IGC-approval for Nielsen Kellerman ClearNav GNSS Flight Recorder
Old May 25th 09, 05:57 PM posted to rec.aviation.soaring
Ian Strachan
Default IGC-approval for Nielsen Kellerman ClearNav GNSS Flight Recorder
IGC-approval for Nielsen Kellerman ClearNav GNSS Flight Recorder.
I have pleasure in announcing that IGC-approval for "all flights" has
been
given to the Nielsen Kellerman ClearNav-IGC GNSS Flight Recorder,
effective 25 May 2009.
This follows test and evaluation by the IGC GNSS Flight Recorder
Approval
Committee (GFAC) in accordance with Annex B to the Sporting Code and
the Specification for IGC-approved GNSS Flight Recorders.
The IGC-approval document will appear on the IGC GNSS web site
shortly,
together with the manufacturer's DLL file for use with the IGC Shell
program for the Validation of IGC files produced by this type of
recorder.
The IGC-approval only applies to the IGC version of this recorder,
with the
firmware standard as given in the IGC-approval document. Earlier
versions
of the ClearNav that are currently in service are not included in this
IGC-
approval, although it is understood that they can be updated to the
IGC
standard by application to the manufacturer or his official agents.
This brings the number of IGC-approved GNSS Flight Recorders to 45
types, from 18 different manufacturers.
For details of all of the existing IGC-approval documents, see:
http://www.fai.org/gliding/system/fi...proved_frs.pdf
By clicking the link "List of IGC-approved FRs" a PDF document will
be
produced with:
(1) a table of all types of IGC-approved Flight Recorders,
(2) a table of Manufacturers,
(3) a list of all IGC-approval activity since 1996, and
(4) a short history of IGC GNSS Flight Recording.
However, please note that it has been found that the links to the
individual
IGC-approval documents in the tables in the above PDF document do not
work in Internet Explorer.
Links have therefore been added to the bottom of the page when you
first
go to:
http://www.fai.org/gliding/gnss
At the bottom of this gliding/gnss page, there are links to the
following
IGC-approval documents.
aircotecxc.pdf
cambridge10_20_25
cambridge302.pdf
dsx.pdf
ediatececw100f.pdf
ew.pdf
ew-micro.pdf
flarm-igc.pdf
garrecht.pdf
igc_approved_frs.pdf
imierixx.pdf
lxncolibri.pdf
lxnlx20.pdf
lxnlx21.pdf
lxndx50.pdf
lxnlx5000.pdf
lxnlx7000.pdf
lxnlx8000.pdf
lxnminibox.pdf
lxnredbox.pdf
nteeasy.pdf
ntematchbox.pdf
peschges.pdf
ptechnik.pdf
sdiposigraph.pdf
themit3.0.pdf
triadis_altair.pdf
zander940.pdf
zander941.pdf
All owners of IGC-approved flight recorders are encouraged to download
current IGC-approval document for their type of recorder.
If you have any comments and/or corrections, please email the GFAC
Chairman.
Ian Strachan
Chairman, IGC GNSS Flight Recorder Approval Committee
Old May 26th 09, 03:19 PM posted to rec.aviation.soaring
Paul Remde
Hi,
Below is a note from NK regarding the ClearNav's IGC Approval.
Best Regards,
Paul Remde
___________________________
I am very pleased to announce that on May 25th the ClearNav was granted IGC
approval for "all flights". All ClearNavs except ones shipped last week will
need to be returned to the factory for upgrade to this standard. Production
units need to have the ENL (engine noise level) circuit adjusted to the IGC
standard and the latest firmware (v30) loaded. First Flight units require up
to four hardware ECO's (engineering change orders) depending on there date
of purchase, ENL and altitude calibration, assignment of a serial number,
electronic sealing and firmware upgrade to v30.
