New type of Flight Recorder gains IGC-approval
Old August 31st 11, 06:21 AM posted to rec.aviation.soaring
Ian Strachan
Default New type of Flight Recorder gains IGC-approval
New type of Flight Recorder gains IGC-approval.
The SaFly GNSS Flight Recorder manufactured by the DSX company (www.d-
s-x.net), has gained IGC-approval with effect from 31 August 2011.
The approval level is for badge flights up to and including the three
Diamonds, and other flights that are covered by this level of IGC-
approval under rules for other flight performances such as
competitions. For IGC-approval levels, see para 1.1.4 of Annex B to
the Sporting Code for gliding. This Flight Recorder also includes a
satellite-based tracking system that enables its position to be
monitored by a ground station.
This brings the number of IGC-approved Flight Recorders to 49 types,
from 19 different manufacturers.
The IGC-approval document will be available on the FAI/IGC web page:
www.fai.org/gliding/IGC_approved_frs
Note: This may not be until about 15 September because the FAI web
pages are being completely revised after difficulties with web links
that followed the move of the FAI Secretariat to a larger office in
Lausanne. Meanwhile the document is available from or
from the GFAC Chairman at the email address below.
IGC-approval follows test and evaluation by the IGC GNSS Flight
Recorder Approval Committee (GFAC) in accordance with Annex B to the
Sporting Code for gliding and the Technical Specification for IGC-
approved GNSS Flight Recorders.
See:
http://www.fai.org/gliding/system/fi...1-3-31_al6.pdf
and http://www.fai.org/gliding/system/fi..._spec_gnss.pdf
After the FAI web page revision later this month, for a table of all
existing IGC-approval documents, see:
http://www.fai.org/gliding/system/fi...proved_frs.pdf
Note: Due to the difficulties on the FAI web pages mentioned earlier,
the link to this document is currently not available but will be
restored after about 15 September when the new FAI web pages are
expected to be on-line.
This document is in PDF document and contains:
(1) a table of all types of IGC-approved Flight Recorders, in
alphabetical order of manufacturer name
(2) a table of Manufacturers, in alphabetical order of manufacturer
name
(3) a list of all IGC-approval activity from 1996 to the present day
(4) a short history of IGC GNSS Flight Recording
Ian Strachan
Chairman, IGC GNSS Flight Recorder Approval Committee
Additional information:
For all IGC-approval documents, see:
At the bottom of this page, there are links to the following IGC-
approval documents.
aircotecxc.pdf 53.92 KB
cambridge10_20_25.pdf 68.53 KB
lxncolibri.pdf 102.44 KB
lxnlx7000.pdf 193.47 KB
nteeasy.pdf 69.11 KB
ntematchbox.pdf 105.53 KB
peschges.pdf 46.48 KB
ptechnik.pdf 46.93 KB
sdiposigraph.pdf 179.44 KB
themit3.0.pdf 253.6 KB
zander941.pdf 51.29 KB
garrecht.pdf 101.01 KB
lxndx50.pdf 95.73 KB
lxnlx20.pdf 110.92 KB
lxnlx21.pdf 97.23 KB
flarm-igc.pdf 105.95 KB
lxnlx8000.pdf 117.36 KB
imierixx.pdf 108.43 KB
ediatececw100f.pdf 100.54 KB
dsx.pdf 94.5 KB
ew-micro.pdf 101.72 KB
triadis_altair.pdf 95.25 KB
nkl_cn.pdf 97.18 KB
lxnlx5000.pdf 106.85 KB
Zander940.pdf 84.95 KB
ew.pdf 283.86 KB
ew_annex_c.pdf 130.07 KB
lxnlx9000.pdf 235.33 KB
lxnminibox.pdf 222.15 KB
lxnredbox.pdf 220.63 KB
LXNAV_Nano.pdf 237.84 KB
tech_spec_gnss.pdf 801.71 KB
cambridge302.pdf 110.08 KB
lxnlx8080f.pdf 174.49 KB
igc_approved_frs.pdf 178.96 KB
tech_spec_gnss.pdf 907.58 KB
al1_tech_spec_gnss.pdf 151.82 KB
All owners of IGC-approved flight recorders are encouraged to download
the current IGC-approval document for their type of recorder.
If you have any comments and/or corrections, please email the GFAC
Chairman on:
Ian Strachan
Chairman IGC GNSS Flight Recorder Approval Committee (GFAC)
IGC-approval of the LXNAV Nano GNSS Flight recorder Ian Strachan Soaring 5 September 1st 10 02:41 PM
IGC-approval for Nielsen Kellerman ClearNav GNSS Flight Recorder Ian Strachan Soaring 2 May 26th 09 03:45 PM
New IGC-approval for GNSS Flight Recorder Ian Strachan Soaring 0 February 14th 09 08:00 PM
IGC-approval issued for Aircotec GPS Flight Recorder Ian Strachan Soaring 0 May 30th 06 11:47 PM
IGC-approval for new type of recorder - NTE Easy Matchbox Ian Strachan Soaring 0 August 8th 05 10:34 AM
