Can someone describe the antenna installation issues with the PowerFlarm
brick? Does the brick contain the transponder and ADS-b antennas or are they separate? If they are in the brick, does this dictate a need for a special location for mounting the black box? If they are separate, do they need to go outside the glider? SZ |
![]() "Sam Zimmerman" wrote in message ... Can someone describe the antenna installation issues with the PowerFlarm brick? Does the brick contain the transponder and ADS-b antennas or are they separate? If they are in the brick, does this dictate a need for a special location for mounting the black box? If they are separate, do they need to go outside the glider? SZ Also, how far does the GPS antenna have to be seperated from other GPS antennas, such as a 302 antenna? Wayne |
On Nov 11, 10:00*am, "Wayne Paul" wrote:
"Sam Zimmerman" wrote in ... Can someone describe the antenna installation issues with the PowerFlarm brick? Does the brick contain the transponder and ADS-b antennas or are they separate? If they are in the brick, does this dictate a need for a special location for mounting the black box? If they are separate, do they need to go outside the glider? SZ Also, how far does the GPS antenna have to be seperated from other GPS antennas, such as a 302 antenna? Wayne What I've heard so far is that there are 3 antennas: GPS, FLARM, and transponder/ADS-B (those are on the same frequency anyway). I'm interested in the issues as well. My plane is all fiberglass (ASW-19) so it's just the metal parts that will affect the signals. Distance from the antennas to the unit is also an issue. Somewhere there's a discussion of a program that analyzes FLARM traces to determine how good your antenna placement is. They give an example of a unit placed behind the spar that had difficulty seeing traffic ahead. However, I don't have a whole lot of room ahead of the panel for antennas, and I'm concerned about effects on my compass. -- Matt |
On Nov 11, 6:56*am, "Sam Zimmerman" wrote:
Can someone describe the antenna installation issues with the PowerFlarm brick? Does the brick contain the transponder and ADS-b antennas or are they separate? If they are in the brick, does this dictate a need for a special location for mounting the black box? If they are separate, do they need to go outside the glider? SZ Flarm antenna and 1090 MHZ (ADS-B and PCAS) antenna would normally be mounted up above your glareshield inside the cockpit. You do not want to mount them hidden behind the panel. I expect the brick to come with antennas with short coaxial leads designed to allow this - similar to those used on current headless Flarm units like the LX Red Box and Swift made units. There are instructions available now for those units that might give you some planing guidance. There is a port for optional second Flarm antenna (not included in the package) on the PowerFLARM designed to help increase the range and that is intended for mounting externally (esp. if carbon) usually underneath the glider. If there is a transponder antenna in that area there will need to be some thougth given to mounting that antennas away from each other, and cable run lengths etc. I expect most people will install the brick and standard two antennas in a temporary setup and see how this goes and eventually add the external antenna if they want to. That's what I'm planning on doing and am in no rush to drill holes in the outside of my baby. I do expect to drill two hole in the glareshield on my ASH-26E for those two antennas to poke through. Not sure how they will fix/locate underneath yet, and the issue will be making it easy to remove and resinstall the canopy. We asked Urs from Flarm about some of this this at the PASCO safety seminar where he spoke and I think the final exact details on antennas with the brick is still being worked out. Darryl |
On Nov 11, 9:49*am, Darryl Ramm wrote:
On Nov 11, 6:56*am, "Sam Zimmerman" wrote: Can someone describe the antenna installation issues with the PowerFlarm brick? Does the brick contain the transponder and ADS-b antennas or are they separate? If they are in the brick, does this dictate a need for a special location for mounting the black box? If they are separate, do they need to go outside the glider? SZ Flarm antenna and 1090 MHZ (ADS-B and PCAS) antenna would normally be mounted up above your glareshield inside the cockpit. You do not want to mount them hidden behind the panel. I expect the brick to come with antennas with short coaxial leads designed to allow this - similar to those used on current headless Flarm units like the LX Red Box and Swift made units. There are instructions available now for those units that might give you some planing guidance. There is a port for optional second Flarm antenna (not included in the package) on the PowerFLARM designed to help increase the range and that is intended for mounting externally (esp. if carbon) usually underneath the glider. If there is a transponder antenna in that area there will need to be some thougth given to mounting that antennas away from each other, and cable