Usually the hand on my ammeter bounces for a few moments while taxing
and then settles down at about 20 amps. Yesterday it continued to be erratic with a few calm moments with the hand indicating 10 amps. The ammeter has 1976 stamped on the back. Do these things ever wear out? Is there any way to bench test one? I need a few opinions, what is the most likly culprit - ammeter, regulator or alternator? Thanks Leo |
We had the problem of bouncing loadmeter needle in our 74 Archer. It came
and went, but it bothered everyone because no one could guarantee that it wasn't a sign of impending trouble, even though a lot of people told us that many, many Cherokees have that problem. We found a lot of potential fixes in various places on the internet. One of the recommendations was to change the regulator for a solid state one. One of our partners said this was too much and that we should clean all the contacts before we invest in a new regulator. So he and another partner spent most of a Saturday cleaning all the contacts, including some in the alternator. When they put it back together, there was no charging at all. Then they discovered that the extra washer they had when they were done was an insulating one, and that they had shorted the field winding to ground. This had fried the (solid state) regulator, so nothing worked even after putting the washer back where it belonged. So finally, they turned it over to the A&P who reassembled the alternator, replaced the regulator (with a solid state one, again), and checked everything out. Everything now works perfectly. No needle bounce, rock solid. Unfortunately, we will never know if the problem was the regulator, a loose connection, or dirty contacts. We're also a few hundred $$'s poorer. -- Bob (Chief Pilot, White Knuckle Airways) I don't have to like Bush and Cheney (Or Kerry, for that matter) to love America "Bob Noel" wrote in message ... In article , (Leo) wrote: Usually the hand on my ammeter bounces for a few moments while taxing and then settles down at about 20 amps. Yesterday it continued to be erratic with a few calm moments with the hand indicating 10 amps. The ammeter has 1976 stamped on the back. Do these things ever wear out? Is there any way to bench test one? I need a few opinions, what is the most likly culprit - ammeter, regulator or alternator? Thanks Leo from the Cherokee hints & tips, there are several potential causes. Most are related to loose connections or corroded connections (the connection heats up, becomes open, cools off and closes). The time I had a bouncing ammeter, it was caused by a bad master switch. Checking and cleaning all the connections is the cheapest first step in troubleshooting this (assuming you are doing it) rather than trying to isolate the problem by swapping out the ammeter, regulator, or alternator. -- Bob Noel |
![]() The Ammeter on my 75 Warrior used to bounce all over the place and after I replaced the voltage regulator it went away. As others have pointed out loose connections are also a likely culprit. FWIW - the voltage regulator was in the neighborhood of $100. -Brian N33431 "Leo" wrote in message m... Usually the hand on my ammeter bounces for a few moments while taxing and then settles down at about 20 amps. Yesterday it continued to be erratic with a few calm moments with the hand indicating 10 amps. The ammeter has 1976 stamped on the back. Do these things ever wear out? Is there any way to bench test one? I need a few opinions, what is the most likly culprit - ammeter, regulator or alternator? Thanks Leo |
My AMP meter in my old Arrow would bounce as well only when the strobes
were turned on (Whelan Comet Strobes) otherwise it was rock solid. Maybe you have a current drain, or a loose connection someplace? Leo wrote: Usually the hand on my ammeter bounces for a few moments while taxing and then settles down at about 20 amps. Yesterday it continued to be erratic with a few calm moments with the hand indicating 10 amps. The ammeter has 1976 stamped on the back. Do these things ever wear out? Is there any way to bench test one? I need a few opinions, what is the most likly culprit - ammeter, regulator or alternator? Thanks Leo |
Fuel dip tube for Piper Warrior? | TTA Cherokee Driver | Owning | 16 | May 3rd 04 05:42 PM |
Warrior POH | Michael Egan | Owning | 2 | February 4th 04 05:41 PM |
Warrior Strobe Tube Replacement | Jerry Malin | Owning | 3 | September 29th 03 04:02 AM |
