OOPS! Got contact cement on the windshield
Old November 13th 04, 04:57 AM
Mike Rapoport
Default OOPS! Got contact cement on the windshield
I managed to get some 1300L contact cement on the windshield of my Helio
Courier while reattaching the vinyl to the glareshield. Does anyone know if
I can use "adhesive remover" on an acrylic windshield without causing
crazing? Any other suggestions? Thanks!
Mike
MU-2
Old November 13th 04, 12:59 PM
Kyle Boatright
The best product I've found for removing glue, paint, and other stuff from
plexi is one of the citrus based cleaners. No solvents, and the stuff does a
fairly good job attacking a surprising number of things. Personally, I
wouldn't want to use any solvent near that expensive windscreen.
KB
"Mike Rapoport" wrote in message
hlink.net...
if I can use "adhesive remover" on an acrylic windshield without causing
Mike
MU-2
Old November 13th 04, 11:13 PM
Mike Rapoport
I will try some citris cleaner on contact cement and then try it on
plexiglass if the "tedious fingernail method" doesn't work.
Mike
MU-2
"Kyle Boatright" wrote in message
a fairly good job attacking a surprising number of things. Personally, I
KB
hlink.net...
Mike
MU-2
Old November 13th 04, 01:40 PM
Jim Burns
Mineral spirits??? Rubbing alcohol? Brake Parts cleaner? If there is a
mechanic on your field, ask him for a scrap piece of glareshield and give it
a try.
hlink.net...
if
Mike
MU-2
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.788 / Virus Database: 533 - Release Date: 11/1/2004
Old November 13th 04, 01:45 PM
Roger Long
I have the old windshield from our 172 in the back yard serving as a
basement window shelter. If you would like me to try anything on it for a
final check, email me directly. I'll even put some contact cement on it.
Roger Long
hlink.net...
Mike
MU-2
Old November 13th 04, 11:11 PM
Mike Rapoport
Thanks! I think that I will try picking it off before trying chemicals but
if that fails I will give you some stuff to try!
Mike
MU-2
"Roger Long" wrote in message
Roger Long
hlink.net...
Mike
MU-2
Old November 13th 04, 03:43 PM
zatatime
On Sat, 13 Nov 2004 04:57:20 GMT, "Mike Rapoport"
Mike
MU-2
Can you keep the area very wet for a long period of time? I'm
thinking covered with wet paper towels, and wait a while for the
adhesive to soften up so you can use your finger to pick it off.
If that won't work, I know either Sporty's or Spruce sells a
"Windshield Compounding" kit. It comes with different "grit" sponges
and 3 or 5 separate compounds. You'll probably have to do the whole
windshield, but at least it should get the junk off it.
HTH.
z
Old November 13th 04, 11:10 PM
Mike Rapoport
Thanks. I think that I will try the fingernail method first. The glue is
down where the windshield meets the glareshield so it would be difficult to
polish.
Mike
MU-2
"zatatime" wrote in message
if
Mike
MU-2
HTH.
z
Old November 13th 04, 04:31 PM
Rutger
"Mike Rapoport" wrote in message thlink.net...
Mike
MU-2
Any adhesive remover probably has solvent in it that will cause even
more damage. The contact cement has solvent in it too, that probably
melted the plexiglas underneath the glue. Best bet would be to simply
wait for it to completely dry and then pick it off with your
fingernail (tedious frustrating process) and then repair the
underlying damage with a MicroMesh polishing kit.
Old November 13th 04, 06:27 PM
Ron Natalie
Many contact cements after they set up can just be rubbed off the window
with a thumb or thumbnail (or a plastic scraper like an old credit card).
windshield wipers tony roberts Owning 8 June 1st 04 02:45 AM
Arrgh! I may have scratched my windshield! Peter R. Owning 7 April 28th 04 07:58 AM
Radar contact before squawk David Brooks Instrument Flight Rules 20 March 25th 04 01:34 AM
Contact myplane Marvin B. Schumer Owning 1 January 26th 04 05:13 AM
Windshield sealant Mike Noel Owning 10 October 2nd 03 01:04 AM
