:32 PM
