Is it worth lugging long extension cords to plug in the Tanis heaters for my
Baron if it's going to sit outside at 12 degrees for two to three hours after a flight? I have cowl plugs which may help a little, but is it really a problem? The oil will be well circulated, and the battery is in good shape to crank the engines. Also, the POH says to keep the cowl flaps open during taxi and take off, but when it's so cold outside does this still make sense? As long as the CHTs remain within a reasonable range what difference should it make? Thanks from Wisconsin, where its 2 degrees and clear. |
On Sun, 15 Feb 2004 13:18:35 GMT, "Viperdoc"
wrote: Is it worth lugging long extension cords to plug in the Tanis heaters for my Baron if it's going to sit outside at 12 degrees for two to three hours after a flight? I have cowl plugs which may help a little, but is it really a problem? The oil will be well circulated, and the battery is in good shape to crank the engines. Also, the POH says to keep the cowl flaps open during taxi and take off, but when it's so cold outside does this still make sense? As long as the CHTs remain within a reasonable range what difference should it make? Thanks from Wisconsin, where its 2 degrees and clear. It is hard to say, as it will vary plane to plane. But in that kind of cold, for my O-360, 3 hours is pushing it. A cowl cover in addition to cowl plugs is the only way I can wait that long. The Baron's engines would have more thermal mass than the O-360, so perhaps you can go longer. OTOH, you don't mention cowl covers... Without the covers, I'd bring the extensions for the Tanis. -Nathan |
So, for those of you with plug in heaters, how does that work out? I presume
that at your home airport, you are parked in your own unheated hangar or near an outlet on the ramp. What about visiting other airports? Do you asked to be parked near an outlet? Do they stretch a cord across the ramp for you? Do they plug it into a service truck for a couple of hours before start? ------------------------------- Travis |
On Mon, 16 Feb 2004 04:08:04 GMT, "Travis Marlatte"
wrote: So, for those of you with plug in heaters, how does that work out? I presume that at your home airport, you are parked in your own unheated hangar or near an outlet on the ramp. What about visiting other airports? Do you asked to be parked near an outlet? Do they stretch a cord across the ramp for you? Do they plug it into a service truck for a couple of hours before start? ------------------------------- Travis If I cannot plug in, I obtain pre-heat in the usual manner -- i.e. the FBO either has a gas fired unit; heated hangar or I make other arrangements. Some folk will carry small generators; others will carry small "Red Dragons". Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Most of the time, I've been able to arrange either to leave it plugged in, or
more often have the fBO move it and plug it a few hours before I intend to depart. I keep an extension cord in the plane all winter. You never know when a short stop might turn into a longer one than intended, and the weight of the extension cord is not all that much. Travis Marlatte wrote: So, for those of you with plug in heaters, how does that work out? I presume that at your home airport, you are parked in your own unheated hangar or near an outlet on the ramp. What about visiting other airports? Do you asked to be parked near an outlet? Do they stretch a cord across the ramp for you? Do they plug it into a service truck for a couple of hours before start? ------------------------------- Travis -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
Aluminum shrinks and expands more than steel. At some temperature around
10 degrees the case will have shrunk onto the crank and cam to the point where you have zero bearing clearance! Rip Viperdoc wrote: Is it worth lugging long extension cords to plug in the Tanis heaters for my Baron if it's going to sit outside at 12 degrees for two to three hours after a flight? I have cowl plugs which may help a little, but is it really a problem? The oil will be well circulated, and the battery is in good shape to crank the engines. Also, the POH says to keep the cowl flaps open during taxi and take off, but when it's so cold outside does this still make sense? As long as the CHTs remain within a reasonable range what difference should it make? Thanks from Wisconsin, where its 2 degrees and clear. |
"Viperdoc" wrote: Is it worth lugging long extension cords to plug in the Tanis heaters for my Baron if it's going to sit outside at 12 degrees for two to three hours after a flight? What is an engine worth? g IF you have a cowl blanket and IF the engine oil will stay warm for that length of time then it shouldn't be a problem. I would plug it in if it was my airplane. Also, the POH says to keep the cowl flaps open during taxi and take off, but when it's so cold outside does this still make sense? As long as the CHTs remain within a reasonable range what difference should it make? CHTs might be okay but other areas of the engine compartment may be heating up. I used to fly a B-17 and B-24, we always had the cowlflaps open on the ground because if they were closed it was possible to heat damage the sparkplug wires. Big difference in engines I know. If the POH says leave them open I would. If you've preheated properly the engine will come up to temp quickly and you'll need them open. Also, with a change in procedure it would be easy to goof and leave them closed during takeoff and climb which could really cook things. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
I started my engines this morning at -4 F... No preheat never do No
problems; though it did take 6 blades each, before they fired - mucho cold senor... Use 15W50... I get oil pressure indication in less than ten seconds... That's the way this airplane has been treated ever since semisynthetic, multiviscosity, oils came out.... Engines go to TBO routinely... denny "Dale" wrote in message ... In article , "Viperdoc" wrote: Is it worth lugging long extension cords to plug in the Tanis heaters for my Baron if it's going to sit outside at 12 degrees for two to three hours after a flight? What is an engine worth? g IF you have a cowl blanket and IF the engine oil will stay warm for that length of time then it shouldn't be a problem. I would plug it in if it was my airplane. Also, the POH says to keep the cowl flaps open during taxi and take off, but when it's so cold outside does this still make sense? As long as the CHTs remain within a reasonable range what difference should it make? CHTs might be okay but other areas of the engine compartment may be heating up. I used to fly a B-17 and B-24, we always had the cowlflaps open on the ground because if they were closed it was possible to heat damage the sparkplug wires. Big difference in engines I know. If the POH says leave them open I would. If you've preheated properly the engine will come up to temp quickly and you'll need them open. Also, with a change in procedure it would be easy to goof and leave them closed during takeoff and climb which could really cook things. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
"Dennis O'Connor" wrote: I started my engines this morning at -4 F... No preheat never do No problems; though it did take 6 blades each, before they fired - mucho cold senor... Use 15W50... I get oil pressure indication in less than ten seconds... That's the way this airplane has been treated ever since semisynthetic, multiviscosity, oils came out.... Engines go to TBO routinely... denny Wow. To each his own. I would never start at those temps without preheat, and I also used 15W50. I've also tried to pour it when it's cold. G If it works for you, great. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
Wow. Pretty cavalier attitude with two engines worth close to $20K apiece. I've found that for periods of four hours or less, the engine will stay pretty warm with our dark blue cowl cover on -- especially in a bright sun. For longer periods, plugging in is essential. A couple of weeks ago, while staying at Lake Lawn Lodge (in Lake Delevan, WI) the oil temperature was 34 degrees at start-up -- even after being plugged in overnight, WITH the cowl cover on! The outside temperature was -10, and the wind was howling. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Turbine air start -- too cold? | Juan Jimenez | Home Built | 97 | March 14th 05 06:51 PM |
Turbine air start -- too cold? | Juan Jimenez | General Aviation | 54 | February 2nd 05 04:14 AM |
Cold War relic F/A-22 initially designed for air-to-air combat with Soviet MiGs | Larry Dighera | Military Aviation | 7 | April 2nd 04 07:05 PM |
Soviet Spy Planes over the West during the Cold War | Rusty B | Military Aviation | 6 | February 19th 04 04:53 PM |
Battery Replacement and Cold Cranking Amps | O. Sami Saydjari | Owning | 27 | February 2nd 04 02:38 PM |
