Battery Replacement and Cold Cranking Amps
Old January 27th 04, 07:19 AM
O. Sami Saydjari
Default Battery Replacement and Cold Cranking Amps
I have a Gill G25 battery in my Piper Arrow III (PA28R-201T). I
recently had a situation where I ran out of juice after 4 attempted
starts. While I am sure that I can improve my starting technique (I am
a newbie for this particular plane), I would like to have a bit more
power in my battery, especially in very cold conditions such as we have
up here in central Wisconsin.
An A&P told me recently that I am "stuck" with my G25 battery. He said
that he tested it and that it was "fine."
Based on a recent article in "Aviation Consumer", I learned that the G25
has only about 225 cold cranking amps. I noted that the G35S has 250
cold cranking amps.
(1) Is it true that I am stuck with a G25 battery and that NO OTHER
battery in the world can go in my plane? I find that a little hard to
believe.
(2) If there are other possibilities, can someone recommend one that has
better cold cranking amps that the G25?
Thanks in advance.
-Sami (N2057M, Piper Turbo Arrow III owner)
Old January 27th 04, 08:27 AM
starts.
Since you live in central Wisconsin, you know how cold can sap a battery's
charge, particularly if left idle for a few days. But when you say it "ran
out of juice after 4 attempted starts" I am wondering (a) what you mean by
no juice, and (b) what constitutes an "attempt." If you mean that the
battery is discharged to a point where the prop will no longer turn with the
starter, that could mean a lot of things, including a defective starter. If
you mean the battery is completely flat (for example, will not power the
radios), then It could be a problem with your charging system or the leads
to the battery.
Four prolonged start attempts with a very cold engine could easily drain a
very cold battery. How, if at all, do you preheat?
I have an Arrow IV, also with an IO-360. I have found that when the engine
is cold (and "cold" here in the Seattle area is pretty mild by your
standards) it likes a very healthy shot of priming. I leave the mixture
rich and the electric pump on until fuel pressure begins to register (it
takes maybe 7-8 seconds), then pull the mixture back and crank. Then it
usually starts without difficulty. I presume that you have studied the
start procedure shown in the manual. The most critical (and perhaps
counter-intuitive) thing to remember is that the mixture needs to be in full
LEAN (i.e. cutoff) position while cranking. You need to keep your right
hand on the mixture while you turn the key with your left hand so that you
can quickly move the mixture to full rich as soon as the engine begins to
fire.
believe.
The battery box in a normally aspirated Arrow is pretty tight -- not much
room for a larger battery. Weight and CG are also considerations.
-Elliott Drucker
Old January 27th 04, 12:02 PM
Ron Natalie
"O. Sami Saydjari" wrote in message ...
starts.
The other thing you may wish to look at is the cable between the
battery and the engine. I believe that a lot of the Cherokee's benefit
from having this replaced.
Of course, your other option is to get an APU cable for your plane.
Used to help the Saratoga in the next tie down start his plane on
cold mornings.
Old January 27th 04, 03:55 PM
Michelle P
Sami,
You can install a Concorde www.concordebattery.com CB-25, CB-25XC, RG-25
or RG-25XC.
1) Four attempted starts depends on how long you were trying. Most
starters have a 30 second continuous limit.
using that that is 2 full minutes of cranking. That would just about be
the limit for battery capacity.
2) Has your aircraft had the original battery cable (Aluminum in most
models) with the Bogert Copper Cable kit? This improves starting speed
and longevity.
3) Find a more open minded A&P Concorde recently modified the battery
cases so they will fit in the Piper Battery Box.
4) Place your battery on a Charger for an hour a day. Low current. A
standard appliance timer works fine.
5) Use a battery heater.
Michelle (A&P)
am a newbie for this particular plane), I would like to have a bit
more power in my battery, especially in very cold conditions such as
we have up here in central Wisconsin.
said that he tested it and that it was "fine."
G25 has only about 225 cold cranking amps. I noted that the G35S has
250 cold cranking amps.
believe.
has better cold cranking amps that the G25?
Thanks in advance.
Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P
"Elisabeth" a Maule M-7-235B (no two are alike)
Volunteer Pilot, Angel Flight Mid-Atlantic
Volunteer Builder, Habitat for Humanity
Old January 27th 04, 06:37 PM
Mike Rapoport
As others have noted, there a number of batteries STCed for your airplane.
I am not sure how your mechanic tested your battery but just testing the
specific gravity or voltage is not really an adequate test of starting
ability. There was a recent article in Aviation Consumer about the
differences between batteries. I hope that you are preheating the engine
before starting in the cold and if you have Tanis heaters, you can add a
battery heater which will help a lot.
MU-2
cold cranking amps.
believe.
Thanks in advance.
Old January 27th 04, 07:20 PM
G.R. Patterson III
or RG-25XC.
Are any of these going to give him more cranking power than the Gill?
George Patterson
Great discoveries are not announced with "Eureka!". What's usually said is
"Hummmmm... That's interesting...."
Old January 27th 04, 08:13 PM
MikeM
"Testing" the battery means making sure it is fully charged, then
discharging it using a known load current, timing how long it takes
the voltage to reach 11.5V, and then computing the capacity by
multiplying the time to reach 11.5V by the load current.
According to Gill & the FAA, your battery should be up to delivering
a load current representing all the stuff it takes to get safely on the
ground for 30 min: this should include engine instruments, fuel gauges,
electric gyros, radios, transponder and some lighting.
A guess for the essential electrical load on your aircraft would
be about 25A. To test the battery, connect a 12V/25A=0.48 Ohm,
12V*25A=300W resistor to the battery, and time how long it takes
the battery to reach 11.5V. If your battery wont hold up this
load for 30 min, then it should be replaced...
Cranking is a separate test. An automotive service-station type of
carbon-pile battery tester can be used to put a load of ~225A on
the battery for 3 or so minutes. If the battery peters out short of
3 min, then replace it.
MikeM
cold cranking amps.
believe.
Thanks in advance.
Old January 27th 04, 11:53 PM
O. Sami Saydjari
That is done, but good thought!
cold mornings.
I was hoping to avoid parasitism
Old January 27th 04, 11:59 PM
O. Sami Saydjari
Wow...thanks.
Michelle P wrote:
Sami,
or RG-25XC.
Gee, I wish my A&P knew this. Growl.
I see. OK. So, it sounds like 4 tries is about all I can expect, no
matter what battery I get?! Guess I need to get better at this starting
thing!
and longevity.
The new cable kit has been installed.
Good to know. Thanks.
This may be a bit awkward. My aircarft is in a communal hanger (hmmm,
sounds communist) and they need to move it around from time to time to
get to other aircraft.
Hmmm...I had not heard of those. Have you or anyone else on the
newsgroup had good experience with those? I wonder if I can somehow
link it to my (newly installed....just last week) Tanis heater?
Michelle (A&P)
