Warrior Strobe Tube Replacement
Old September 29th 03, 12:49 AM
Jerry Malin
Default Warrior Strobe Tube Replacement
Gang:
One of the wingtip strobes on our 1982 Warrior II looks like it is going
bad. Half of it looks black and it only gives one blink per second while the
other wing gives two blinks per second.
I was perusing the Whelen catalog, and our strobe lamp assembly appears to
have a pigtail terminating in a three pin Molex connector.
My question is, how much fishing will I have to do to get to the end of that
pigtail? Will I have to remove the wingtip, or can I reach it through the
bulb socket assembly?
Thanks for any insight,
Jerry Malin,
Warrior N82045
Old September 29th 03, 04:37 AM
Craig
"Jerry Malin" wrote in message hlink.net...
Gang:
Should come right out when you remove the socket assembly....most
likely two or three small screws and it will fall off in your hand.
Getting only a single flash from the tube might not be a tube
problem...more likely a power supply problem. I'd get it tested before
replacing a tube.
Craig C.
Old September 29th 03, 04:55 AM
No Spam
hlink.net...
Gang:
replacing a tube.
Craig C.
To check the power supply, switch the leads coming out of it and going to
the wingtip units. If the problem moves to the other wingtip, the power
supply is the source of it.
No Spam
Old September 29th 03, 05:02 AM
G.R. Patterson III
replacing a tube.
I wouldn't. Since half the tube is black, the tube is definitely bad. Test the
power supply by replacing the tube.
George Patterson
The British drink warm beer because they all own Lucas refrigerators.
Rag and tube construction and computer models? BllFs6 Home Built 24 April 12th 04 01:20 PM
Why 4130 tube? Leon McAtee Home Built 31 March 28th 04 04:04 PM
Pitts Special Steel Tube Fuse Mod. Martin Morgan Home Built 0 November 24th 03 12:08 AM
Chuck Yeager-pitot tube Ron Military Aviation 44 October 9th 03 04:13 AM
Is a cracked vent SCAT tube an urgent problem? Ben Jackson Owning 18 September 20th 03 04:31 AM