Please return the unit at your convenience by filling out the RA (Return
Authorization) at the link below and shipping to us. We will make every
effort to return it to you in a timely way. My turnaround goal is 1-2
business days. gk
https://www.nkhome.com/ra/ra.php
Gary Kammerer
Soaring Technical Sales Manager
NIELSEN-KELLERMAN
NK Rowing Electronics / NK Soaring Instruments / Kestrel Weather Meters
21 Creek Circle, Boothwyn, PA 19061 USA
610.447.1555 x308 * 610.447.1577 Fax
* www.nkhome.com
"Ian Strachan" wrote in message
been
Approval
shortly,
recorder.
with the
versions
IGC-
IGC
be
produced with:
individual
first
go to:
following
aircotecxc.pdf
cambridge10_20_25
cambridge302.pdf
dsx.pdf
ediatececw100f.pdf
ew.pdf
ew-micro.pdf
flarm-igc.pdf
garrecht.pdf
imierixx.pdf
lxncolibri.pdf
lxnlx20.pdf
lxnlx21.pdf
lxndx50.pdf
lxnlx5000.pdf
lxnlx7000.pdf
lxnlx8000.pdf
lxnminibox.pdf
lxnredbox.pdf
nteeasy.pdf
ntematchbox.pdf
peschges.pdf
ptechnik.pdf
sdiposigraph.pdf
themit3.0.pdf
triadis_altair.pdf
zander940.pdf
zander941.pdf
Chairman.
Ian Strachan
Old May 26th 09, 03:45 PM posted to rec.aviation.soaring
Paul Remde
Hi,
One additional note for NK ClearNav owners - When you send your ClearNav
back for upgrade, you need only send the ClearNav display. It is not
necessary to send the Nexus Junction Board or Nexus Junction Box or any
other accessories.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Paul Remde" wrote in message
Hi,
Best Regards,
Paul Remde
IGC approval for "all flights". All ClearNavs except ones shipped last
week will need to be returned to the factory for upgrade to this standard.
Production units need to have the ENL (engine noise level) circuit
adjusted to the IGC standard and the latest firmware (v30) loaded. First
Flight units require up to four hardware ECO's (engineering change orders)
depending on there date of purchase, ENL and altitude calibration,
assignment of a serial number, electronic sealing and firmware upgrade to
v30.
business days. gk
Gary Kammerer
NIELSEN-KELLERMAN
* www.nkhome.com
been
Approval
shortly,
recorder.
with the
versions
IGC-
IGC
be
produced with:
individual
first
go to:
following
aircotecxc.pdf
cambridge10_20_25
cambridge302.pdf
dsx.pdf
ediatececw100f.pdf
ew.pdf
ew-micro.pdf
flarm-igc.pdf
garrecht.pdf
imierixx.pdf
lxncolibri.pdf
lxnlx20.pdf
lxnlx21.pdf
lxndx50.pdf
lxnlx5000.pdf
lxnlx7000.pdf
lxnlx8000.pdf
lxnminibox.pdf
lxnredbox.pdf
nteeasy.pdf
ntematchbox.pdf
peschges.pdf
ptechnik.pdf
sdiposigraph.pdf
themit3.0.pdf
triadis_altair.pdf
zander940.pdf
zander941.pdf
Chairman.
Ian Strachan
New IGC-approval for GNSS Flight Recorder Ian Strachan Soaring 0 February 14th 09 08:00 PM
IGC-approval document issued for NT Easy GNSS recorder Ian Strachan Soaring 0 January 10th 07 09:31 PM
Updates to IGC approval documents for GNSS flight recorders Ian Strachan Soaring 2 September 27th 04 01:32 PM
Date of effect now 1 April 2004 for revised IGC-approval for certain legacy types of GNSS flight recorder Ian Strachan Soaring 56 December 2nd 03 08:08 AM
New and updated IGC-approval documents for GNSS Flight Recorders Ian Strachan Soaring 0 November 25th 03 05:55 PM
