Repairing philliform corrosion
Old October 1st 04, 07:52 PM
Ed Pauls
Default Repairing philliform corrosion
What is the best way stop it, get it off and recoat the affected areas.
Ed
Old September 30th 04, 09:57 PM
Orval Fairbairn
In article , Ed Pauls
Ed
You have to remove all paint from the affected area, remove the
corrosion (Aluminum Jelly works), thoroughly clean the area, including
degrease, Alodyne (optional), prime with self-etching primer, repaint to
match.
Old October 1st 04, 03:56 AM
Get a HARD copy of 43.13 and do it correctly and understand what and why
you are doing it.
It will be the best $20.00 you will ever spend as an aircraft owner.
Dave
Ed
match.
Old October 2nd 04, 09:08 PM
Thomas Lembessis
The January, 1991 issue of Light Plane Maintenance had a good article on
Filiform Corrosion.
"Ed Pauls" wrote in message
Ed
Naval Air Refueling Needs Deferred in Air Force Tanker Plan Henry J Cobb Military Aviation 47 May 22nd 04 03:36 AM
Non Chromate Anti Corrosion and Paint Prep X-it Prekote? All Thumbs Home Built 7 May 5th 04 04:21 PM
Corrosion Protection on Alluminum Sheet Aircraft? DL152279546231 Home Built 6 February 10th 04 05:10 AM
How much corrosion is too much? Carl Orton Owning 5 February 2nd 04 01:31 AM
Corrosion X Applicators Hankal Owning 5 July 7th 03 06:07 PM
