gliding back to your departure airport
Old October 21st 03, 09:02 PM
Harold
Default gliding back to your departure airport
If a small single engine plane can out-climb its engine-out glide ratio from
take off through the top of climb point, wouldn't it follow that it can
always theoretically make it back to the departure airport in the event of
engine failure ? Assuming straight out departure, no wind, and the altitude
loss in the 180 turnback is offset by the runway portion you didn't use. If
my best glide is 85 KTAS and it loses 700 fpm at that speed, shouldn't I be
guaranteed I can make it back if I climb at 84 KTAS and 701 fpm ?
Old October 21st 03, 09:27 PM
Roger Tracy
This is a good thing to test at altitude and know ahead of time. There's
going to be a certain height AGL that you just can't get turned around.
You should know what that is for your plane.
"Harold" wrote in message
from
altitude
If
be
Old October 22nd 03, 05:06 AM
Newps
There was a good article by Barry Schiff last year in AOPA Pilot about
this. I went out and tried it in my 182. I had originally thought that
you would need a healthy shove forward on the controls to keep from
stalling. This is not the case, the plane will simply nose down to
maintain the trimmed airspeed. I need 200 feet to complete a 180 and
another 150 feet to get back to the departure runway. That is only
using a 45 degree bank, the article shows that 60 degrees is optimal.
from
altitude
If
be
Old October 22nd 03, 04:27 PM
Wolfgang K.
"Newps" schrieb im Newsbeitrag
news:qnnlb.838361$YN5.947383@sccrnsc01...
this. I went out and tried it in my 182. [schnipp]
i'd be interested in the article - any link to that?
regards from loww, vie, vienna, austria
wolfgang
Old October 21st 03, 09:36 PM
Roger Long
Altitude loss to get a 172 turned around after practice is about 600 feet.
If the pilot is surprised, panicked, or out of practice, it will be more.
If the pilot it very surprised, panicked, and out of practice, it may be
exactly equal to the altitude the maneuver was started at when he stalls due
to a combination of too much bank and pull on the yoke.
Roger Long
Old October 21st 03, 09:42 PM
Bob Gardner
Keep in mind that it will not be a 180 degree turn but more like 210 degrees
(unless you plan to make your power-off landing parallel to runway surface).
There have been many, many studies of the "Impossible Turn." Google that
term and you will learn a lot.
Bob Gardner
from
altitude
If
be
Old October 21st 03, 09:46 PM
Harold
Well obviously, but I'm not talking about in the pattern area like the
Impossible Turn is. I'm talking about 10 minutes after departure at 7k feet
where the departure airport, if you can make it, is the best landing option.
Then for all intents and purposes its a 180 degree turn.
degrees
surface).
Bob Gardner
from
of
altitude
If
be
Old October 21st 03, 10:00 PM
Peter Duniho
feet
option.
To my knowledge, no one has ever said you can't. Other than aircraft that
cannot climb as steeply as they descend (and there are a number of aircraft
that are like that), obviously after a 10 minute climb, it would be very
likely you could make it back to your original departure airport.
I would never say "guaranteed". Other than aircraft performance, there are
still other reasons you wouldn't be able to make it. For example, climbing
with a tailwind will hinder your ability to make it back to the airport
(just because you take off into the wind, that doesn't mean you'll be
climbing out into the wind, even if you depart straight out).
So, a literal answer to your question is "no", you cannot guarantee that you
can make it back. However, it's true that for many aircraft, once you've
climbed that far, the original departure airport is often going to be a very
good choice for an emergency landing site, at least shortly after takeoff.
Does *that* answer your question?
Pete
Old October 21st 03, 11:00 PM
Bob Gardner
That wasn't implicit in your post (although "top of climb" is a heck of a
hint). Most such questions deal with failure during the initial climb.
Bob Gardner
feet
option.
degrees
surface).
Bob Gardner
ratio
from
can
event
of
altitude
use.
If
I
be
Old October 22nd 03, 07:30 PM
John Galban
"Harold" wrote in message ...
Absolutely. As long as you have continued climbing at a higher rate
than the descent will be.
About 2 years ago I got to practice this. On an early morning
takeoff for a 300 mile cross-country flight, the OAT was cool and the
plane was light, so I climbed out at 900 ft./min. to reach my cruising
altitude quickly. At around 9K ft. the engine got real loud and I
realized I had broken something in the exhaust. I shut down the
engine so as not to catch the cowl on fire. I was 6 miles away from
the airport and knew I had climbed at much better than the 750 ft./min
descent rate, so the return glide was really a no-stress event. When
I got back to the pattern, I actually had about 1K ft. too much
altitude and had to circle to lose it before deadsticking on to the
same runway I had departed.
Historic Helsinki-Malmi Airport in trouble - please read Seppo Sipilä General Aviation 0 December 24th 04 09:04 AM
STAR to nearby airport Viperdoc Instrument Flight Rules 33 May 13th 04 10:48 PM
The battle for Arlington Airport begins? Paul Adriance Home Built 45 March 30th 04 11:41 PM
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! Jay Honeck Home Built 18 January 20th 04 04:02 PM
Student Pilot Stories Wanted Greg Burkhart Piloting 6 September 18th 03 08:57 PM
