Vaccuum Pressure Gauge
Old January 16th 04, 02:53 AM
Al
Default Vaccuum Pressure Gauge
Now that its cold again, my vacuum pressure gauge is acting up (again). In
the past, when it was cold, it would take a few minutes to come up to the
correct reading. Now, it takes about 30 to 40 minutes to come up. All
dials are OK, and when the gauge comes up, it reads in the normal range.
Any suggestions or good shops??? Thanks!
Alex
awaddell .a.t. codestrike d-o-t com
Old January 16th 04, 12:57 PM
CriticalMass
Sounds like it's tired.
Any instrument shop could overhaul it, I suppose - Trade a Plane is full
of them. I'd look at cost new, as well. Aircraft Spruce shows a 2 1/4"
UMA vacuum gauge new for $84.
I always say, replace stuff in our old airplanes with new every 35-40
years whether it needs it or not.
Old January 16th 04, 04:38 PM
Al
Buying the new airborne (OEM) is $883.55. Anyone know the legality & fit of
replacing it with a UMA version?
remove underscores to email
"CriticalMass" wrote in message
Old January 16th 04, 03:25 PM
mikem
Alex
They use a tiny orfice (jewller's screw driver adjustable, located
thru the NPT threaded fitting on the rear of the gauge) to create
the damping for the needle. If this orfice is too big, the needle
vibrates in step with each intake stroke. If the orfice is too small,
it will do what you describe, especially in cold weather, where
differential expandation (sp?) of the materials tend to close up the
orfice...
The orfice adjusting screw is reachable by removing the 1/8" tube
which goes through the firewall to the induction...
MikeM
Old January 16th 04, 05:26 PM
Michael
Assuming this is really a gauge problem (do the gyros spin?) there is
oil and/or crud in the gauge. The only fix is to disassemble, clean
with a solvent (acetone is a good choice, cheap, and available at most
hardware stores), and reassemble. Don't let the acetone get on the
cover (lens) because it will fog.
The most difficult and time consuming part will be removing the gauge
and reinstalling it.
Of course this isn't preventive maintenance, so I would never suggest
that you as an owner should do this.
Michael
Attn: Hydraulic experts - oil pressure relief fix? MikeremlaP Home Built 0 November 2nd 04 05:49 PM
Need gauge help/information dave Home Built 3 February 17th 04 02:39 AM
Manifold pressure gauge problem Dave Russell Aerobatics 3 January 29th 04 03:46 AM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 12:35 AM
Pressure Differential in heat Exchangers Bruce A. Frank Home Built 4 July 3rd 03 05:18 AM