run lengths etc. I expect most people will install the brick and standard two antennas in a temporary setup and see how this goes and eventually add the external antenna if they want to. That's what I'm planning on doing and am in no rush to drill holes in the outside of my baby. I do expect to drill two hole in the glareshield on my ASH-26E for those two antennas to poke through. Not sure how they will fix/locate underneath yet, and the issue will be making it easy to remove and resinstall the canopy. We asked Urs from Flarm about some of this this at the PASCO safety seminar where he spoke and I think the final exact details on antennas with the brick is still being worked out. Darryl I gather new gliders now have transponder antennas in the fiberglass tail, rather than ugly sticking out the bottom, along with radio. Is it impossible to fish coax back to the tail and put some of these antennas back there without cutting holes? John Cochrane |
On Nov 11, 7:55*am, John Cochrane
wrote: On Nov 11, 9:49*am, Darryl Ramm wrote: On Nov 11, 6:56*am, "Sam Zimmerman" wrote: Can someone describe the antenna installation issues with the PowerFlarm brick? Does the brick contain the transponder and ADS-b antennas or are they separate? If they are in the brick, does this dictate a need for a special location for mounting the black box? If they are separate, do they need to go outside the glider? SZ Flarm antenna and 1090 MHZ (ADS-B and PCAS) antenna would normally be mounted up above your glareshield inside the cockpit. You do not want to mount them hidden behind the panel. I expect the brick to come with antennas with short coaxial leads designed to allow this - similar to those used on current headless Flarm units like the LX Red Box and Swift made units. There are instructions available now for those units that might give you some planing guidance. There is a port for optional second Flarm antenna (not included in the package) on the PowerFLARM designed to help increase the range and that is intended for mounting externally (esp. if carbon) usually underneath the glider. If there is a transponder antenna in that area there will need to be some thougth given to mounting that antennas away from each other, and cable run lengths etc. I expect most people will install the brick and standard two antennas in a temporary setup and see how this goes and eventually add the external antenna if they want to. That's what I'm planning on doing and am in no rush to drill holes in the outside of my baby. I do expect to drill two hole in the glareshield on my ASH-26E for those two antennas to poke through. Not sure how they will fix/locate underneath yet, and the issue will be making it easy to remove and resinstall the canopy. We asked Urs from Flarm about some of this this at the PASCO safety seminar where he spoke and I think the final exact details on antennas with the brick is still being worked out. Darryl I gather new gliders now have transponder antennas in the fiberglass tail, rather than ugly sticking out the bottom, along with radio. Is it impossible to fish coax back to the tail and put some of these antennas back there without cutting holes? John Cochrane If by tail you mean the vertical fin? My HP-24 and the Apis are all carbon except for the rudder, I don't think splitting the rudder apart to install an antenna has much appeal. Brad |
wrote: On Nov 11, 9:49*am, Darryl Ramm wrote: On Nov 11, 6:56*am, "Sam Zimmerman" wrote: Can someone describe the antenna installation issues with the PowerFlarm brick? Does the brick contain the transponder and ADS-b antennas or are they separate? If they are in the brick, does this dictate a need for a special location for mounting the black box? If they are separate, do they need to go outside the glider? SZ Flarm antenna and 1090 MHZ (ADS-B and PCAS) antenna would normally be mounted up above your glareshield inside the cockpit. You do not want to mount them hidden behind the panel. I expect the brick to come with antennas with short coaxial leads designed to allow this - similar to those used on current headless Flarm units like the LX Red Box and Swift made units. There are instructions available now for those units that might give you some planing guidance. There is a port for optional second Flarm antenna (not included in the package) on the PowerFLARM designed to help increase the range and that is intended for mounting externally (esp. if carbon) usually underneath the glider. If there is a transponder antenna in that area there will need to be some thougth given to mounting that antennas away from each other, and cable run lengths etc. I expect most people will install the brick and standard two antennas in a temporary setup and see how this goes and eventually add the external antenna if they want to. That's what I'm planning on doing and am in no rush to drill holes in the outside of my baby. I do expect to drill two hole in the glareshield on my ASH-26E for those two antennas to poke through. Not sure how they will fix/locate underneath yet, and the issue will be making it easy to remove and