Hi
I'm looking for a preheater for my 172. I don't have a power source near my tiedown. I don't own a generator. Because of all of the above I'm looking for a propane powered preheater but I can't find one. Any recommendations? Any reason why I shouldn't buy a propane one. Thanks -- Tony Roberts ) PP-ASEL VFR-OTT - Night Cessna 172H |
We have a 300 watt oil pan heater and the engine starts much better and oil
temperature comes up faster than when we used the FBO's dragon. The size and weight of a portable generator that would power one of these is similar to the size and weight of a dragon. Why not buy the generator which would have all sorts of other uses? -- Roger Long |
oil temperature comes up faster than when we used the FBO's dragon. The size and weight of a portable generator that would power one of these is similar to the size and weight of a dragon. Why not buy the generator which would have all sorts of other uses? It's much easier on the fiberglass cowling, too. (I actually bubbled the paint on a rental bird, using one of those "stick it in the cowling" jet engine heaters...) However, it doesn't warm the cylinders at all. I wonder if a portable generator could power the cylinder warmers, too? We've got the oil pan and cylinder warmers, and the oil is usually warmer when we start up in winter (verified with our digital oil temperature gauge) than it is in spring and fall. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
I wonder if a portable generator could power the cylinder warmers, too? We've got the oil pan and cylinder warmers, and the oil is usually warmer when we start up in winter (verified with our digital oil temperature gauge) than it is in spring and fall. -- Shouldn't be a problem. If I remember right, my cylinder warmers were about 50 watts a piece. And, although I don't have the pan heater, I think they're usually about 150 watts. So the max, on a 6 cyl, would be about 450 watts. I think that's well within the capabilities of even small generators. I would think the big pain in the butt would be that fact that it takes electric warmers a reasonable length of time to warm the engine, which means th generator would be sitting their running for many hours. -- Jay __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino/ ! ! ! Checkout http://www.oc-adolfos.com/ for the best Italian food in Ocean City, MD and... Checkout http://www.brolow.com/ for authentic Blues music on Delmarva |
That's true... just about the smallest generator would be fine to
power a plane or two. For a 20 degree day, plugging the plane in for 3 hours or so typically seems to bring it up to warm to the touch. That's only 1.5 kWh of juice, so it's roughly $0.25 worth of gasoline for a generator. Seems to make more sense than a portable preheater. Also, I've read that the flame-thrower type (expecially the propane bottle ones) don't put enough heat in the right places to help prevent cylinder scuffing. Leaving a multi-point heater plugged in for a few hours is the best, and the generator has many more uses elsewhere. -Cory Jay Masino wrote: : Shouldn't be a problem. If I remember right, my cylinder warmers were : about 50 watts a piece. And, although I don't have the pan heater, I : think they're usually about 150 watts. So the max, on a 6 cyl, would be : about 450 watts. I think that's well within the capabilities of even : small generators. I would think the big pain in the butt would be that : fact that it takes electric warmers a reasonable length of time to warm : the engine, which means th generator would be sitting their running for : many hours. : -- Jay : __!__ : Jay and Teresa Masino ___(_)___ : http://www2.ari.net/jmasino/ ! ! ! : Checkout http://www.oc-adolfos.com/ : for the best Italian food in Ocean City, MD and... : Checkout http://www.brolow.com/ for authentic Blues music on Delmarva -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
read that the flame-thrower type (expecially the propane bottle ones) don't put enough heat in the right places to help prevent cylinder scuffing. Leaving a multi-point heater plugged in for a few hours is the best, and the generator has many more uses elsewhere. Of course, the rub is turning the danged thing on 3 hours in advance. Didn't someone rig up a "cell-phone-on/off-trigger" for their pre-heater last year? I remember thinking it was way cool, for those who don't have a hangar with electricity. (If you have a hangar, the best trigger, IMHO, is the temperature-sensitive cubes. They go "On" at 35 degrees, "Off" at 40 degrees...) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
I have the Reiff cylinder heaters and oil sump heater. Mine are for the narrow
deck engine, so each cylinder heater is 50W. I think the sump heater is 300W, so for my Six, a generator capable of at least 600W should work fine. I think most of the portable generators are good for about 1000W. Jay Honeck wrote: We have a 300 watt oil pan heater and the engine starts much better and oil temperature comes up faster than when we used the FBO's dragon. The size and weight of a portable generator that would power one of these is similar to the size and weight of a dragon. Why not buy the generator which would have all sorts of other uses? It's much easier on the fiberglass cowling, too. (I actually bubbled the paint on a rental bird, using one of those "stick it in the cowling" jet engine heaters...) However, it doesn't warm the cylinders at all. I wonder if a portable generator could power the cylinder warmers, too? We've got the oil pan and cylinder warmers, and the oil is usually warmer when we start up in winter (verified with our digital oil temperature gauge) than it is in spring and fall. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
![]() "Ray Andraka" wrote in message ... I have the Reiff cylinder heaters and oil sump heater. Mine are for the narrow deck engine, so each cylinder heater is 50W. I think the sump heater is 300W, so for my Six, a generator capable of at least 600W should work fine. I think most of the portable generators are good for about 1000W. I purchased a Hot Padd heater from Reiff. The heater could not be mounted on my engine in accordance with the supplied instructions, so I made do as best I could. The adhesive didn't cure and the pad easily peeled off. I returned the pad to Reiff for a refund, they sent it back to me with more adhesive. Apparently I violated the warranty by not following the instructions to the letter, (the fact that it was impossible to follow them was of no interest to Reiff). I don't know if the Reiff heater is any good or not, I do know that their product support and customer relations are terrible. I won't do business with them again. I purchased a "milkhouse heater" and some ductwork at a local home improvement store. The cost was about $35 and it does a fine job. |
"Roger Long" om writes:
We have a 300 watt oil pan heater and the engine starts much better and oil temperature comes up faster than when we used the FBO's dragon. The size and weight of a portable generator that would power one of these is similar to the size and weight of a dragon. Why not buy the generator which would have all sorts of other uses? I second the generator idea. Electric heaters are *so* handy. You can even put some in your cabin to keep your seat and instruments warm. If you run the generator off of 100LL, you won't have to mess with carrying (other) tanks of fuel. I'd feel a lot better about leaving a generator running (for a day trip) than leaving a Dragon running too. The Red Dragon *without* fuel tank is a little lighter than a generator (16-22 vs. 29 pounds) but it requires electrical power. In the cold, I'd much rather leave something running that's charging, not discharging, my plane's battery. Small generators often have 12VDC outputs http://www.mayberrys.com/honda/gener...ls/eu1000i.htm so if your plane has a 12V system, you're all set. I've checked with a few FBOs about plugging in my plane on the ramp when we travel. The answers range from "Sure, no problem" to "Bring your own extension cord." That means you'd usually be able to avoid having to deploy the generator. So...do you want to lug around a tank of LP, mess with connecting a heater to your engine and battery and then run down your battery, or would you rather drain a little fuel into a generator, plug it in, and await a warm cockpit and freshly-charged battery? --kyler |
Lycoming intake preheater | Dale Larsen | Home Built | 5 | June 6th 04 10:32 PM |
