Lycoming intake preheater
Old June 6th 04, 04:12 PM
Dale Larsen
Default Lycoming intake preheater
Anyone know the reasoning for running the intake tubes through the hot oil
in the sump?
Old June 6th 04, 05:11 PM
Dale Larsen wrote:
: Anyone know the reasoning for running the intake tubes through the hot oil
: in the sump?
1. Make oil not so hot
2. Make package more compact
3. Reduce power
4. Decrease detonation margin.
1&2: good
3&4: notsogood
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
Old June 6th 04, 10:32 PM
Jan Carlsson
Some engine design need to heat the intake side to prevent condense in the
tubes that lead to engines that run rough, this is a normal design on carb
engines, even in cars. it also prevent ice in the tubes but that is not the
main goal, even cars use warm air to heat the intake air in the carburator
and tube, manually changed (winter/summer) or by a thermostat
Jan Carlsson
www.jcpropellerdesign.com
"Dale Larsen" skrev i meddelandet
news:GvGwc.53250$eY2.35696@attbi_s02...
in the sump?
O-235 Lycoming Mods Do B Home Built 2 March 19th 04 02:42 PM
Remove oil seal from vacuum pump adapter on Lycoming IO320 HOW????? Ron Home Built 2 February 24th 04 04:34 PM
Lycoming Sued jls Home Built 0 February 13th 04 02:01 PM
Weight of Lycoming O290 Ray Toews Home Built 1 December 21st 03 11:56 PM
Lycoming 320 and EAA Light Sport Aircraft ? Dave Jackson Home Built 29 October 20th 03 01:20 AM