resinstall the canopy. We asked Urs from Flarm about some of this this at the PASCO safety seminar where he spoke and I think the final exact details on antennas with the brick is still being worked out. Darryl I gather new gliders now have transponder antennas in the fiberglass tail, rather than ugly sticking out the bottom, along with radio. Is it impossible to fish coax back to the tail and put some of these antennas back there without cutting holes? John Cochrane John Looking at that is a good idea, but beyond the capability of most owners or repair shops. This is something the glider manufacturers really should be working with Flarm to design in this capability. That will make for three antennas back there. The VHF comm antenna in the tail is unlikely to be a significant problem but the Transponder and Flarm will a need some thought/work on how they are installed near each other to avoid problems. Flarm operates at relatively low power and the coax run back to the tail may be an issue. Even with transponders I expect the tail mounted antennas to have issues with mimimum coaxial loss requiremnts. e.g. If I was ordering a new glider with the tail mounted transponder antenna I'd talk to the glider manufactures about the output power from tranponders they have actually seen when they do the transponder calibrations tests (not just the theoretical cable losses). And I'd not be surprised if I needed to order a higher-power transponder to know that it would reach the minimum power output requirements (e.g. order a Trig TT-22 instead of a Trig TT-21 transponder - and/or work on getting that Trig transponder box back as far as it can be mounted (and reached for service) in the glider fuselage). Because the vertical fins of modern gliders are carbon the antennas usually mount outside the fin box in the rudder hinge gap area. This may actually be a worse location than mounted under the glider, especially since the antenna is parallel to large conducting surfaces of the vertical fin, but it sure looks cleaner. I'd love to see any test results manufacturers have for these transponder antenna installs. And at least for Flarm if the antenna in that location is slightly blocked looking forward that is not an issue since the Flarm antenna in the cockpit should provide good forward coverage. In an ideal world the glider manufactures would have a RF consultant model the antenna performance in these installs. I'm not sure how much design work actually goes into these installs. In my ASH-26E my transponder antenna is is underneath the fueslage behind the gear. My PowerFLARM optional external Flarm antenna might end up getting installed on the top of the tail boom behind the engine bay (where people can walk up and try to wiggle it and ask "what is this" - before being smacked on the head). I expect we'll see some guidance from Flarm on this in time. This also was something that came up at the PASCO saftey seminar in questions to Urs from Flarm and he seemed quite keen on the idea of having glider manufactures install the optional external Flarm antenna in glider vertical fins. Some comment back to antenna installs. Both the 1090MHz and Flarm signals are vertically polarized so both antennas need to be as vertical as possible. The standard antennas Flarm devices use in the cockpit do not require a ground plane. Different optional external antennas may or may not depending on the antenna. Many GPS receivers do not interfere when mounted close to each other. I'm not even sure what the problem is when they do (local-oscillator back leakage from the GPS receiver? - but that has to come all the way from the box as the powered antennas don't have a L.O. in them) but I know people have experienced this. Most times I've heard of problems separating the antennas by a few inches seemed to cure it. If there is a problem I'd also try swapping out the active (patch style that contain an RF amplifier) antennas with a different brand/model and seeing if that helps. I've seen people claim problems with GPS antenna interference when I suspect it was really just a faulty antenna or coax/cable and where moving things appeared to change things because of the coax was intermittently bad. So careful testing/swapping out antennas/cables if you think you see this is a good idea. Darryl |
There will be a few options, I'm sure. Those of us with carbon
fuselages will need to experiment. My OzFLARM Nimbus 3 install (now back in the USA and part of Steve Leonard's fleet) had a high-gain film antenna stuck to the inside of the canopy. It looks obvious from the outside but was not visible to the pilot in flight. These were for sale by the original manufacturer of the OzFLARM, Nigel Andrews at RF Developments. I have not seen those antennas on the Swift Avionics (current Australian FLARM representative) website. Of course this was a top-of-the-panel mount with an internal GPS antenna and didn't need a transponder antenna. Before installing the high-gain antenna, I took the plastic cover off the standard OzFLARM antenna and replaced it with clear instrument tubing - less obtrusive than the black stick. There are a few antenna options for the standard FLARM shown on this page: http://www.swiftavionics.com.au/prod.../1/Sailplanes/ The suction cup mount antenna (just above Altair Pro) and similar GPS antenna mounts may be a good way to experiment with placement. Whilst you're on the Swift website, look at their FLARMNAV. Makes a simple package for club gliders. Jim |
