STAR to nearby airport
Old May 8th 04, 01:34 PM
Viperdoc
Default STAR to nearby airport
Recently while returning from a trip I was heading to my home base, which is
a class D airport. I was handed off to the local tracon, which has a class C
airport, and was issued a clearance to follow a star that led to a navaid
near my destination. However, the star was for the class C airport, not my
destination. The class D airport is well outside of the class C airspace but
inside the area covered by the tracon.
I happened to know the star was for the class C airport, and followed it
appropriately. However, in the Jepps it is listed under the class C, and not
my destination.
I have never encountered this before even in a busy radar environment- is
this a common controller technique for arrivals?
If I had been unfamiliar with the area and approaches, this could have
caused a few moments of frantic chart flipping. Besides, the star did not
list my destination airport as one of the transitions, although a nearby
navaid is the IAP for several approaches.
Since my last clearance was the star into the class c airport, if I had gone
nordo, would I have been expected to fly to the class C airport listed in
the star and do an approach , or should I do an approach to my destination,
even if not listed in the star?
Old May 8th 04, 03:07 PM
Dan Luke
"Viperdoc" wrote:
[snip]
environment- is this a common controller technique for arrivals?
Well, it's common at least in the Houston terminal area.
Besides, the star did not list my destination airport as one of
the transitions, although a nearby navaid is the IAP for several
approaches.
When I used to land at EYQ in Houston, I'd get the Trinity 1 arrival
every time, even though EYQ is not depicted on the STAR plate.
had gone
in
destination,
If you were cleared to the destination airport via the STAR, you should
fly the STAR, shoot an approach (if in IMC) and land. Don't do this if
you're a hundred miles out, though. The consensus of controllers and
instructors I have talked to is that a NORDO IFR aircraft is a major
pain in the airspace: ATC wants you to land as expeditiously as
possible.
Dan
C172RG at BFM
Old May 8th 04, 03:31 PM
Steven P. McNicoll
"Viperdoc" wrote in message
base, which is a class D airport. I was handed off to the local
tracon, which has a class C airport, and was issued a clearance
to follow a star that led to a navaid near my destination. However,
the star was for the class C airport, not my destination. The class
D airport is well outside of the class C airspace but inside the area
What's your home base?
Old May 10th 04, 03:20 PM
Dave Butler
my destination.
When I used to frequently fly to GAI in the Washington area, I would often get
the COATTx arrival for Dulles, then vectors to GAI, so I'd say it's fairly common.
Apparently there is some kind of list of "eligible airports" for a STAR. These
NOTAMs have been showing up lately for TTA, which is near Raleigh-Durham's class
C. ARGAL5 and BRADE5 are arrivals for RDU. DUAT plain-language translation:
Sanford NC (Sanford-Lee County Rgnl) [TTA]: January NOTAM #13 issued by UAR
ARGAL five arrival (ARGAL. ARGAL5) add TTA as an ELIGIBLE airport effective
from January 30th, 2004 at 11:24 AM EDT (0401301524)
Sanford NC (Sanford-Lee County Rgnl) [TTA]: January NOTAM #12 issued by UAR
BRADE five arrival (BRADE. BRADE5) add TTA as an ELIGIBLE airport effective
from January 30th, 2004 at 11:20 AM EDT (0401301520)
What was your clearance limit?
Dave
Remove SHIRT to reply directly.
Old May 10th 04, 06:24 PM
Everett M. Greene
Dave Butler writes:
Idle curiosity: I wonder why the oddball effective times.
If you were approaching at 15:22, you could be issued
BRADE5 but not ARGAL5. Two minutes earlier and you can
get neither and two minutes later you can get either.
Old May 11th 04, 05:58 PM
EDR
Take a look at KCVG (Greater Cincinnati International). This is CBAS
and all the airports with instrument approaches within the Mode C veil
use the SIDs and STARs.
I always file "NO SIDS OR STARS" in the Remarks.
Old May 11th 04, 06:46 PM
Steven P. McNicoll
"EDR" wrote in message
Why do you do that?
Old May 11th 04, 06:49 PM
Dave Butler
I don't understand. What do you mean "take a look at..."? Is there some document
you want me to see?
This is CBAS
Where does it say that? In the document you want me to take a look at?
Why do you do that?
Not intentionally dense, I'm just not getting your meaning, somehow.
Dave
Old May 12th 04, 05:53 PM
EDR
In article , Dave Butler
document
you want me to see?
This is CBAS
NOTAMs and Approach Plates
Why do you do that?
I am not a jet jockey. I fly a slow spam can. If I am given a SID or
STAR I am going to be flying miles out of my way, well below traffic
that the procedures are designed to separate.
Old May 12th 04, 06:39 PM
Teacherjh
Don't they just give you the SID or STAR anyway, just spell it out for you?
They want to vector you far away, they vector you far away./
Jose
SWRFI update... Moving again (argghh!!)... Dave S Home Built 14 October 15th 04 04:34 AM
Please help -- It's down to the wire Jay Honeck Home Built 12 July 14th 04 07:05 PM
The battle for Arlington Airport begins? Paul Adriance Home Built 45 March 31st 04 12:41 AM
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! Jay Honeck Home Built 18 January 20th 04 05:02 PM
Requirement to fly departure procedures [email protected] Instrument Flight Rules 77 October 15th 03 07:39 PM
