i really need to start this by saying i know absolutely nothing new or
bad about any aircraft. i'm sure not trying to start any rumors. in fact, this may be something that y'all have already chewed on but... the outfit i rent from is just down the taxiway from "air aces" at houston-hooks where they've had a horrible time with wings coming off airplanes lately. in talking about that, one of the people at my base....not at "aces"... told me they have been hearing about faa looking into a structural problem with c-152 rudders. since they've got several and since i'm almost certainly going to be buying one in the next few months we're kinda curious about what might be going on. anybody??? dan |
"aces"... told me they have been hearing about faa looking into a structural problem with c-152 rudders. since they've got several and since i'm almost certainly going to be buying one in the next few months we're kinda curious about what might be going on. Of the thousands that have been built and flown hard as trainers, a few dozen have developed some cracks that were found on inspections (not by the tail coming off - that never happened on any C-150 or C-152) and there's going to be an inspection required for cracks (may already be out) on a periodic basis. This type of AD is very common on all-metal airplanes and not a big deal. BTW - you should consider the Tomahawk if you are in the market for a C-152. Generally more bang for the buck, roomier, better visibility, carries more fuel, and a bit faster. Not as good for soft/rough fields though. Michael |
tomahawk??? ya got me....i'll google it. thx
dan |
Oh, the Trauma-hawk. If there has ever been a plane plagued with AD's up
the ass, this is the one. -- www.geocities.com/ralphsnart2004/index.html "houstondan" wrote in message oups.com... tomahawk??? ya got me....i'll google it. thx dan |
ok, i found the tomahawk. nope, living in houston, i just think the
sun beating down on me thru that bubble would be too much. i've talked to people here who say it's pretty bad. it does look like a great a/c tho. dan |
sun beating down on me thru that bubble would be too much. Your call, of course, but before you make the decision, you might drive on over to Pearland Regional (formerly Clover) and fly one of Mike King's when summer comes around. I've never found it to be a problem because on the ground it's easy to keep the doors open, and once airborne the ventilation is excellent. I've seen Tommy's with low time engines and airframes and good IFR panels going for $20K. Michael |
i'll check it out. do apppreciate the input.
dan |
The vertical fin on a C-150 is held on to the fuselage with a welded
steel bracket riveted into the aluminum structure. The welds are in the corners where the stress is highest. The steel undergoes galvanic corrosion when it is close to aluminum. These aircraft are being used well beyond their original intended lifetime and this steel fitting was cracked in the welds on the two 150s I'm familiar with. I thought it was a recent AD or at least a recent service letter. They were certainly not airworthy. This should be checked at annual on any 150 since it is an area of known service difficulty. The 172s don't have this problem with the bracket as it is an aluminum forging - not prone to corrosion. It would be one thing to lose a rudder, but losing both the rudder and vertical fin would be pretty exciting. It would be even worse if the rudder cables kept the separated surfaces attached to the rest of the airplane. |
![]() "houstondan" wrote in message oups.com... i really need to start this by saying i know absolutely nothing new or bad about any aircraft. i'm sure not trying to start any rumors. in fact, this may be something that y'all have already chewed on but... the outfit i rent from is just down the taxiway from "air aces" at houston-hooks where they've had a horrible time with wings coming off airplanes lately. in talking about that, one of the people at my base....not at "aces"... told me they have been hearing about faa looking into a structural problem with c-152 rudders. since they've got several and since i'm almost certainly going to be buying one in the next few months we're kinda curious about what might be going on. anybody??? dan Check out the following link: http://www.tc.gc.ca/CivilAviation/Sy...8/4-00/536.htm It seems if the rudder stop is deformed, it is possible that when you go to full rudder deflection, to catch on the deformed rudder stop, which locks the rudder hard-over. Moral: make sure the rudder stops are properly set and in good structural condition. FAA has been contemplating an AD for a while. Just be proactive. Make the rudder stops and the lower rudder horns a walk-around item. J. Severyn |
excellent help...thx
dan |
B2 Split Rudder | Emilio | Military Aviation | 8 | April 12th 04 10:43 AM |
P-51 Rudder Aerodynamics | Hawkeye Hughes | Home Built | 1 | March 15th 04 09:24 AM |
rudder cable question | Bob Loer | Home Built | 7 | November 26th 03 08:34 AM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
Rudder cable - was The Little Wheel in Back | BD5ER | Home Built | 9 | September 11th 03 04:14 PM |