On Nov 11, 2:25*pm, JS wrote:
* There will be a few options, I'm sure. Those of us with carbon fuselages will need to experiment. * My OzFLARM Nimbus 3 install (now back in the USA and part of Steve Leonard's fleet) had a high-gain film antenna stuck to the inside of the canopy. It looks obvious from the outside but was not visible to the pilot in flight. These were for sale by the original manufacturer of the OzFLARM, Nigel Andrews at RF Developments. I have not seen those antennas on the Swift Avionics (current Australian FLARM representative) website. * Of course this was a top-of-the-panel mount with an internal GPS antenna and didn't need a transponder antenna. Before installing the high-gain antenna, I took the plastic cover off the standard OzFLARM antenna and replaced it with clear instrument tubing - less obtrusive than the black stick. * There are a few antenna options for the standard FLARM shown on this page:http://www.swiftavionics.com.au/prod.../1/Sailplanes/ The suction cup mount antenna (just above Altair Pro) and similar GPS antenna mounts may be a good way to experiment with placement. Whilst you're on the Swift website, look at their FLARMNAV. Makes a simple package for club gliders. Jim Hi Jim ! Note that classic flarm is not OK for USA. FLARM crew is working on better antenna options for the states. See you in Keepit in a couple weeks ? Best Regards, Dave "YO electric" |
wrote: On Nov 11, 9:49*am, Darryl Ramm wrote: On Nov 11, 6:56*am, "Sam Zimmerman" wrote: Can someone describe the antenna installation issues with the PowerFlarm brick? Does the brick contain the transponder and ADS-b antennas or are they separate? If they are in the brick, does this dictate a need for a special location for mounting the black box? If they are separate, do they need to go outside the glider? SZ Flarm antenna and 1090 MHZ (ADS-B and PCAS) antenna would normally be mounted up above your glareshield inside the cockpit. You do not want to mount them hidden behind the panel. I expect the brick to come with antennas with short coaxial leads designed to allow this - similar to those used on current headless Flarm units like the LX Red Box and Swift made units. There are instructions available now for those units that might give you some planing guidance. There is a port for optional second Flarm antenna (not included in the package) on the PowerFLARM designed to help increase the range and that is intended for mounting externally (esp. if carbon) usually underneath the glider. If there is a transponder antenna in that area there will need to be some thougth given to mounting that antennas away from each other, and cable run lengths etc. I expect most people will install the brick and standard two antennas in a temporary setup and see how this goes and eventually add the external antenna if they want to. That's what I'm planning on doing and am in no rush to drill holes in the outside of my baby. I do expect to drill two hole in the glareshield on my ASH-26E for those two antennas to poke through. Not sure how they will fix/locate underneath yet, and the issue will be making it easy to remove and resinstall the canopy. We asked Urs from Flarm about some of this this at the PASCO safety seminar where he spoke and I think the final exact details on antennas with the brick is still being worked out. Darryl I gather new gliders now have transponder antennas in the fiberglass tail, rather than ugly sticking out the bottom, along with radio. Is it impossible to fish coax back to the tail and put some of these antennas back there without cutting holes? John Cochrane- Hide quoted text - - Show quoted text - Hi John, I installed a dipole antenna inside the tail of my Genesis and routed the coax forward to run the transponder. It needs to be kept 6" from the radio antenna and metal parts like pushrods. You may be able to mount one behind the rudder in a corner that doesn't interfere with rudder movement or cut a small hole in the bottom of the fin spar to get it out of the way of rudder. It measures 1" X 1" X 5" with a BNC coming out at 90 degrees ( I got one from Aircraft Spruce) The coax can be secured by sliding gooped-up rings down the coax from the front then allowing the rings to settle and bond in the desired locations. JJ PS..........please no cracks about the Genesis not having a tail. |
PowerFLARM | Paul Remde | Soaring | 9 | November 6th 10 04:30 AM |
PowerFLARM | Greg Arnold[_2_] | Soaring | 6 | November 2nd 10 09:32 AM |
Antenna install | [email protected] | Piloting | 5 | May 26th 08 03:48 PM |
Antenna install | [email protected] | Owning | 5 | May 26th 08 03:48 PM |
Antenna install | [email protected] | Home Built | 5 | May 26th 08 03:48 PM |
