Corrosion X Applicators
Old July 5th 03, 12:40 AM
Hankal
Default Corrosion X Applicators
Corrosion X applicators.
Some shops just mist or fog Corrosion X into the fuselage.
Others will use long wands and spray it into the wings.
Which is better or which is recommended by the manufacturer?
Hank N1441P
Old July 5th 03, 03:29 AM
Doug
Boseal, a new product is better than Corrosion X. When it dries, it leaves a
wax, much like thin Cosmoline. The idea is to have the oil penetrate joints.
So brush it on, swab it on, spray it on, it doesn't matter so long as it
goes where it is supposed to.
"Hankal" wrote Corrosion X applicators.
Hank N1441P
Old July 7th 03, 03:32 PM
Ron Natalie
"Doug" wrote in message ...
You mean Boeshield? (T-9). Not exactly new.
Old July 7th 03, 05:55 PM
Doug
Well it's new to me. And I think it's better. If you want long lasting
protection, that is. Leaves wax.
leaves a
joints.
Old July 7th 03, 06:07 PM
Javier Henderson
I've read that one negative about Boeshield is that it's not as good
as penetrating lap joints as Corrosion X is.
I believe Mike Busch had an article about his on his monthly colum
in the CPA magazine.
-jav
"Doug" writes:
leaves a
joints.
Naval Air Refueling Needs Deferred in Air Force Tanker Plan Henry J Cobb Military Aviation 47 May 22nd 04 03:36 AM
Non Chromate Anti Corrosion and Paint Prep X-it Prekote? All Thumbs Home Built 7 May 5th 04 04:21 PM
Corrosion Protection on Alluminum Sheet Aircraft? DL152279546231 Home Built 6 February 10th 04 05:10 AM
