rudder cable question
Old November 25th 03, 07:53 PM
Bob Loer
Default rudder cable question
The tail dragger I am building shows a closed loop rudder cable system. That
is to say both front pedals are joined by a cable that loops around a pulley
in front of the control stick on the floor. There are also pedal return
springs.
Is this extra weight and complexity needed? What is the advantage or
disadvantage? One point that my be pertinent is the rudder cable branches
off with a lower cable to the tail wheel just after it exits the fuselage.
Any thoughts appreciated.
Robert Loer
LM-5X-W
Southern Oregon
Old November 25th 03, 10:27 PM
Rich S.
"Bob Loer" wrote in message
That
pulley
springs.
My Emeraude plans show the same arrangement, but after looking over the
setup on a friend's RV-4 I decided to save the weight and complexity. I
haven't found any down side to not having them closed loop. (Wow! a triple
negative!)
Rich S.
Old November 25th 03, 10:53 PM
Frank
The springs are prolly for feel or extra pedal force.
Old November 26th 03, 02:44 AM
springs.
Without the return cable, your pedals may flop backwards due to the weight
of the rudder cables and the ground attitude. If there's no stop, you may
end up with them falling flat on the floor if you take your feet off them.
A little tough to get back upright.
Some light springs (or just a limit cable) would do the trick.
The springs on my airplane are kind of weak, so the cables go a bit slack
when the plane is sitting on the ground. I regularly have people come up
and "warn" me that there's something wrong with my rudder cables....
Old November 26th 03, 02:53 AM
Rich S.
"Ron Wanttaja" wrote in message
Toe brake linkage will also act as a limit.
Rich S.
Old November 26th 03, 02:56 AM
Phil
I remember during my first solo circuit many years ago a twin cut across in
front of me on downwind. I stomped on the brakes so hard that if the
Cherokee hadn't had something similar, I swear I would have torn the control
horns off the rudder.
Phil Maley
Perth Australia
Old November 26th 03, 04:54 AM
David O
Phil Maley
Perth Australia
Along similar lines, my first attempt to taxi an airplane found me
weaving back and forth across the taxiway as I tried to steer with the
yoke. Yes, I knew to use the rudder pedals to steer but that didn't
stop me from going to the yoke on several occasions early on.
David O -- http://www.AirplaneZone.com
Stupid super cub question Robert Loer Home Built 9 November 22nd 03 06:28 PM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 02:51 AM
Rudder cable - was The Little Wheel in Back BD5ER Home Built 9 September 11th 03 05:14 PM
Question on Pulsejets/Ramjets??? DarylG1532 Home Built 3 August 16th 03 04:20 AM
Brake line design question Charlie Smith Home Built 0 July 2nd 03 01:31 PM
