Attn: Hydraulic experts - oil pressure relief fix?
Old November 2nd 04, 06:49 PM
MikeremlaP
Default Attn: Hydraulic experts - oil pressure relief fix?
Okay, here's the deal. Lycoming O-320 in a Glasair. On full power, whether
oil is hot or cold, oil pressure will be higher than the regulator is set for.
(Shoots to top of yellow arc - 90 psi. I think most Lyc's do that.) Upon power
reduction, say turning downwind, you can "see" the ball pop off the seat when
the oil pressure gage goes "sproinggg" and the pressure suddenly drops to the
regulated 60 psi in a classic 2nd order damped sinusoidal response. It will
stay at regulated pressure until the ball seats itself again, say on final
approach with the engine back to idle, and the pump isn't making as much
pressure. Then the process starts over again, on the next touch 'n' go. I'd
like to have regulated oil pressure all the time.
I'm theorizing that there's some kind of venturi effect, where the ball is
actually sucked down harder on the seat when lots of oil is flowing past it on
the engine side. Seems counter-intuitive, I know, but what else could be
holding the ball down? Is oil cohesive?
Anyone got a simple fix I can try? Larger ball bearing? Smaller ball bearing?
Cutting groves in the seat to help ball break free? Different angle on the
face of the seat?
Mike Palmer
Excellence in Ergonomics
Pressure Differential in heat Exchangers Bruce A. Frank Home Built 4 July 3rd 03 06:18 AM
