Cad drawing for ASW27 or ASG29 instrument panel
Old January 20th 11, 10:09 PM posted to rec.aviation.soaring
Larry Goddard
Default Cad drawing for ASW27 or ASG29 instrument panel
Trying to help a friend with instrument layout for a new panel. Anyone
have a cad drawing of one of these?
Larry
Zero One
Old January 20th 11, 10:22 PM posted to rec.aviation.soaring
KevinFinke
You can get a very high quality PDF drawing from the AS website.
Should then be possible to bring that into a CAD program and convert
it into a CAD dataset.
http://www.alexander-schleicher.de/s...20ib%20001.pdf
-Kevin
Old January 20th 11, 10:28 PM posted to rec.aviation.soaring
Brad[_2_]
-Kevin
can't a PDF file be opened in a vector/spline based application like
Adobe Illustrator? if so, it should be relatively easy to get what you
need, sizing the view space and the printing window would take some
tiling tho.
Brad
Old January 20th 11, 10:49 PM posted to rec.aviation.soaring
Larry Goddard
Thanks!!!!
Should have poked around further on the website before giving up....
Larry
"KevinFinke" wrote in message
-Kevin
Old January 21st 11, 01:55 AM
OregonGliderPilot OregonGliderPilot is offline
Junior Member
First recorded activity by AviationBanter: Sep 2009
[quote=Larry Goddard;760470]Thanks!!!!
Larry
I have a .dwg of my ASG29 large panel if you are still looking.
MG
Old July 22nd 14, 02:54 PM posted to rec.aviation.soaring
Nik[_2_]
Could you please share that .dwg file?
Thanks in advance, Nik
On Friday, 21 January 2011 02:55:57 UTC+1, OregonGliderPilot wrote:
Larry Goddard;760470 Wrote:
Thanks!!!!
Larry
MG
OregonGliderPilot
Old July 22nd 14, 04:19 PM posted to rec.aviation.soaring
Bob Kuykendall
Here's a DWG version of that panel. Double check it before you put much faith in it:
http://www.hpaircraft.com/misc/ASG29_Panel.zip
Thanks, Bob K.
Old December 29th 18, 07:25 PM posted to rec.aviation.soaring
Gary Wayland
Larry
Zero One
I have one for the ASW27 in DWG. How do I get it to you?
Gary
"SQ"
ASW27b
Old December 30th 18, 07:19 PM posted to rec.aviation.soaring
Gary Wayland
Larry
Zero One
Larry, Not only do I have the CAD file, I have many instruments that have the back measurements. So, you can move them around at will in the cad file to see if they are going to fit in the panel. The fronts don't mean much in this job other than looking what will be in the air.
The SN-10 comes to mind. Some instruments have inlarged backs beyond the standard.
I will send all I have with it if you like.
I do have DropBox if you want them. I can post the link
Gary
ASW27b
27-148
"SQ"
PIK-20D Instrument panel Solo Soaring 5 February 15th 09 06:50 PM
CAD drawing for DG instrument panel... Marc Ramsey Soaring 5 April 7th 06 07:12 AM
Instrument Panel ccwillwerth Home Built 7 February 9th 06 02:15 PM
DG-300 instrument panel [email protected] Soaring 14 January 29th 06 02:48 PM
LS 6 b instrument panel John Brenann Soaring 4 November 19th 05 04:37 AM
