On my Komet trailer, the wingtips are held into place by a clamp with
a pad that is connected to the ceiling of the trailer. When the trailer is closed, this pad is pressed against the trailing edge of the wingtip. The construction of the rubberish-foam is about 3/8 inch thick. This pad needs to be replaced. Any suggestions of what to use? |
On Apr 22, 7:16*pm, Scott Alexander
wrote: On my Komet trailer, the wingtips are held into place by a clamp with a pad that is connected to the ceiling of the trailer. *When the trailer is closed, this pad is pressed against the trailing edge of the wingtip. *The construction of the rubberish-foam is about 3/8 inch thick. This pad needs to be replaced. *Any suggestions of what to use? There's lots of "rubberish-foam" available from McMaster-Carr on-line. They even have some Durometer charts to compare the degree of firmness of the various rubber materials along with their resistance to weathering. bumper |
wrote: On my Komet trailer, the wingtips are held into place by a clamp with a pad that is connected to the ceiling of the trailer. *When the trailer is closed, this pad is pressed against the trailing edge of the wingtip. *The construction of the rubberish-foam is about 3/8 inch thick. This pad needs to be replaced. *Any suggestions of what to use? Thick felt, carpet, neoprene wet-suit material... etc.. |
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! | flyingmr2 | Soaring | 4 | November 16th 10 02:11 AM |
Looking for source for tie down clamp for Ox bottle | [email protected] | Soaring | 3 | May 28th 09 07:20 PM |
Trailer tires for old (1981) Komet Trailer | [email protected] | Soaring | 3 | May 13th 09 10:24 PM |
Adel clamp source? | Jim Burns | Owning | 5 | October 31st 06 04:00 PM |
Adel clamp source? | Jim Burns | Home Built | 9 | October 31st 06 04:00 PM |
