Effect on aeroplane of sudden depressurisation
Old February 5th 04, 02:39 PM
Guy Lux
Default Effect on aeroplane of sudden depressurisation
Often in films, when a plane flying at high altitude has its window
shot out, it seems to experience major turbulence and/or seem to dive
before it is stabilised.
I can't understand why a load of air rushing out of the pressurised
cabin would do this in *real* situations, does it actually happen?
Any explanations?
Guy
Old February 5th 04, 10:10 PM
Gene Seibel
The pilot will dive to bring the plane down to an altitude where
passengers can breathe without oxygen. But in a real situation there
should be no loss of control or severe turbulence.
Gene Seibel
Hangar 131 - http://pad39a.com/gene/plane.html
Because I fly, I envy no one.
(Guy Lux) wrote in message . com...
Any explanations?
Guy
Old February 6th 04, 07:27 AM
Troy Towner
In real life, the pressure in will stay constant, the pressure out will stay
very close to constant. There are valves called the outflow valve which is
basically a flute like on a Chimney. There are usually 2 on large transport
category aircraft. The Out flow valve open when there is too much pressure
in the fuselage, and closes to allow the air pressure to build up. So like a
gun shot through the thin skin... wont do anything....a few guns shot? ehh
maybe a noticeable difference, but there is always the airmasks. As long as
the roof don't rip off like the Aloha airlines B737-297.... you'll probably
be ok
anyway hope it helps
Troy
"Guy Lux" wrote in message
om...
Any explanations?
Guy
Old February 6th 04, 09:44 PM
Steven Polczynski
Hi People
I am an A&P student and read what was posted on the de-pressurization
question. You guys did well in answering Guy's question.
Orval: said that it might fog up. Well, If your talking about a slow
decompression no it won't but if it is a sudden decompression it will fog up
and there will be an immediate drop in temperature. And it if the plane is
high enough it can kill instantly. Auto pilot will not necessarily do
anything. ex. last year a Learjet crashed after it ran out of fuel. the
pressure release valve failed suddenly and the windows fooged over and the
crew died. the auto pilot kept the plane on course until it ran out of fuel
and crashed. No big chunks of fuselage suddenly ripped from the plane.
tony: I single gunshot can cause major damage or not depending on where it
penetrated the fuselage. If it goes through a window (depending on caliber)
it can make a small hole and eventually get worse or it can blow out the
whole windoe and cause major damage. unless there is major structural
damage that maintenance doesn't know about it still would not cause a gaping
7 foot hole. It might create a hole that would get worse at 700 MPH and it
would also decompress the cabin and fog up. the passengers next to the hole
would most likely die instantly. the masks would release but not everyone
would be alive to use them.
Obviously since I am not a Professional but merely a student in AMT school I
would not take my word as gospel. But I have gone through some classes that
covered such subjects. The learjet mentioned earlier was talked about in
class.
thanks
hope I didn't offend anyone
om...
Any explanations?
Guy
Old February 23rd 04, 06:25 PM
Michael Houghton
Howdy!
In article fXTUb.39070$L_4.14247@okepread01,
Steven Polczynski wrote:
Hi People
Ummm...not quite.
In fact, not close.
Instant death won't happen. Rapid incapacitation followed by death can
occur, but it takes some time. In the Payne Stewart incident (that you
probably allude to), the NTSB was unable to determine why the aircraft
lost cabin pressurization. Neither were they able to explain why the
crew were incapacitated by that loss of pressurization. The apparent
icing on the cockpit windows suggests a loss of bleed air (input) as
opposed to a "big leak". No evidence could be found to support any
specific conclusion about why the cabin lost pressure, nor any to permit
any inference about the rate of depressurization.
I recommend http://www.ntsb.gov/Publictn/2000/AAB0001.pdf highly.
yours,
Michael
Michael and MJ Houghton | Herveus d'Ormonde and Megan O'Donnelly
| White Wolf and the Phoenix
Bowie, MD, USA | Tablet and Inkle bands, and other stuff
http://www.radix.net/~herveus/
Old February 23rd 04, 06:30 PM
Tarver Engineering
"Michael Houghton" wrote in message
Howdy!
Hi People
up
is
fuel
Ummm...not quite.
In fact, not close.
That conclusion is silly, considering the maintenance on the Lear done
before the flight.
The Meredith Effect Corky Scott Home Built 19 September 4th 04 04:01 PM
For sale:1933 Avro 626 and 637 Aeroplane Sales Catalogues sam Military Aviation 0 July 9th 04 05:52 AM
Did the Germans have the Norden bombsight? Cub Driver Military Aviation 106 May 12th 04 07:18 AM
Wing in Ground Effect? BllFs6 Home Built 10 December 18th 03 05:11 AM
Origin of "aeroplane" Geoff May Military Aviation 18 July 4th 03 11:42 AM
