AR 4201 low volume on receiving side
Old June 20th 12, 04:08 PM posted to rec.aviation.soaring
Alexander Swagemakers[_2_]
Default AR 4201 low volume on receiving side
I have purchased a used Becker AR 4201 and installed it in my glider. Reception is fine. On transmission the signal volume is very low on the receiving side. Even though the voice is clear, it is hardly understandable because of the low volume. I tried making some changes to the configuration to no avail (especially settings concerning the microphone).
Any ideas on what the problem might be? Has anybody experienced similar behavior before?
Old June 20th 12, 04:22 PM posted to rec.aviation.soaring
Bill D
On Jun 20, 9:08*am, Alexander Swagemakers
I'm not a radio engineer so they can jump in with a better explanation
but here's my take.
The radios we use are designed for airplanes. In a noisy airplane,
pilots will shout so mike sensitivity is set low so as not to over-
modulate the transmitter. Read the manual carefully and you will find
an adjustment for mike gain - probably behind tape or a placard. Try
some test transmissions speaking in a normal voice with an assistant
listening to a receiver at least a half mile away for over-modulation
as you increase the gain then back off a half turn.
Old June 21st 12, 01:46 AM posted to rec.aviation.soaring
T[_2_]
but here's my take.
The radios we use are designed for airplanes. *In a noisy airplane,
modulate the transmitter. *Read the manual carefully and you will find
an adjustment for mike gain - probably behind tape or a placard. *Try
I have been flying powered airplanes for 38 years and have never had
to SHOUT into a microphone to be heard.
T
Old June 21st 12, 02:20 AM posted to rec.aviation.soaring
Bill D
but here's my take.
T
You raise your voice naturally because you are in a noisy
environment. AFAIK, all 'airplanes' are powered.
Old June 22nd 12, 12:34 AM posted to rec.aviation.soaring
T[_2_]
but here's my take.
T
environment. *AFAIK, all 'airplanes' are powered.
Really? With proper hearing protection, ear plugs and flying helmets,
my ears and mouth do not know I'm in a noisy environment. With 15+ hr
missions, I've never come back with a soar throat from raising my
voice.
T
Old June 22nd 12, 04:13 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
voice.
And the sidetone is adjusted so you hear your voice in the headphones at
a decent level, which keeps you from shouting.
email me)
Old June 20th 12, 05:18 PM posted to rec.aviation.soaring
Tim Mara
It sounds to me like you have either connected your microphone to the wrong
pins or have an improper microphone.
The Becker radio accepts either Dynamic (amplified) microphones PIN 5 (and
also Mic Ground Pin 6) or accepts amplified dynamic, electret or carbon
microphones (wiring to STANDARD MIC) Pin 18 (and also Mic Ground Pin 6).
If you have a standard mic connected to the dynamic imput the voice
transmitted with be very low (unintelligible)
If you have a dynamic microphone connected to the standard mic input your
voice transmitted with also be very low (unintelligible)
the other mistake can be by using a microphone that is just the wrong type,
typically telephone, PC and other low cost microphones cannot be made to
work with most airband radios. diagram for wiring is on my website
http://www.wingsandwheels.com/useful.htm also, please see page 2-6 of the
manual for installation wiring guidelines.
Best regards
Tim Mara
"Alexander Swagemakers" wrote in message
behavior before?
Old June 21st 12, 10:45 AM posted to rec.aviation.soaring
Thanks for the fast response. Chances are good that this is the problem. The current wiring is for non dynamic microphone and my guess is that the normal goose neck microphone installed is probably dynamic. I will change the wiring and hope for improvement;-)
Am Mittwoch, 20. Juni 2012 18:18:23 UTC+2 schrieb Tim Mara:
Best regards
Tim Mara
behavior before?
Old June 23rd 12, 01:40 AM posted to rec.aviation.soaring
Wheaton
I had the identical problem two years ago. Sent it to Becker repair in Florida and they replaced a board. Now it works fine. $300+ Joe
HP310 and hx4705 - side by side, first impression Tuno Soaring 8 February 23rd 09 07:30 PM
HP310 and hx4705 - side by side, first impression Darryl Ramm Soaring 0 February 22nd 09 02:42 AM
Saturn V S-IC (first) stage are placed side by side prior to commencement of the mating of the two stages 6416485.jpg [email protected] Aviation Photos 0 April 12th 07 01:28 AM
For Mitchell Holman, if you want them... - F-15 & F-16 on pedestals WPAFB side by side.JPG (1/1) Blue Oval/Dan Edwards Aviation Photos 4 January 19th 07 01:19 AM
Is That a Resistor Wired Between the Hot Side and the Switch Side of the Solenoid? jls Owning 3 April 11th 04 04:55 PM
