Effect of suction on DG
Old February 28th 04, 10:01 PM
Jay Honeck
Default Effect of suction on DG
In the last couple of months we have replaced both vacuum instruments (DG
and AI) as well as all vacuum hoses.
Immediately after this was done, I noticed our suction was lower than
before. It would top out in the 4.8 region -- at the very low end of the
acceptable scale.
At the same time we also noticed that our newly overhauled DG was precessing
excessively. It would precess 10 degrees every 15 minutes or so. Sometimes
less.
Before we pulled and returned the DG, I wanted to make sure that the lower
suction wasn't part of the problem, so today I had my A&P adjust the vacuum
regulator. It's now reading 5 at 2000 rpm, and almost 5.2 (the high end of
acceptable) at full throttle in a ground run. We left it at the high
setting to see where it settles out after a flight or two.
Question: Will this increase in vacuum help the DG's precession problem, or
is the DG toast?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old February 28th 04, 10:52 PM
Stu Gotts
There should be an acceptable range that will be listed in your
maintenance manual. I'm sure that being in the green at full throttle
will not be harmful to the gauge. Even vacuum a bit lower than the
green should be sufficient to spin the gyros. Check the lines for a
pinhole leak, which could also be introducing dirt into the
instruments. I won't give you the ol' "I told you so" about having a
recent instrument rebuilt just yet!
acceptable scale.
less.
is the DG toast?
Old February 29th 04, 04:24 PM
Doug Vetter
Jay Honeck wrote:
snip
acceptable scale.
less.
Jay,
Generally speaking, 4" of vacuum is sufficient to drive modern gyros,
and a properly functioning DG shouldn't precess any more than 5 degrees
every 15 minutes (which is a high rate of precession, but that's
apparently the number manufacturers use to determine warranty coverage).
My experience with two (properly functioning) Sigma Tek DG's is far
better -- around 3 degrees every 30 minutes, assuming we're not doing
pylon 8's.
I have noticed that even with ALL NEW parts in our vacuum system, before
the first flight of the day vacuum starts out at the top of the green,
particularly if it's cold outside ( 50 degrees). It then routinely
settles into the middle of the green for the remainder of the flight.
Don't ask me why that happens, but it does, and since everything is new
and otherwise works fine, I'd consider that normal.
I would suggest you make sure that your regulator is functioning
properly. Look very closely at the vacuum gauge while you increase RPM
slowly from idle / 1000 RPM. Vacuum should rise relatively quickly
until 1500-1800 RPM and then STOP, as if it hit a "peg".
If it rises further with RPM, even a few tenths, the regulator is worn
out and needs to be replaced. PMA'd examples are about $250. Don't go
back to Piper...they likely stock the OEM Airborne, and that lists for
about $950.
is the DG toast?
It's likely toast. It does happen...and it's not necessarily the
manufacturer's fault. If the DG is dropped in shipment or (worse)
dropped on the bench (even from a few inches), it can display the
symptoms you're reporting. IMO, gyro shipping boxes should display a
warning label like "Radioactive material in glass shipping
container...Handle with care". Maybe then they'd get the respect they
deserve.
One other item...have you swung the compass lately? Before you pull the
DG, do that (and not at the airpot rose...have your avionics shop use
their calibrated compass). That will reveal whether some or all of your
"precession" is actually "caused" by an inaccurate compass. I say this
because that's the first thing Sigma Tek asked my avionics tech when we
requested warranty service. It's apparently a common problem.
For the benefit of those who haven't seen it, check out the two-part
article I wrote about the fun we had with our 172's vacuum system.
Click through Aviation-Articles-Maintenance-50 Hour Inspection
-Doug
Doug Vetter, CFIMEIA
http://www.dvcfi.com
Old March 1st 04, 12:28 AM
Jay Honeck
Thanks, Doug (and everyone). We flew a couple of hours today, and the
vacuum is now consistently at 5.1.
I timed the precession of the DG in level flight, and it was five degrees
every 30 minutes -- MUCH better than before.
Of course, the temperature here was near 60 today -- about 45 degrees warmer
than when we noted the high precession rate. Did that have more to do with
it than the increased vacuum? Everything works better when it's warm, of
course.
I dunno. But it's good to have the problem licked, for now.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old February 29th 04, 04:45 PM
PaulaJay1
In article fd80c.433565$na.1039251@attbi_s04, "Jay Honeck"
writes:
acceptable scale.
With the Precise Flight Secondary Vacuum, they suggest that 3 inches will spin
the instruments. Where did you get the 4.8 and low end acceptable?
Chuck
Old March 1st 04, 12:25 AM
Jay Honeck
spin
It's in the Piper Service Manual.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old March 3rd 04, 01:12 PM
Jay Honeck wrote:
: With the Precise Flight Secondary Vacuum, they suggest that 3 inches will
: spin
: the instruments. Where did you get the 4.8 and low end acceptable?
: It's in the Piper Service Manual.
: Jay Honeck
: Iowa City, IA
: Pathfinder N56993
: www.AlexisParkInn.com
: "Your Aviation Destination"
... and typically on the nameplate of the (now installed) gyro. We just
overhauled our DG and AI last summer. Originally they sent a DG that had a different
acceptable range than the AI... (AI said 4.8-5.2, DG said 4.2-4.5). It jittered
anyway, so I sent it back for another. Now beautiful, matched, and a
water-manometer-calibrated regulator pegged at 5.00" The compass-thingy threw us too
though.
-Cory
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
The Meredith Effect Corky Scott Home Built 19 September 4th 04 04:01 PM
Did the Germans have the Norden bombsight? Cub Driver Military Aviation 106 May 12th 04 07:18 AM
Effect on aeroplane of sudden depressurisation Guy Lux General Aviation 9 February 23rd 04 06:30 PM
Wing in Ground Effect? BllFs6 Home Built 10 December 18th 03 05:11 AM
Great Lakes lake effect snow Paul Tomblin Instrument Flight Rules 30 October 21st 03 05:15 PM
