Trailer tires for old (1981) Komet Trailer
Old May 12th 09, 04:32 AM posted to rec.aviation.soaring
Default Trailer tires for old (1981) Komet Trailer
I can't seem to find a local dealer with 165R13 trailer tires. Can
anyone tell me where to get suitable tires or if you substituted
something else e.g. 175/80R13 or similar and how that worked out.
IC
Old May 12th 09, 12:51 PM posted to rec.aviation.soaring
On May 11, 10:32*pm, wrote:
I can't seem to find a local dealer with 165R13 trailer tires. *Can
IC
I use 185/70R-13 on 1985 Komet. No issues.
-T8
Old May 12th 09, 03:40 PM posted to rec.aviation.soaring
Papa3
IC
I use 185/70R-13 on 1985 Komet. *No issues.
-T8
Check out the conversion chart here. Confirms that 185/70R-13 is a
compatible configuration. It's been a long time, but I remember my
local dealer being unable to find 165R13s...
http://www.tirerack.com/tires/tirete...sionchart.html
Old May 13th 09, 11:24 PM posted to rec.aviation.soaring
Trying to keep the overall diameter of the replacement tire the same
as for the orginal equipment tire isn't absolutely mandatory. Some
pilots use taller tires to get the back end of the trailer up higher
for more clearance when pulling out of a driveway, though that could
complicate rigging the glider with the trailer still hitched to the
tow vehicle. Other pilots swap the wheels for larger, wider ones and
mount low aspect ratio tires for more sidewall stiffness and
(hopefully) more stable towing, although this combination can give a
harsher ride. One of the most fundamental factors if you're keeping
the original wheels is wheel size, specifically width. Lower aspect
ratio tires may require wider wheels. You'll have to check your
current wheels against the allowable spec for the new size tires to be
sure they're OK.
Chip Bearden
ASW 24 "JB"
USA
Komet Trailer gas struts HL Falbaum[_2_] Soaring 13 February 1st 09 02:05 PM
Old Komet Trailer thermalrider Soaring 7 October 11th 08 05:13 PM
Komet Trailer Rims Tim Hanke Soaring 6 February 28th 06 05:56 PM
KOMET Trailer Cradle [email protected] Soaring 3 September 27th 04 05:33 AM
Komet trailer strut John Shelton Soaring 5 November 15th 03 06:04 PM
